*Preface: Hello all and welcome. STFU and read, kthx. "What if I have further questions after reading?" you ask? Search. SEARCH, please. Also, take note of the lovely (but abbreviated) forum list on the right of your screen, below the ads. If/When you feel the need to make a thread, be sure to take a good look at that list first and make the right decision.
This thread, as it stands now, is a compilation of three already existing threads made by GrilledCheese33, ClubSX and ddgsxr4504 -- so many thanks and good job.
by GrilledCheese33
*240SX Buying Guide/General Overview*
If you are considering buying a 240sx, but not sure which model you want or like best, this is the guide for you! Here is a full breakdown of all the years the 240 came into the U.S. with pictures. I hope it’s helpful!
The s13 body style (89-94):
The s13 came in 3 Body Styles:
The Hatchback or Fastback
The Coupe
The Convertible
The Pignose:
The First year of the 240sx was 1989. It came with the Pignose Front bumper:
The pignose front was only used in 1989 and 1990 and there was no convertible made in these years. These years have the 2.4 Liter KA24E Single Overhead Cam(SOHC), inline 4 cylinder engine.
This engine produces 140hp and 152 lb/ft. tq.
The Chuki
The Chuki came into production in 1991 and was carried out until 1994. It came with a newly re-designed front bumper:
A new engine was also introduced in 91. The 2.4 liter, KA24DE Dual Overhead Cam(DOHC), inline 4 cylinder engine.
The Dohc Produces 155 hp and 160 lb/ft. tq.
In the chuki years, some hatchbacks have the SUPER HICAS 4 wheel steering system. This aids in handling, but most people disable it. Hicas bypass products can be found at one of our many sponsors. See link below.
The convertible began production 1992 and note that all convertibles are automatic. These cars were shipped here as coupes, then converted over by ASC.
Also note that in 1994 the only body style sold was the left over convertibles from 1993.
S13 Trims:
XE Coupe- Pignose coupe, pw, pdl, cloth seating power moonroof
Base- pw optional, pdl optional, cloth seating, sunroof otional
SE- pw, pdl, cloth seating, rear spoiler, sunroof optional
LE, pw, pdl, leather seating, rear spoiler, sunroof
Buying Guide:
There are some things to look for when buying an s13. Mileage is normally not a very big issue as the KA is known to go well over 200,000 miles if maintained properly. I wouldn’t recommend buying one with super high mileage, but if you are assured it has been properly maintained, then you should be fine.
Listen to the engine at idle. If it makes a “Marble Rolling in a Tin Can” noise coming from the front of the engine, that would be the timing chain guides. These are plastic and are deemed unnecessary by Nissan. They will eventually break off if not removed. There is a great write-up here on nico that shows how to take care of this issue by removing the guides. It is about a 3hr. job and is fairly simple if you are mechanically inclined.
Rust is also a common problem. A few common spots for rust are the strut towers, wheel wells, and lower doors. The worst one is on the hatchback. If the hatchback has a factory spoiler, then there WILL be rust under that spoiler 90-95% of the time. The factory spoiler is foam and it will rust your hatch to no end. It is better to find a hatch without a spoiler, but if your baby has a spoiler, you can probably find a spoiler less hatch here in the nico classifieds.
The s14(1995-1998):
In 1995, the 240 underwent a lot of major changes. It came out with a totally restyled design including no pop up headlights, a wider stance, more solid chassis, and a much more comfortable interior, but continued to use the DOHC engine as used in the chuki.
The Zenki(95-96):
The zenki front end came out in 1995 with the new s14.
Note these headlights yellow in summer heat, but the yellow is easily buffed out with aluminum polish, wax, or rubbing compound. The SE zenki comes with a factory black front lip.
The Kouki(97-98):
In 1997, the kouki front end came out.
These headlights do not yellow. The kouki is the higher demanded style of the two s14’s and are hard to find at a good price. Some koukis will have factory sideskirts, but if you want a front lip, those did not come factory and will need to be purchased separately if desired. Nissan made an OEM lip for the kouki, but for some reason, it didn’t come factory.
