driverdriver
NICO's longtime resident Canuck!!!
Toronto, Canada
8-1-2003
I'll post the first DIY article (courtesy of gr8scott72)Changing the fuel filter Fuel filter is located on the passenger side of the engine inbetween the engine and the shock tower. Steps: 1. Unscrew the clamp that hold the filter in place. 2. Unscrew the two hose clamps, one on each end of the filter. 3. Remove hose from both ends of filter. 4. Installation is opposite of removal. Make sure filter is oriented the right way when installing.
puck
1997 Infinity J30
Cincinnati OH
8-13-2006
| « Re: (driverdriver) | 6:45 AM 6/10/2007 |
To change the fuel filter, the fuel pressure should be released first. I would include those steps before actually removing the pump for safety reasons and to prevent an avoidable mess.Releasing fuel pressure: 1. remove the fuel pump fuse, located under the hood towards the front of the car on the passenger side - the fuses were labeled. 2. start the car and let it run until it stalls. 3. Turn the engine off. 4. clamp the line coming from the gas tank / fuel pump (when I replaced mine I still had fuel running out the line and it was easy enough to just clamp the line.) fuel filter Steps (from above): 1. Unscrew the clamp that hold the filter in place. 2. Unscrew the two hose clamps, one on each end of the filter. 3. Remove hose from both ends of filter. 4. Installation is opposite of removal. Make sure filter is oriented the right way when installing.
final couple steps: 1. remove extra clamp from fuel line (if used in the begining to prevent run off as I did) 2. Replace fuel pump fuse
That's all I can think of Modified by puck at 2:59 PM 6/10/2007
Modified by puck at 3:00 PM 6/10/2007
97 Infiniti J30, 91k
yodawill2000
94 Infinti J30
Grand Prairie Tx
3-24-2005
Maybe vent the gas cap as well if you dont clamp the fuel line. Good point Puck.
Modified by yodawill2000 at 9:02 AM 6/10/2007
94 J30 w/180 K miles Dark green and sexah !!!
on41greyst
san diego ca
8-5-2007
| « Re: J30 Do-It-Yourself Work (driverdriver) | 5:04 PM 8/5/2007 |
I have a 1994 Infinity and the brake lights will not shut off.. need help
mechanicsvillej30
1997 Infiniti J30
Mechanicsville VA
8-20-2007
| « Tune-Up Questions | 11:44 AM 8/20/2007 |
Just bought a 1997 J30. Looking for information on how to tune it up. Have never changed the coil-over type plugs. Also need to know the gap for the plugs. Also looking for how-to info for setting the timing. Used to do it years ago on a VW beetle by turning the distributor. How do you retard and advance the timing on these things? THANKS-Anybody that can help or steer me somewhere. TC/Mechanicsville, VA
elan
BMW 328I, Had J30 95,
Toronto ON
5-8-2006
| « Re: Tune-Up Questions (mechanicsvillej30) | 9:04 AM 9/13/2007 |
mechanicsvillej30 there is nothing special about changing the coil over plugs. Here is the sequence - Disconnect the wiring from the coil - unscrew the coil - pull it out gently - unscrew the plug, you will need a wrench with a long extension to reach the plugs. - put everything back in the opposite order. you do not need to know the gap as you never adjust it given you use recommended NGK Double Platinum which is stock and they pretty last their life of 60kmiles. The use of others is not recommended as people report problems. Though I was using Denso Iridium in mine - they were working OK. NGK DP are about 18 CDN retail in Canada and 12USD in the US per piece.
mechanicsvillej30
1997 Infiniti J30
Mechanicsville VA
8-20-2007
| « Re: Tune-Up Questions (elan) | 9:14 AM 9/13/2007 |
Thanks! TC
idcp
J30
columbia sc
10-2-2007
| « Re: Tune-Up Questions (elan) | 1:02 AM 10/2/2007 |
I have been using bosch platinium 4s, in my j30 for about 6 months now. they seem to do just fine.If you ever need a write up of how to replace the alternator, in a j30 i could do that, i have had mine in and out probably 5 times. The first time was hard but, now i can do it rather quickly. Also a high preasure power steering hose is a common problem, yet somewhat difficult to remove and reinstall. yet it is possible to do with little or no tools. The real thing about the j30s is they alway leave just enough room to do things on the j30. you may have to wiggle the part in, and turn in around 20 times before you find the perfect combination of angles. but there is a way.
