i was boredkarmakaze wrote:
why are you hitting the switch with your car on?
When you hit the switch the car will not immediately die. There is still fuel in the rail and the lines that will get sucked out. It sounds like your switch is working correctly but it seems like you thought by installing this switch that if you flipped it when the car was still running your car would shut off like when you pull out the key. This is not the case. You are making a fuel pump kill not an engine kill. When the fuel pump gets killed you still have gas that needs to be used before the car will totally die out. Hope that helps.Seto wrote:ey guys i dnno what the problem is, when i hit the switch, my idle drops to like 300-400, and the car seems to be choking, if u tap the gas it will shut off, but if you ease on it, you can almost get the car going
wtf, i checked my wires, and their not connecting anywhere
how did he mount it there?
Couldn't have said it better myself.adrians_s13 wrote:and the trophy for the most random and irrelavant post in regards to thread topic goes to...Keimcongradulations!
Dude i am so confused right now. What do you mean your friend got the car started? Was it not supposed to start? Did he hot wire it? Sounds like your car some other issues. If you followed the guide exactly your car should act no differently than before. I say undo all you work and sort out your issues. If it's fine with no switch retrace your steps and see what you did wrong. This is on the lower end of skill needed so you should be able to get it right. GLSeto wrote:sorry, i made it sound wrong
i had the fuel pump switch on
and my friend got the car started and got it moving, he just had to keep it at high idle or else it would start to bog and shake
are my wires touching somewhere??
yea i didredtop91 wrote:Did you splice them Seto?
3rd thatschanne wrote:^ I second that
Yea i need pic's 2, i still read pop up books because words are to complicated and boringslipipinoi wrote:yeahh picturesss. i dont want to mess up. :Pi want to do this over the weekend hehe
