S13 Doorpanel write-up
StandardProspect
Car: '93 Nissan 240SX
'98 Infiniti Q45
I got sick of my doorpanels being rough and not comfy so i decided to try my hand at recovering them. i thought it turned out really well. much better than i ecpected.
i love the material i picked out. it is almost a felt-like material and it is easily strechable, which is very important for this diy project.
I bought 1.5 yard of this doubleovered material at walmart for $6 and a can of elmers craft spray glue for $5
Cost: $11Time: 1 hour, but take your timematerials: fabric of your choice, spray glueTools: Screwdriver, razor blade, blowdrier or heat gun, and scissors
If you havent removed the tweed from you door panels yet this is the first thing you should do. here is a link to the write up for that.http://www.nicoclub.com/articles.php?id=175775
Heres all the stuff i used
This is what the door panel looks like with the tweed removed
start by removing the handle trim, holy sh*t handle etc.
next, cut enough material for it to be draping over your door panel. (it will be a lot easier if you do this instead of trying to hold it up while gluing)
start spaying glue in the middle of the door panel and continue to glue arount the holes for the parts you must put back on. smooth out the fabric and make sure there are no creases.
now, using the razor blade, cut a hole for the little handle thing and put the handle thing back on. (this will help keep the fabric in place)
then the holy sh*t handle
and then the handle/lock trim
now you are going to need the blow drier/heat gun to heat up the material to make it more strechy and easier to work with. after heating, glue the area with the large curve making sure there are no creases in the fabric. (this was surprisingly easy with the material i used)
once all the fabric on the panel is glued down for the most part you can trim the fabric smaller so its easier to work with the edges.
the next part can be sort of tricky. do some fine trimming with the razor blade and leave about a centemeter of fabric from the crevas in the panel. you then tuck the fabric into the crevas while using a small amont of srpay glue on the very edge.
continue tucking in the fabric around the entire panel
once you are done with that, the door panel is ready to go!i love the finished product. this is my favorite diy interior project so far.using the same material i also recovered my glovebox, padded my armrest, and made shift and e-brake boots. it gives your interior a much classier look and feel. i will post pics of my interior once enverything is complete.
GOOD LUCK
s13gebala
Car: 99 Nissan Maxima
91 Nissan SR hatch
not bad, but i think if you would take apart the door panel it would be much easier
StandardProspect
'98 Infiniti Q45
as far as i know i dont think it comes apart. you mean remove the door panel and do it on a flat surface?
BMAR240SX
Car: 1993 Nissan 240S Coupe
Sexy
madmeg323
Beautiful.
diggles240
Car: 1996 240sx SE
2005 Altima 2.5S
looks good man. what is the material that you used- weight, etc.? i am considering something like this in lieu of the duplicolor refinish...maybe a vinyl material similar to vroom's cupholder write-up.
kevin
StandardProspect
'98 Infiniti Q45
diggles240 wrote:looks good man. what is the material that you used- weight, etc.? i am considering something like this in lieu of the duplicolor refinish...maybe a vinyl material similar to vroom's cupholder write-up.
kevin
it is a very light wight material, very soft. it feels just like my puppy im not sure of the exact name of the material, but walmart has it. it feels like felt and its strechy.
$4.66per yardI would like to see it done in vinyl good luck
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Just dont buy a yard and a half...6.66...we found it out the hard way.
Looks good bryan! Let me know how it holds up, I might be switching materials though. I have a feeling this stuff is going to pic up all the lint possible.
But who knows!
P.S.
someone should come and fix my truck...or give me a hint on what else could be wrong zerothread/347267
StandardProspect
'98 Infiniti Q45
S13xCrazy wrote:Just dont buy a yard and a half...6.66...we found it out the hard way.
But who knows!
YES! we shall wait and see
Goldeneagle
Car: 1992 240sx Coupe
bjohnson wrote:as far as i know i dont think it comes apart. you mean remove the door panel and do it on a flat surface?
You are correct, the door panel does not come a part. However you can remove the trays at the bottom of the door panel.
Other than that, I believe he was trying to say it may be easier if we take the door panel off of the door frame.
livinglegend2100
very nice. looks good. i definately need to do this... removed all the nasty old tweed **** and most of the adhesive, but just cant get all of it off...
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
wow that came out looking good.I'd recovered my glove box with black vinyl in my s13, i've been meaning to do the doors as well but haven't gotten around to it yet.
Soravia
Car: 2003 Audi A4 1.8T
Thanks for the writeup. I have one S13 with ruined interior.This might even work on the cracked HUD Dash!
S13xCrazy
Soravia wrote:Thanks for the writeup. I have one S13 with ruined interior.This might even work on the cracked HUD Dash!
It probably would, just make sure you get a flexible enough material. Otherwise you are going to have a hard time getting no wrinkles.
Our goal when looking for the right material was simple...we needed it to stetch.
srpowered240sx
Car: 90 240sx-sr, 92 F-150, 00 bmw 323ci, 1991 s13 coupe, 99 F250 Dsl
looks nice and clean. i was going for the crazy approach.
Xdisaster240sX
Car: S13 Hatch, R32 GTS4
Nice write up. I could use this when I do mine. Thanks
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
Black felt. Same material I use with excellent results. Years later is still holding great.
StandardProspect
'98 Infiniti Q45
VERY NICE!!!that looks greatim glad to hear it held up, thats the only thing i was curious about.
IanS
Car: 2002 Subaru WRX, 2010 Subaru Forester XT, 2004 Infiniti G35 Coupe.
Looks great. Ive been meaning to do this to my Integra, the fabric is all torn and bubbling. I would do it on the S14 as well, but its fine as of yet and Ive got too many projects already.
StandardProspect
'98 Infiniti Q45
FlatBlackIan wrote:Looks great. Ive been meaning to do this to my Integra, the fabric is all torn and bubbling. I would do it on the S14 as well, but its fine as of yet and Ive got too many projects already.
there is an integra specific write-up floating around here somewhere, i found it searching a while backgood luck
fallingjetengine
Car: 1992 240sx Convertible
Hey guys. I have a convertible. and i started to rip off the tweed, but i couldn't manage to finish. The tweed is stuck on there soo bad! And now some parts are off the rest's still on and it looks like crap.Does anyone know an easier way to remove it? Or maybe where i could get some inserts?
MastaYu
Car: 92 Nissan 240SX SE HB
it looks good
donjuanmon
Car: '90 Space Gray Metallic 240sx, '05 Carbon Silver 350Z
Thanks for sharing. It looks great!I'm thinking about doing something like this...well that's once I'm successful at finding a driver-side power window door panel.
l2efused
Car: '93 Nissan 240sx
yes this looks awsome.. soon going have to attempt this to somewhat complete my interior with my leather steats.
Dead Serious
Car: 90 240sx hatch
very nice........that kind of work is in high demand down here in palm beach
s13gebala
91 Nissan SR hatch
sadly, i used suade, and forgot a blow drier lol.
i ended up with some creases
2g00d4u
DID YOU SPRAY OVER THE FABRIC OR SPRAYED THE DOOR PANEL AND PUT THE FABRIC ON?
White Comet
Car: fc, s13 and mazda6, Sierra
donjuanmon wrote:Thanks for sharing. It looks great!I'm thinking about doing something like this...well that's once I'm successful at finding a driver-side power window door panel.
i have a spare one sitting in my closet
