After starring at it for many hours and over many beers, I decided I am going to try and swap the engine myself, I have a few questions which may seem silly though but would completely change the way I pull the engine. I have already stripped the engine from the top, complete engine harness, a/c compressor and lines, rad blah blah are all out from the top. Here is how it sits
Today I will reposition the truck better in the garage and attack it from the bottom for the next few days, as the exhaust manifolds, 02 sensors and transmission are going to probably be a HUGE pain.
My question really is how to I actually pull the engine away from the trans and out of the car. I understand I will need to take the trans to engine bolts out, aswell the fsm says after pulling the starter I will have access through the starter hole to undo torque convertor bolts (i think?) But I am unsure if I need to actually take the trans out of the car? Or can I leave it connected to its mount / driveshaft and just slide the engine forward and away from it?
I have never seen a tq convertor before, so Im unsure if it stays sitting on the engine or on the trans? Im assuming it stays on the trans on some sort of input shaft. See where Im a little lost here guys? If the trans needs to be completely removed from the vehicle that etc... Hopefully someone has some experience and tips they can lend me, because I am way over my head so far but learning as I go. I was also planning on undo'ing the exhaust from the manifold and leaving the manifolds attached to the engine as those bolts look impossible to reach in this chassis, looks like it will fit, disagree?
Any questions feel free to ask, I could use all the help I can get and if you guys dont mind I will post pics and questions along the way!! Cheers