S14 Trims
Base: 4 lug wheels, pw, pdl, cloth seating black faced gauges, sunroof and spoiler optional, no rear sway bar
SE: 5 lug 5 spoke wheels, pw, pdl, cloth seating, white faced gauges power moonroof (optional in 95, 97, and 98), rear spoiler, fog lights, abs and vlsd optional
LE: 5 lug 5 spoke wheels, pw, pdl, leather seating, white faced gauges, power moonroof, rear spoiler, fog lights abs and vlsd optional
Buying Guide:
same mileage deal
same timing chain guide issue
The s14 really has no common rust areas that I know of to date.
The 240 is a very fun and reliable car to drive. You won’t be disappointed in it. I hope you enjoyed my guide and good luck finding your new car!
by ddgsxr504
*Model and Engine/Engine Swap Info*
Introduction:
The Nissan 240SX was a rear-wheel drive front engine (FR Layout) coupe built and sold from 1989 to 1998 in the United States designed to replace the rear-wheel drive 200SX.
The car was well known for its snappy, precise handling, good chassis balance, and legendary Nissan reliability but were plagued with underpowered engines and low production numbers.
Two distinct generations were marketed and sold in the United States; the S13 from 1989 to 1994 and the S14 from 1995 to 1998. American versions of the 240SX came with a 2.4 liter KA-series naturally-aspirated engine producing approximately 140-155hp at the crank.
1989-1994 "S13":
This generation of the 240SX was sold in the United States from 1989 to 1994, and were separated into two distinct "sub-generations" - the Zenki and the Chuki.
Models made from 1989 to 1990 were called the Zenki (lit. Preceding Period). Two models of the Zenki were sold, the coupe (XE) and fastback (SE). The coupe is based on the Japanese version of the 240SX (Silvia) while the fastback is based on the Japanese 180SX. The only major difference between the United States Zenki coupe and the Japanese 240SX were the retractable headlamps. American regulations did not allow Nissan to directly carry over the Japanese 240SX headlamp arrangement. The American models were powered by a 140hp KA24E engine which had 3 valves per cylinder, carried a 2.4 liter displacement, and was single over-head cam (SOHC). Four wheel disc brakes were standard all around, with ABS offered as an option on the SE fastback model. Both models also had the option of a 4-speed automatic transmission or a 5-speed manual transmission. The XE coupes also had a digital Heads-Up Display option.
Models made from 1991 to 1994 were called the Chuki (lit. Middle Period). Four models of the Chuki were sold, the coupe (XE), the hatchback (LE), the fastback (SE), and the convertible. Basic body design remained the same; the LE hatchback added leather interior. The powerplant was replaced with the KA24DE, which had dual-overhead cams with 4 valves per cylinder producing 155hp & 160ft lbs. Several options were made available to the SE model, including a viscous limited-slip differential and Nissan’s all-wheel steering system called HICAS. The convertible model was added in 1992 and was exclusive to the American market. The only transmission option for the convertible was the 4-speed automatic transmission.
1995-1998 "S14":
This generation of the 240SX was sold in the United States from 1995 to 1998, and were separated into two distinct "sub-generations" - the Zenki and the Kouki.
Models made from 1995 to 1996 were called the Zenki. The body shape was redesigned from the S13 to produce a longer and more flowing look. The convertible and hatchback lines were dropped, and only the coupe design remained. The new design had a longer wheelbase by 2 inches, was about 20 pounds heaver, did not have the flip-up headlights, and benefited from the addition of dual air bags. The base model Zenki had 15-inch 4-lug wheels, softer suspension, and no rear sway-bar. The SE model had 5-lug 16-inch alloy wheels, a stiffer suspension, and a rear sway bar. Additional options available to the SE model included a viscous limited-slip differential and ABS. Mechanically, the S13 and the S14 are virtually identical.
