I found out that alot of things are different from 2001-2002 to 2003-2004. The crank and cam sensors do not output the same voltage and the same signals. The cam gears are also different... So you will need to install your 2001 cam,crank sensors and cam gears on the 2003 engine
Ok so need to make sure the JDM is from a 2001-2002 (same year as current engine). Swap over the cam / crank sensors.
I think he will need to change also the flexplate?? I read somewhere that they are also different and the signal plate on the 2003-2004 do not give the same signal or that the 2001-2002 dont even have a signal plate on the flexplate???
Again 2001-2002 JDM to avoid problems.
I remember seeing a sensor on the bell housing of the transmission once when I was under there. I am assuming that is for the signal plate.
