Not really their little wes. But 2 or 3 thenths maybe is my guess.elwesso wrote:So this should put you in the low 12's by now, right?
qship96 wrote:More horseshitt from the horseshitter.
Which is why the mod is pointless. Without port matching the intake, it will do absolutely nothing for you and even then it won't really give you a noticeable benefit unless you port match the plenum to the cylinder heads as well. You may "feel" it in the butt dyno, but it's doing nothing for your true power.goody90q45 wrote:Not trying to be a hater but the opening on the intake is only about 80mm (measured on my spare plenum) so how will the flow increase and what gains can you expect from a 102mm TB?
Yooooo....I've been speaking to the Ladies and they say Little Wes ain't so Little....N/A Q45 wrote:Not really their little wes. But 2 or 3 thenths maybe is my guess.elwesso wrote:So this should put you in the low 12's by now, right?
IThaJ0kaI wrote:If the stock TB was that restrictive, why do SR, RB, KA guys all use them when making 600+hp?
Then dyno your car and prove your claims.N/A Q45 wrote:IThaJ0kaI wrote:If the stock TB was that restrictive, why do SR, RB, KA guys all use them when making 600+hp?
Turbo is soo much different then N/A I am not even going to try and explain. .
But even a turbo/supercharged can benefit from it. There's lots of info out there where gt500s gain about 30whp just from the TB.
Actually it's the opposite. Volumetric flow rate (Q) is the product of area (A) and velocity (V).. Q=V*A.. Rearranging the equation for velocity, V=Q/A. The engine's flow rate at a given RPM does not change, therefore you can consider it constant. If you increase the area (A), you decrease the velocity..SanCarlosQ45 wrote:
I can, or anyone else, can post them. As far as the throttle body I cant see it flowing any higher than stock as far as CFM because your opening is still 80mm, the velocity may increase but that may be unlikely.
Lol I know ehInfinitiguy19 wrote:Thank you N/A Q45 you make NICO's Q45 section worth visiting. We haven't had this much action here in a while!
Bringing in more air as in exhaust/cams/ -intake-elwesso wrote:Actually it's the opposite. Volumetric flow rate (Q) is the product of area (A) and velocity (V).. Q=V*A.. Rearranging the equation for velocity, V=Q/A. The engine's flow rate at a given RPM does not change, therefore you can consider it constant. If you increase the area (A), you decrease the velocity..SanCarlosQ45 wrote:
Anyone who is beyond their second year in engineering school (with any basic fluid mechanics course) can tell you that if the volumetric flow rate (or mass flow rate) doesn't change, then changing the cross sectional area will not do anything but reduce velocity which can be quite detrimental. The only other effects you would have are frictional losses and losses in the plumbing, both of which are fairly insignificant in this case..
The *only* way to create more horsepower is to make the engine capable of bringing in more air.
My mistake, this is why I'm Computer engineering, I hated Physics IIActually it's the opposite. Volumetric flow rate (Q) is the product of area (A) and velocity (V).. Q=V*A.. Rearranging the equation for velocity, V=Q/A. The engine's flow rate at a given RPM does not change, therefore you can consider it constant. If you increase the area (A), you decrease the velocity..
Here's what you're missing... If a given component is not a restriction in the first place, making it less of a restriction is not going to do anything!!!N/A Q45 wrote: Bringing in more air as in exhaust/cams/ -intake-
Just incase people don't know how a plenum works
> in alot of cases for most normal driving the stock plenum size is good for the lowend, idle. But the real problem is that the TB being smaller will have more velocity ( don't get me wrong velocity is a good thing to a point and the high velocity rushing in and hopefully slowing down builds pressure) and with the Qs design I don't believe that the air has enough time or room to slow down as the stock plenum is on the small size, it should be around 6.5L of volume for the best results. I don't know for sure how many liters the stock one is but I'm sure it's not 6.5L, so if the air can't slow down then it will try and run past the first runners more then the last ones in line, with the bigger TB and a little smaller plenum size you still keep the good idle and lowend while having more then enough air to supply at a lower velocity and all the runners would have a better chance of getting equal amounts of air, their will be less chance of it building pressure but I doubt the stock one has enough volume to build any anyways.
The TB seems to work pretty good and it doesn't feel like it dies off above 5700rpm like it did before with the stock TB.
elwesso wrote:Here's what you're missing... If a given component is not a restriction in the first place, making it less of a restriction is not going to do anything!!!N/A Q45 wrote: Bringing in more air as in exhaust/cams/ -intake-
At 7300 RPM, the VH45DE has the capability of flowing 580 CFM theoretical, assuming 100% volumetric efficiency.. Let's just assume that for kicks and giggles.. According to my math, a 90mm TB is capable of flowing about 1170 CFM.. That's not even HALF of what it's capable of, in a perfect world.. Since we know engines are not theoretically perfect, then this number goes down even more. The bottom line is, for a stock VH45 the stock TB will not gain any power. Period. End of discussion.
Any good engine builder always starts at the valve and works their way backwards. Any good engine builder knows that the biggest restriction in the intake system is the intake valve itself.... so it stands to reason that if you can decrease the restriction by increasing valve lift and/or valve duration, those are the next best places to go. Unless you're increasing the displacement of the engine, increasing the cross sectional area of any intake components will not gain you any power if it's not a restriction in the first place.
You really didn't read my post did you.. ahh wes you're good for a laugh I'll give you that lol.elwesso wrote:Here's what you're missing... If a given component is not a restriction in the first place, making it less of a restriction is not going to do anything!!!N/A Q45 wrote: Bringing in more air as in exhaust/cams/ -intake-
Wes can you just go look at a flow chart that shows how intakes that even are equal runner lengths can have problems.. like I said the stock plenum isn't big enough to give the air time to slow down with the stock 83mm TB so if it can't slow down and build pressure it will more or less blow right buy the right banks runners more then with the 102mm TB.elwesso wrote:The stock runners are equal length from the center line of the plenum to the valve. So, if the runners are equal length, how can one (or more) cylinders get unequal flow? Also, we would know if this is a problem if one or more cylinders have problems running lean with as many VH45's this forum has had and as many spark plugs as we've changed.. This is a problem on older small block chevy's and the typical fix is to change the intake manifold to an equal length setup (edelbrock or something). I don't think this is an issue with the VH45.
I don't have the numbers handy, but of some very thorough posts I've read show that the heads AND intake can flow considerably more air than 4.5L of displacement can breathe unless you're talking crazy modifications. I will look later, because I know there is actual measured flow data of the stock intake manifold and heads.
You say, "any good builder starts with the most restrictions first"... IF that's the case, why did you start with the TB? It's proven that the TB is not a significant restriction, so why start there? Seems to me like you just proved you're not a good engine builder? In all fairness though, a lot of what you're saying is true, but I don't think it applies here. Also, we've seen some pretty good gains from cam work in a VH45, I'll have to see if I can dig up those threads too..
I have yet to see any quantitative data proving my point otherwise, so until you show me some numbers I believe my point stands. All of the "data" you've displayed is qualitative and therefore irrelevant at this level of detail.
qship96 wrote:My question is why he wastes so much time and effort trying to make an old heavy obsolete 4 door sedan "faster" instead of investing his time and money in a remedial spelling and composition class at the local community college? That would provide a lifetime of benefits......long after that heap of a car is sent to the crusher.
