Mike W. »
https://forums.nicoclub.com/mike-w-u275015.html
Sat Feb 07, 2026 12:05 am
2003 QX4. 180K. Used oil since I got it 50K ago, but it's getting bad. Not quite check the gas, fill the oil but close. 6-700 per quart. Maybe. Runs great, nice interior, does need paint, killer 4WD. But it's an oil pig. I was just going to replace it with the dreaded T make, but those are just stupid expensive. And this is a known quantity. So I'm thinking about an engine replacement. Not looking for more HP or anything like that, just a lower mileage engine that isn't an oil pig.
So, after all that, I'm seeing some "Japanese" engines, which I have to assume are JDM, low mileage for reasonable price. I am in California if that makes any difference.
The obvious question is will they bolt up and run, and not set off the check engine light? I've searched, but results are thin. About all I'm seeing is 01-02 is cranky about slightly later engines. But I've got an '03. I would probably pay a guy to do the swap, I'm not afraid to get my hands dirty, but I have lost patience with laying on my back under the truck for extended periods of time. Like swapping an engine. So while I do feel he is skilled, I can't expect him to do a ton of research and changes to make it work. At least without paying him a bunch more money.
Executive summary: Is a Japanese market replacement engine a straight swap or not?