Models made from 1997 to 1998 were called the Kouki (lit. Latter Period) and a host of minor changes to the body style and design were made. Mechanically, the car was identical to the S14 Zenki. The front of the car was redesigned with a more aggressive look, with projector lights, new hood, bumper, and fenders. Side-skirts were made standard, and the taillight was also redesigned to look darker and more aggressive. An LE edition designed for luxury was also added to the line which included leather seats, keyless entry and alarm, and a cd-player. This generation marked the end of the American 240SX. Japanese versions continued into 2002 with the production of the S15.
Reliability:
Generally all American 240SX’s were very reliable. Rust remains a major concern for any vehicle, not just the 240SX. Major areas to look for when purchasing a used 240SX are the rear wheel-well, under the driver’s and passenger’s doors, and the front wheel-wells. The muffler or exhaust system may have rusted through and require replacement.
Take the car out for a drive if possible. Pay careful attention to the sounds the engine makes. The engine is an iron-block inline 4 with a forged crank and is generally extremely reliable. However, because of its long stroke, the engine is more susceptible to damage from over-revving it. The engine should sound smooth and deliver its power up to around 5500RPM, at which point the power will diminish slowly to the redline of 6900RPM. If there are any ticking or clicking noises, check the timing chain. Many KA24 engines wear away at the timing chain guides which are made of plastic. If they are worn, you can either remove them entirely or replace them. If the engine has problems, KA24E or KA24DE replacement engines are very easy to find.
In the S13, the digital heads-up display often malfunctions or does not work at all. Most people choose to remove the unit entirely, citing it as more trouble than its worth.
Modifications:
The 240SX has a large growing community of modders behind it. Almost anything in the car can be swapped for its Japanese counterpart, including the engine, climate control system, transmission, gauge cluster, and rear differential.
A popular modification is to replace the underpowered KA24 series engine with a Japanese SR20DET engine from a Japanese 240SX, known as the Silvia. The SR20DET comes with approximately 205/225/250hp and later models introduced variable valve timing. While the engine is swapped, the transmission also must be swapped to the SR20DET transmission. 1989-1998 Japanese Silvia’s have 5-speed transmissions, while 1999-2002 Silvia’s have 6-speed transmissions.
Another popular modification is to turbocharge the stock KA24-series engine. A custom or pre-fabricated turbo kit adds as much as 70hp to the engine and extends the power band well past 5500RPM all the way to redline. Because the engine is built with an iron block and forged internals, and has a long stroke, careful tuning of a turbocharged KA24 engine can produce a very powerful torque monster in excess of 250hp and 280ft-lbs of torque.
Far into the extreme modifications include swapping the stock engine out for the Nissan Skyline engine (RB20DET, RB25DET, RB26DETT). The RB series is an inline 6 cylinder turbocharged engine from 2 liters to 2.6 liters. This series of engines is legendary for their indestructible construction and ability to handle in excess of 500hp. However, choosing this route can be very expensive and require extensive modification of the engine bay. However, companies such as McKinny make engine mounts that ease the installation of these monster engines into the 240SX engine bay.
Another option is to install the 180SX engine, the high-revving CA18 series into the 240SX. With a displacement of 1.8 liters and a short-stroke design, this engine can make in excess of 300hp and can rev well into 8000RPM.
Less extreme modifications include installing an improved intake and exhaust system. Allowing the engine to breathe easier makes it produce slightly more horsepower (around 5-10 more hp). Also a popular modification to the S14 year KA's is the installation of S13 KA camshafts as they are of a higher duration bumping up HP slightly. The Japanese digital climate control system will also install into the car with some minor wiring changes.
Popular with the drifting crowd, suspension upgrades do more than improve the handling of the car. Lowering the car a reasonable amount removes unsightly wheel gap in the front and rear wheels. Installing stiffer springs and harder shocks makes the 240SX handle much “tighter” and more responsive to steering input.
