The correct way to make a Fuel pump Cut-off switch!! Tech Article
driftin8ez
Car: 92 Coupe, Turbo Miata
This mod is a good security feature as well as a helpfull diagnostic tool. If your car is having trouble starting you can use a fuel pump kill to see if it is getting to much fuel and flooding out. Also if hidden it makes a great anti-theft device.
What you need:
Tools:10mm socketFlat and Phillips head screw driversSoldiering Iron Wire stripper/cutter
Materials:14 or 16 gauge wire ( i used speaker wire as it is really two wires making it easier to fish around your interior)Solder and shrink wrap tubing (best method)or at the leastCrimp connectors and electrical tape (ok method)Toggle switchDouble sided tape to stick the switch somewhere hidden
--1)V
Locate your car. Hopefully it is where you left it the night before. After this mod you can sleep easier.
--2)VLocate and remove interior panels by passenger side right foot well. (s13 pictured, S14 may differ slightly)
--3)VLocate ecm and remove the 10mm bolts holding it to the chassis. Remove harness from ecm with the 10mm bolt and refer to diagrams to find fuel pump relay wire.
--4)VIn most cases the fuel pump relay wire is b/p or black with a purple stripe. Cut the wire about 6 inches from the ecm. Then connect the two 14 or 16 gauge wires one to each end of the cut fuel pump relay wire.
--5)VNow run this wire under the dashboard to the driver side foot well. Connect your toggle switch to the two wires. Hide the switch in a creative spot. Start the car with the switch on. It should start and idle normal. Flip the switch off and the idle should start to bog down as the engine starves of fuel. If your switch works correctly your done! Bolt you ecm back in and fasten all the interior panels back together. Hide the wires as best you can and Job complete.
Modified by driftin8ez at 4:55 PM 12/17/2006
Modified by driftin8ez at 11:33 AM 1/3/2007
Modified by driftin8ez at 5:03 PM 3/31/2008
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
Great Write Up!! 2 thumbs up!
skylinekin
Car: 1990 Nissan 240SX Hatchback
sweeettt, i am going to do this right now, thanks!
BRILLIANT!
Sweet article, this is going on http://www.240sxTech.com.
Let me know what you want your "custom title" to be!
Done.
Custom title = the tag under your screen name.
driftin8ez
AZhitman wrote:Done.
Ohhh lol... There i go again. Let me think about that one.Thanks for the name change as well.
rico05
Car: 1992 RMS13 w/ CA18DET
Nice. If my dash wasn't littered with random switches already, I would totally do this.
BTW, glad you kept your car Its hella nice.
adrianfromthecastle
Car: 1992 Nissan 240sx
got the ecu diagram for sr? btw, nice write up
driftin8ez
adrians_s13 wrote:got the ecu diagram for sr? btw, nice write up
I'll try and locate one but I'm not really to fond of the SR so i don't have the fsm or anything.
AZhitman my custom title will be = Jersey's Finest
Driftless240
Car: 1991 Hatchback
Man wants his Custom Title !!
sochinkyeyesshut
Car: PS13 Sr20Det I/E/FMIC/Tanabe Coilovers and other mods
: i second that diagram for an ESSSSSSS ARRRRRRRRGGGHHHHHHH
asher4857
Car: '89 240SX Fastback
ive been wanting to do a few kill switches in my car for a while now. this wont hurt the engine will it? like.. if i do this everytime i shut the engine off?
driftin8ez
well if you do it like this the engine will never know. Turn the engine off then flip the switch off. Turn the switch on then the engine .
asher4857
lol.. good point..
Dookie
Car: 1993 240sx Coupe
sochinkyeyesshut wrote:: i second that diagram for an ESSSSSSS ARRRRRRRRGGGHHHHHHH
There are plenty on the internet, search for it
IHeartTurbo
It would be better, safer, and easier to put the switch on the ground wire coming out of the fuel pump
lenso
Car: 1993 240sx hatch
here you go. red top pinout is 104 color is b/p
adrianfromthecastle
thanks bro!
driftin8ez wrote:I'll try and locate one but I'm not really to fond of the SR
eh... whatever.btw... email greg for the title. he'll get back to you in like an instant
driftin8ez
IHeartTurbo wrote:It would be better, safer, and easier to put the switch on the ground wire coming out of the fuel pump
You lose. Again this is THE BEST way of doing it. It doesn't mess with the stock power circuit of the fuel pump. It only controls the relay which controls the circuit.
Thank you i will add this to the original post.
le_ryan
Car: Mazda3
91 Nissan 240SX SR
not bad dood, I pulled my article, yours is much better.
driftin8ez
vroom-chirp wrote:not bad dood, I pulled my article, yours is much better.
Thank you Thank you
skylinekin
when i leave my car sitting for a few hours with the kill switch on, i flip the switch off and try to start my car and it takes alot longer than normal to start, does this happen to anyone else?? did I do something wrong?? I followed your directions, i have a SOHC and I spliced it in the b/p wire.
Drewster
Car: 1991 240sx
let the fuel pump prime first
skylinekin
it never did this before i put in the switch though.
S3t0_S13
Car: Of Nothing But FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL FAIL
dont just turn on the car immediatly, turn the key to start, (when the windows go up and down, jeez i forgot that position) give it a couple seconds so the fuel runs in the lines and then start her up, mine used 2 do that 2
GREAT write up by the way man, love it
skylinekin
alright, thanks.
driftin8ez
skylinekin wrote:when i leave my car sitting for a few hours with the kill switch on, i flip the switch off and try to start my car and it takes alot longer than normal to start, does this happen to anyone else?? did I do something wrong?? I followed your directions, i have a SOHC and I spliced it in the b/p wire.
If you turn your car off then flip the switch to kill the pump. Then come back and flip the pump switch so the pump will turn on before you put the key in, then turn on the car it should have no effect on starting. If you put your key in turn it to on then flip the switch it wont prime the fuel system and give you a longer start. The pump runs for about 3-5 seconds after you turn the key to the on position so if you still have the pump killed it wont prime.
SirSilvia
Car: Sold both my babies
well yeah once the engine sucks the fuel outta the line (when you flip the switch off) The pump has to send fuel through a partialy empty line therefore taking longer.
driftin8ez
SirSilvia wrote:well yeah once the engine sucks the fuel outta the line (when you flip the switch off) The pump has to send fuel through a partialy empty line therefore taking longer.
Correct but you should flip the switch after the engine has completely stopped spinning, and flip the pump back on before even putting the key in to have a seamless and closest to stock functionality.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
so using speaker wire and duct tape is the correct way to do this?
