 S13 Doorpanel write-up
StandardProspect
Online
'93 240sx '98 Q45
Delafield WI
2-14-2008
I got sick of my doorpanels being rough and not comfy so i decided to try my hand at recovering them. i thought it turned out really well. much better than i ecpected.
i love the material i picked out. it is almost a felt-like material and it is easily strechable, which is very important for this diy project.
I bought 1.5 yard of this doubleovered material at walmart for $6 and a can of elmers craft spray glue for $5
Cost: $11
Time: 1 hour, but take your time
materials: fabric of your choice, spray glue
Tools: Screwdriver, razor blade, blowdrier or heat gun, and scissors
If you havent removed the tweed from you door panels yet this is the first thing you should do. here is a link to the write up for that.
http://www.nicoclub.com/articles.php?id=175775
Heres all the stuff i used
This is what the door panel looks like with the tweed removed
start by removing the handle trim, holy sh*t handle etc.
next, cut enough material for it to be draping over your door panel. (it will be a lot easier if you do this instead of trying to hold it up while gluing)
start spaying glue in the middle of the door panel and continue to glue arount the holes for the parts you must put back on. smooth out the fabric and make sure there are no creases.
now, using the razor blade, cut a hole for the little handle thing and put the handle thing back on. (this will help keep the fabric in place)
then the holy sh*t handle
and then the handle/lock trim
now you are going to need the blow drier/heat gun to heat up the material to make it more strechy and easier to work with. after heating, glue the area with the large curve making sure there are no creases in the fabric. (this was surprisingly easy with the material i used)
once all the fabric on the panel is glued down for the most part you can trim the fabric smaller so its easier to work with the edges.
the next part can be sort of tricky. do some fine trimming with the razor blade and leave about a centemeter of fabric from the crevas in the panel. you then tuck the fabric into the crevas while using a small amont of srpay glue on the very edge.
continue tucking in the fabric around the entire panel
once you are done with that, the door panel is ready to go!
i love the finished product. this is my favorite diy interior project so far.
using the same material i also recovered my glovebox, padded my armrest, and made shift and e-brake boots. it gives your interior a much classier look and feel. i will post pics of my interior once enverything is complete.
GOOD LUCK
11:11
If it's good or if it's fortune I can't tell,
but pieces come together for some reason just as well
s13gebala
99 maxima , 91 sr hatch
Chicago il
4-15-2008
not bad, but i think if you would take apart the door panel it would be much easier
StandardProspect
Online
'93 240sx '98 Q45
Delafield WI
2-14-2008
 « Re: (s13gebala)
as far as i know i dont think it comes apart. you mean remove the door panel and do it on a flat surface?
BMAR240SX
1993 240sx Coupe
QUEENS NY
8-21-2006
 « Re: (s13gebala)
Sexy
F.S. S13 Fujitusbo Leagis R Exhaust
http://forums.nicoclub.com/zerothread?id=472422
madmeg323
Denham Springs la
10-12-2005
 « Re: S13 Doorpanel write-up (bjohnson)
Beautiful.
diggles240
1996 240sx SE
Harrisonburg VA
2-14-2008
 « Re: (bjohnson)
looks good man. what is the material that you used- weight, etc.? i am considering something like this in lieu of the duplicolor refinish...maybe a vinyl material similar to vroom's cupholder write-up.
kevin
StandardProspect
Online
'93 240sx '98 Q45
Delafield WI
2-14-2008
 « Re: (diggles240)
Quote, originally posted by diggles240 »
kevin
it is a very light wight material, very soft. it feels just like my puppy
im not sure of the exact name of the material, but walmart has it. it feels like felt and its strechy.
$4.66
per yard
I would like to see it done in vinyl good luck
S13xCrazy
1993 240sx Vert, 1986 Nissan D21 4x4, 1993 BMW 325i, 2000 Ford Taurus
Dousman WI
10-8-2006
 « Re: (bjohnson)
Just dont buy a yard and a half...
6.66...
we found it out the hard way.
Looks good bryan! Let me know how it holds up, I might be switching materials though. I have a feeling this stuff is going to pic up all the lint possible.
But who knows!
P.S.
someone should come and fix my truck...
or give me a hint on what else could be wrong
http://forums.nicoclub.com/zerothread/347267
93 240 vert project - GT28 turbo, FMIC, SSQV bov, 370cc injectors, e-mance tune, meth injection, 3" exhaust and much much more.
Quote, originally posted by ILoveMyRHS13 »
Lets do some math! YAY!
4k worth of eBay parts + shop doing your swap = COCK PICTURES!
StandardProspect
Online
'93 240sx '98 Q45
Delafield WI
2-14-2008
 « Re: (S13xCrazy)
Quote, originally posted by S13xCrazy »
6.66...
But who knows!
YES! we shall wait and see
Goldeneagle
1992 240sx Coupe
Newark Texas
6-11-2006
 « Re: (bjohnson)
Quote, originally posted by bjohnson »
You are correct, the door panel does not come a part. However you can remove the trays at the bottom of the door panel.
Other than that, I believe he was trying to say it may be easier if we take the door panel off of the door frame.
Pay off your mortgage in a fraction of the time!
Need FSM? Click here to download a copy
Old FAQs
livinglegend2100
93' ka-t hatch, 86" FC
elk river mn
2-8-2008
very nice. looks good. i definately need to do this... removed all the nasty old tweed **** and most of the adhesive, but just cant get all of it off...
krazydriver
2002 civic ex, 1993 KA-T 240sx - parting it out...