Additional Information:
Number exported sorted by year - including convertibles:
1989 - 68118
1990 - 60582
1991 - 34534
1992 - 27033
1993 - 21471
1994 - 1391
1995 - 25114
1996 - 7334
1997 - 3655
1998 - 2178
Number exported sorted by year - convertibles only:
1992 - 2327
1993 - 4602
1994 - 1391
by ClubSX
*A Newcomer's Guide to 240sx Conversions*
For NICOnaut Newbies or even if your not that would like to know the different front-end conversions then this thread is for you. The following are common front-end conversions that have been done to the 240sx. Help on putting together the kit can be found by doing a SEARCH
S13 CONVERSIONS
Silvia Front End on 240sx Coupe
The Silvia Front-end conversion was taken from the Japanese Silvia only sold in Japan. Depending on the kit, the headlights are offered in Dual or Triple Beam projectors and also halogen headlights.
Silvia Front End on 240sx/180sx Hatchback
The Silvia Front-end on the US produced 240sx is sometimes refered as the Sil-forty, named for the Silvia front and the 240sx body. Japan produced a low number of Sil-Eighties that included the Silvia front on a 180sx.
R32 Skyline on 240sx Coupe and Hatchback
Very few people have done this conversion due to hard labor. The conversion requires alot of body fitment of the panels and may require cutting. This conversion includes the Skyline Front with a Coupe body.
S15 Front End on 240sx Coupe and Hatchback
The conversion is also seen as S13.5 and includes the Nissan S15 front-end onto the 240sx platform. Beaware of cheap kits. Many kits may look like the real deal but when found out are cheap and easily breakable.
280z Front End on 240sx Hatchback
Few enthusiasts have converted the 240sx Hatchback into a Classic look. With a bit of work and cutting the 280z front will find its way quite smooth with the hatchback's lines.
Kouki S14 Front End on S13 Hatchback
A unique conversion in its own, requires much labor on the fender in which you can see where the front windshield and the fender meet that its alot wider then the S13 fenders.
S14 CONVERSIONS
S14 Zenki to S14 Kouki
Due to the high price of the Kouki's many people are tempted to buy for Zenki and do the Kouki conversion. Only a select few parts are needed in this conversion and can be found in the May 2006 issue of Modified Mag.
S15 Front End on S14
This conversion requires little fabrication and the kits come with the body panels matching up.
R34 Skyline-S14 Conversion
This is a kit that has only been done a few times due to the massive amount of fabrication and cost of parts. I have yet to see one in person.
R33 Skyline-S14 Conversion
The kit has been done by fellow Nico Member starkos14(Steve). Many hard hours have been put into this kit. Not to mention money and also trial and error. To do this conversion it requires R33 parts and possibly extras incase of an error. Any questions can more then likely be answered by Steve.
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (SeVa-S13)
Posted by: SeVa-S13 at 8:19 PM 7/2/2006
I was thinking about unsticky-ing ddgsxr504 and ClubSX's threads, but putting a link to them in this thread, next to the beginning of each part in the main post. Sound good?
Edit: Gunna list other useful threads here to be compiled as a list later when there's a decent amount.
http://forums.nicoclub.com/zerothread/223218 - Z brake-clearing wheels
Posted by: turbogeorgez at 10:19 PM 7/2/2006
Oh and repo asked me what I wanted for a custom title for making that article, but never got back to me. Think you can help me out on that one Seva??
Post Title:
Posted by: Black on Gold at 7:47 AM 7/21/2006
Here are all of the trim packages and optional performance equipment. This stuff was really confusing when I was looking for a 240 so hope you guys find it useful.
Trim Packages
1989
SE Fastback
XE Coupe
1990
SE Fastback
XE Coupe
1991
Standard Fastback
Standard Coupe
SE Fastback
SE Coupe
LE Fastback
Limited Fastback
1992
Standard Fastback
Standard Coupe
SE Fastback
SE Coupe
SE Convertible
LE Fastback
1993
Standard Fastback
Standard Coupe
SE Fastback
SE Coupe
SE Convertible
1994
SE Convertible
1995
Standard Coupe
SE Coupe
1996
Standard Coupe
SE Coupe
1997
Standard Coupe
SE Coupe
LE Coupe
1998
Standard Coupe
SE Coupe
LE Coupe
Optional Performance Equipment
ABS
1989-1993 SE Fastback
1991 and 1995-1998 SE coupe
1991 LE Fastback
1995-1996 Standard Coupe
1997-1998 LE Coupe
VLSD
1991, 1992, and 1993 SE Fastback
1995-1998 SE Coupe
Super HICAS
Sport Suspension
1990, 1991, and 1993 SE Fastback
You can find this stuff on my site too (240edge.com).
