Rotaries aren't as bad as people make them out to be. It's usually the owner that neglects what the 13b needs. I've seen a lot of high horsepower 7's make the power w/o any problems all day long. To say they're unreliable is silly, as after taking any stock car and modifying it makes it more unreliable... IMO v8's don't belong in 7's. Reliable...I can think of one rotary car that is still running and still makes the power strong. 787B. Only Japanese car to ever win Le Mans.VMPhil wrote:you must really really want a fast car. im not so sure you want an RX-7 unless you have a lot of money to keep it running. Dont get me wrong the RX-7 is a sweet car but you may end up spending alot of money replacing Apex seals and filling the engine with Oil (as rotaries burn alot) . Rotaries are not overly reliable, which is why i have seen quite a few guys with RX-7's out right replace the roatary with a small block V8. Unless you got money to burn, dont do it.
Your A/F gauge doesn't show diddly squat about your actual ratio. Get a wideband O2 sensor and tell me what the readings are then. I guarantee they're better without your resistor mod.Twilight sentra tuner wrote:think of ur air/fuel ratio. factory intakes as u know are extremely restrictive. by switching to an open element or CAI the air goes straight to the manifold and is not rerouted to a deadend. the engine gets more air this way. basically the CAI compensates by getting enough air for all the parts of fuel. and remember, this car comes from the factory burning lean. i have an autometer a/f ratio gauge and the chip makes the car burn mostly stoichiometric. ( however no car can sadly achieve perfect combustion)
If it were possible to time the QG...but like the newer ones (mine) included, it's a distributer-less ignition system and just has coil packs...Twilight sentra tuner wrote:timings a good idea btw
What chip are you talking about? I have a CAI and have no problems with my car....?needtobefaster wrote:ok one of the main problems in my 1.8s is that my cold air is f**king with my o2 senser.
the thing is that the computer is reading the air intake 60 times a sec and adjusts, but when i turn the car for a start back up it does not reset the injectures it just keeps dumping more fule in the engine. how can i fix it.
do you think that a chip will be any good for my car or bad
Twilight sentra tuner wrote: got any other mods to improve the performance of the sentra for poor people????