Middle of Nowhere NY
2-8-2007
 « Re: (livinglegend2100)
wow that came out looking good.
I'd recovered my glove box with black vinyl in my s13, i've been meaning to do the doors as well but haven't gotten around to it yet.
Buy my stuff! Here!
Soravia
1991 240SX Coupe 1992 240SX SE Coupe 2003 SE-R Spec V
Jacksonville FL
11-18-2005
Thanks for the writeup. I have one S13 with ruined interior.
This might even work on the cracked HUD Dash!
1991 240SX Coupe all stock - Wrecked.
1991 240SX Coupe VQ30DE project - Sold.
1991 240SX Coupe Celica front seats - Sold.
2003 SE-R Spec V - Sold.
2004 RX8 Sport - Sold.
Next pick - IS300 or G35
S13xCrazy
Dousman WI
10-8-2006
 « Re: (Soravia)
Quote, originally posted by Soravia »
It probably would, just make sure you get a flexible enough material. Otherwise you are going to have a hard time getting no wrinkles.
Our goal when looking for the right material was simple...we needed it to stetch.
srpowered240sx
Shocker Style
90 240sx-sr, 92 F-150, 96 integra gsr
humboldt county ca
6-29-2005
looks nice and clean. i was going for the crazy approach.
When did I realize I was God? Well, I was praying and suddenly realized I was talking to myself.
NICO photo contest crew..........three, count em, three times
Proud Creator of WBDM2TTWFOC: Cuz selling is for pussies!!
Xdisaster240sX
Undecided
S13 Hatch
Baltimore MD
10-25-2006
 « Re: (srpowered240sx)
Nice write up. I could use this when I do mine. Thanks
MY S13 build ---> http://forums.nicoclub.com/zerothread?id=447971
amolao
Old Guys Rule
Online
1989 Hatchback (the first one...)
Alabama
11-25-2003
 « Re: (bjohnson)
Black felt. Same material I use with excellent results. Years later is still holding great.
Operation: Extended Storage
HUD repair step by step, door panel upholstery how-to, and other 240sx tutorials
NICO/240SX BEST RUNNER UP NOPI 2006 AWARD
NICO RIDE OF THE MONTH DECEMBER 2006
StandardProspect
Online
'93 240sx '98 Q45
Delafield WI
2-14-2008
 « Re: (amolao)
VERY NICE!!!
that looks great
im glad to hear it held up, thats the only thing i was curious about.
FlatBlackIan
Lumberjack Moderator
S13 Chuki, S13 Zenki, A34 Maxima, 1983 C10 pickup.
Creepy cabin in the woods MN
12-23-2004
 « Re: (bjohnson)
Looks great. Ive been meaning to do this to my Integra, the fabric is all torn and bubbling. I would do it on the S14 as well, but its fine as of yet and Ive got too many projects already.
>>S13 240SX rally car buildup<<
"If in doubt, flat out" - Colin McRae
StandardProspect
Online
'93 240sx '98 Q45
Delafield WI
2-14-2008
 « Re: (FlatBlackIan)
Quote, originally posted by FlatBlackIan »
there is an integra specific write-up floating around here somewhere, i found it searching a while back
good luck
fallingjetengine
1992 240sx Convertible
Woodbury MN
7-27-2008
 « Re: (StandardProspect)
Hey guys. I have a convertible. and i started to rip off the tweed, but i couldn't manage to finish. The tweed is stuck on there soo bad! And now some parts are off the rest's still on and it looks like crap.
Does anyone know an easier way to remove it?
Or maybe where i could get some inserts?
-Nicolas
MastaYu
92 240SX HB SE
MD
10-3-2007
 « Re: (fallingjetengine)
it looks good
Shift_up
My S13 Ressurection/Rebuild
donjuanmon
'90 Space Gray Metallic 240sx, '05 Carbon Silver 350Z
Memphis TN
7-10-2005
 « Re: S13 Doorpanel write-up (StandardProspect)
Thanks for sharing. It looks great!
I'm thinking about doing something like this...well that's once I'm successful at finding a driver-side power window door panel.
l2efused
'93 Nissan 240sx
Kitchener Ontario
4-24-2006
 « Re: S13 Doorpanel write-up (donjuanmon)
yes this looks awsome.. soon going have to attempt this to somewhat complete my interior with my leather steats.
brad
Dead Serious
90 240sx hatch
Palm Beach Gardens FL
4-26-2008
very nice........that kind of work is in high demand down here in palm beach
forced induction & weight reduction
s13gebala
Chicago il
4-15-2008
sadly, i used suade, and forgot a blow drier lol.
i ended up with some creases
2g00d4u
OC ca
7-27-2008
DID YOU SPRAY OVER THE FABRIC OR SPRAYED THE DOOR PANEL AND PUT THE FABRIC ON?
White Comet
type x fanboi
fc, s13 and mazda3 (owned!!1!)
lancaster Pa
6-15-2006
Quote, originally posted by donjuanmon »
i have a spare one sitting in my closet
door panels
Quote, originally posted by Logan76 »
I swing it around like a helicopter and all the ladies want to go for a ride.
Quote, originally posted by mrgreeneyes »
sorry i cant satisfy you, jeff