Posted by: NoOneIsPerfect at 5:05 AM 8/5/2006
It started off as people who crashed their 180's front end to easily fix up and also upgrade to sr20 from ca18. Two cars in accidents patched up togther and running are commonly called as "Niko-Ichi" cars in Japan (translation: two for one)
Though it is rare even in Japan. I used to go to Rokko-touge a lot when I was in highschool (my school was just minuites away) just to look at cars drifting and such and only saw few.
Neways, GREAT INFO!!!! Who ever put this together must have taken hours to complete this!
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (NoOneIsPerfect)
Posted by: SeVa-S13 at 7:17 PM 8/8/2006
AKA NISMO GIRL
Post Title: NEWBIE
Posted by: DragDrift240sx at 9:13 AM 9/17/2006
| Quote, originally posted by eds13 » |
good thread!!!!! but um... more pics of the fastback with the kouki front or ban!!!!! |
but that's it, but i just have two questions:
1.Is the '89 coupe have an hydrauclic or manual clutch?
2.And does it have hydraulic or manual lifters?
Just asking because I want to fix the clutch and the lifters asap.
Post Title:
Posted by: CantSTOP at 3:17 PM 10/25/2006
Heads up i do believe so, but mine doesn't work. I really do want one though, one that shows my odometer and speedometer, that way I don't have to look down when i drift.
plus they look pretty sweet with the S14 front ends so that's what i want to get
http://www.datsun.org/fairlady/silvia.htm
http://www.200sxs13.nismo.org/Brochures.html
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (eds13)
Posted by: Black on Gold at 6:56 PM 11/2/2006
Here's a good one
Post Title:
Posted by: Fox_Trot at 5:00 PM 11/6/2006
(victim is 240sx hatchback)
does S13 to Zenki front end conversion require new core support? also am i gona have trouble with fenders?
Post Title: Re: (ubermoose)
Posted by: maff2099 at 10:36 PM 1/10/2007
| Quote, originally posted by maff2099 » |
| what has more head room, leg room, better feel in the back seats, the coupe or the fast back. i searched |
Im sorry but when they decided not to have cup holders due to weight reduction, they decided not to have rear seats also.
Posted by: gatz at 10:03 AM 1/17/2007
pics to come as soon as my lazy a** gets off work and goes to take pics.. prolly in a couple hours it should be...
needs... paint (rockin a panda 240 atm), suspension, and thats about it
Post Title:
Posted by: UsJdmTuner at 10:25 AM 2/15/2007
just trying to figure out wut year i want to buy...??? THANKS 4 the ADVICE
Posted by: Optical_Illusion at 2:21 PM 2/28/2007
QUOTE]
Hi guys I am new to the 240's so I am trying to learn as much as I possibly can. the main problem is which motor I want to run, the KA24, or the SR20. I was reading this thread and it specifically says that the KA turbo will do 250hp but it also says that the SR20 Turbo does 250 hp. My Question is: is this correct, if so why does everyone switch to the SR motor?
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (steveortiz1985)
Posted by: R6_240sx at 1:42 AM 3/8/2007
There are also benefits of KA-T which most people would say is Torque. Ever since SR prices skyrocketed KA-T setups grew as an alternative and because of that a main problem that is often seen with KA-T setups is that it's cheaply done which can lead to lots of problems, but if done right, well...
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (R6_240sx)
Posted by: steveortiz1985 at 1:49 AM 3/8/2007
what this called? a silvia s14.3
Post Title: Re: (R6_240sx)
Posted by: brkn240 at 11:06 AM 4/25/2007
| Quote, originally posted by SeVa-S13 » |
| Because the engine is built with an iron block and forged internals, and has a long stroke, careful tuning of a turbocharged KA24 engine can produce a very powerful torque monster in excess of 250hp and 280ft-lbs of torque. |
The rear of the S14 also changed in 97, when the switch from Zenki to Kouki was made. The zenki tails were slightly bubbled, and had a little "valley" in the middle, and the nissan emblem was chrome. The kouki tails were flat, had the litle steps, were slightley blacked, and had a black nissan emblem in the center.
Im not a mod, so i dont have the power to edit the origional post, but ill include a pic of each tail light, so it will be easyer for whoever decides to (if they do) edit the post.
Zenki:
Kouki:
If you want to swap the tails, they are a direct replacment, and can be done without having to fabricate anything, or replace anything (besides the tails
Also, on the S13, a common thing done (but not too common, because they are usually in the $500 area) is to swap the zenki/chuki tails, to the kouki tails. They were only offered in japan, as the U.S. never saw the kouki S13 Hatch.
Zenki/Chuki Tails:
Kouki Tails:
Also, one last thing. Mabey sombody can include the code in the S13 section? You know, the code how if you say like RPS13
R = hatch, M = KA, P = SR, etc?
I dont know the whole breakdown, but i know somebody has it in their sig.
Im also pretty sure (but could be wrong), that in TS13, T = coupe?
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (SketchyRollin564)
Posted by: SketchyRollin564 at 2:20 PM 5/12/2007
heres my examples:
S13.5 hatch:
S13 coupe, silvia front end:
and also, heres a more clear example of a sileighty:
Posted by: texxx at 10:03 PM 5/20/2007
this is very classy, I want to know more about it lol I hope it will work with an sr20det conversion, coz so far that looks like the way I want to go!
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (240sxprjct)
Posted by: Wuze at 8:58 AM 7/27/2007
I drive a 91' Nissan 240sx hatchback.
I dont have any awesome racing stories, and I dont drift or have an sr20det engine under the hood.
But I love my car more than anything.
I absolutely love this forum. Ive been going through and reading all of the posts and looking at your pictures for hours.
This site mesmerizes me =]
Post Title: Re: (Konstantine)
Posted by: Cameron at 10:29 PM 8/2/2007
| Quote, originally posted by chichihuil » |
| im looking at getting a fully stock 1998 240sx SE. it has 47,000 miles and has been very well kept. what would a reasonable price for it be? thanks -carlos |
http://forums.nicoclub.com/zer...33916
A VERY nice car...If its as nice as that one^^..you're looking at around 10k.
Post Title: yay pics!
Posted by: chichihuil at 4:46 PM 8/6/2007
Posted by: crakin at 7:27 PM 8/10/2007
| heres a pic of te one im lookin at. ill get better pics up once its MINE! muahahahahaha ![]() |
Let me say that it isn't a minor modification, at least if you want OEM-like fitment. Plenty swap the front but they usually look like ****, poor fiberglass fenders, cheap bodywork and bad mounts all make for a chop swap that is commonplace. S14xman (I think that is his name) has a pretty good swap and there are a couple others too that actually spent time on theirs to get it right and it made me appreciate the concept of the swap seeing their cars.
Mine is done by using special fabricated front mounts; zenki fenders that were cut at the windshield down to the bumper and reshaped along the hood, headlamp and bumper; The bumper is an OEM S15 with the license plate frame removed and smoothed to the curvature of the bumper.
Using a S15 core support, reinforcement bar and headlamp brackets would offer the best fit IMO, although I feel my setup has about the best fitment you'll find on a Zenki S14.5 that is on par with using all OEM parts. Mending S14 and S15 OEM fenders would help to, but I personally preferred the zenki fenders being worked over as they flare out more overal and offer better wheel clearance than the S15's where just the wheel arch flares out.
Modified by Dopefish at 7:16 AM 11/14/2007
Post Title: Re: (Dopefish)
Posted by: 95-240-SX at 6:53 AM 11/23/2007
heres what im working with and the little transformation made so far into becoming a work of art..
lmk what you think..
Post Title: Re: (95-240-SX)
Posted by: Dopefish at 3:06 AM 12/10/2007
| Quote, originally posted by 95-240-SX » |
| What kind of hood is on your s14? I like the way it looks. I just got my s14 and plan to do something with the front end eventually. |
OEM-style carbon-fiber hood, the center-section is tinted carbon-fiber, sort of hard to take a picture of though.
Post Title:
Posted by: I :heart: Touge at 9:18 AM 12/10/2007
Can someone explain?
Modified by rage941 at 7:59 AM 1/3/2008
Modified by rage941 at 8:00 AM 1/3/2008
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (rage941)
Posted by: amolao at 8:24 AM 1/3/2008
Just playing the devil's advocate....
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (amolao)
Posted by: harrypotter at 1:02 AM 1/9/2008
i am new here!
more to come!
Posted by: fender-startocaster at 4:06 PM 1/17/2008
| Quote, originally posted by Black on Gold » |
Here's a good one |
*edit: holy shyt I was replying to the first page lmao! that's what work 2 in the morning will do i guess..
Posted by: delishnick at 10:14 PM 4/15/2008
Thanks ( I have searched, but it seems to be unclear )
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (phatjo911)
Posted by: night240 at 11:12 AM 6/21/2008
cool stuff in here.
Anyways im looking for a Zenki 240 prolly 91 to 94 got a budget of 4200 plus i live in MN
Any answers? (I've look quite a bit online)
Post Title: Re: (super-up)
Posted by: super-up at 9:57 AM 8/18/2008
my weekly run to the tire shop
at my house
swap time.... both of my drift cars lol
any body know wat this is lol
Post Title: Re: (stevespeed)
Posted by: 240sxman7139 at 1:49 PM 11/19/2008
: those side skirts and your rear bumper are FUGLY and so ricey... | Quote, originally posted by rage941 » |
| Hey I'm a noob and I'm interested in buying an s14. So I was looking at them on the internet and I came across something that I don't understand. In this thread it is stated that the LE(that's the ONLY edition with leather right?) was only an option for the 97-98's. Well I saw an s14 on the internet that they say is a 96. But it has leather. So I thought, well maybe it's a typo and it's really a 97. But that can't be because it has the Zenki front and rear of the 96's.
Can someone explain? |
This thread makes the mistake of not mentioning the LE model of the Zenki. I have a 1995 LE with a leather interior and everything mentioned under the LE model for the Kouki (with the exception of the foglights; I'm not sure if my bumper was replaced anyway).
When I got my 240 I was also looking at another one very similar and it was an LE (1995 too). Said "LE" on the back and had the leather interior and everything. Then I saw the car that I'd eventually get and was led to believe it was a base 240SX until I checked up this thread (which is somewhat ironic cause this thread is inaccurate). It had all its emblems missing and I had to purchase them myself so I didn't realize until somewhat recently that it was an LE.
But the point is, an LE model does in fact exist for the Zenki. This thread completely ignores it. I've been meaning to mention this for some time but never got down to it.
I realize your post is from a year ago and also that your pictures do not work, but I can tell you that the car you were looking at was a 1996 240SX LE.
Posted by: JulianMG at 6:09 PM 2/19/2009
required reading
Posted by: dosovm at 10:27 PM 4/16/2009
Posted by: tx240s14 at 10:17 PM 4/21/2009
| Additional Information: Number exported sorted by year - including convertibles: 1989 - 68118 1990 - 60582 1991 - 34534 1992 - 27033 1993 - 21471 1994 - 1391 1995 - 25114 1996 - 7334 1997 - 3655 1998 - 2178 Number exported sorted by year - convertibles only: |
Viewable shortly at " http://www.thezregistry.com/ "
All will be ready with a GOOD 240SX convertible registry soon.
Post Title: Re: THE 240SX Info/Introduction/FAQ Thread (AZ-ZBum)
Posted by: muffincat at 12:59 AM 10/13/2009
< Contact Us - NICO