Gerardjg
1995 J30t & 1997 J30
Deltona Fl
1-24-2006
| « Re: J30 Do-It-Yourself Work (driverdriver) | 8:19 PM 10/22/2007 |
Here is a How to on the drivers door control panel Bulbs http://home.cfl.rr.com/dandgsystems/J30.htm And the Passenger door bulbs are basically the same Just turn the switch over and remove the bulb holder with a pair of tweezers, it is replaced similar to the instructions above just a longer post. Here is a how to for the bulbs in the heated seat switches http://home.cfl.rr.com/dandgsy...t.htm
j3097inf
97 infiniti j30
rosharon tx
11-27-2007
| « Re: Tune-Up Questions (mechanicsvillej30) | 3:48 PM 11/27/2007 |
hey do you think you can send me a copy the fuse box diagram?...the one below the steering wheel
Gerardjg
Deltona Fl
1-24-2006
| « Re: Tune-Up Questions (j3097inf) | 2:57 AM 11/28/2007 |
| Quote, originally posted by j3097inf » | | hey do you think you can send me a copy the fuse box diagram?...the one below the steering wheel |
YHEM
chicteenager
Madison WI
12-9-2007
| « Re: (puck) | 6:59 AM 12/19/2007 |
Hi Puck,Thanks for the posting the instruction on how to replace the fuel filter. I tried replacing my old fuel filter (1997 Nissan Sentra) but could not remove the old fuel filter from the tubes that attach to it. Do you have any idea on what i should do? My friend suggested that I cut the tube and replace it with a new one. What do you think? Any help is greatly appreciated. Thankss!!
puck
1997 Infinity J30
Cincinnati OH
8-13-2006
| « Re: (chicteenager) | 7:06 PM 12/19/2007 |
Those lines were next to impossible to pull off. I think I did eventually pull one off. I decided it wasn't worth the effort on the opposite side so I used a razor to put a slit in the side of the line. That loosened the line enough to easily pull the filter out. I just cut off the part of the line I put the slit in. There was plenty of extra line on each side to do this on my J30. I can't speak for a Sentra, however.
naladude911
2001 Infiniti QX4
mt.kisco ny
10-3-2006
umm, changing your parking lights. I made powerpoint on how to do it, but I dont know how to upload it onto NICO
 NALADUDE911 Check out my cardomain! http://www.cardomain.com/ride/3392312
hpedolzky
1995 Infinity J30
Floyds Knobs Indiana
2-7-2008
| « Re: J30 Do-It-Yourself Work (driverdriver) | 5:21 PM 2/7/2008 |
Headlight relay repair.Just purchased 1996 J30 (great condition, low mileage). entire passenger ligths were out. Did some research, told me the headlight relay was probably dead. Looked for relay for approx. 45 minutes, it is not in the relay/fuse compartment on the passenger side inside the engine compartment. It is located inside the drivesr side engine compartment by the firewall, secured by 1 11mm screw. Once I found it, it took only about 5 minutes to get it out, very tight fit. It has 2 locked plugs, which can easily be removed with a slotted screwdriver. Once you have the relay out, gently remove the bottom cover, I had to break some of the lip to get it separated. The bottom then slides out and you have a small circuit board with 4 relays on it. Resolder all relay connection (mine had one bad connection on the main RH light relay). I plugged the relay back in and tried all the lightsm before I put the circuit board back into the top, snap the bottom back, then seal the bttom with any waterproof seal. Getting the relay back into postion was a little harder, since the wires are about 2 inches to short to make re install easy, but it can be done. Be sure, the 2 plugs snap securely into place and re mount the relay. Good luck!
Listof7
1993 J30t
Las Vegas NV
1-27-2008
| « FRONT BRAKE PADS | 7:50 PM 2/8/2008 |
This is an easy maintainence job which can be performed alone or with a buddy to keep you company. Difficultly level is comparable to an oil change. Time is 30 minutes to 2 hours depending on skill level and if you chose to waste time being angry. Have all items ready before starting. TOOLS: Eye Protection & Gloves are a good idea 4" C-clamp (6" is ok also) Jack (& Stands if you gott'em) Wheel Blocks (Brick works ok) Lug-Wrench 14mm socket hammer or malet may come in handy Bungy Cord PARTS: Brake Pads ($25-$35 aftermarket) Some Brake Lube (not a live or die item, but a good idea $3) Maybe brake fluid ($3) STEPS: 1:Make sure you're on a level surface 2:Block the rear wheels 3:Remove center caps from wheels 4:Before jacking up, break the lug nuts loose using a star pattern (start with any one, then go to the next one in order as if you're drawing a star) 5:Properly place jack and raise car. (If you have them place stands now, if not, once you remove the tire, place it under car, without removing jack, as a emergency catcher) 6:Completely remove lug nuts and wheel 7:Inspect and remember how this looks for replacement later. There should be a large "device" at 2 O'clock on the rotor, this is your caliper and your pads are held by this assembly. 8: Find and remove the two 14mm bolts which are accessed on the back of the caliper. You'll know you have the right ones because of their size and they should have a rubber boot connected to them. When you do the top bolt, there is a hose, attached, LEAVE IT ATTACHED, just move it gently out of your way. Once bolts are out, leave caliper for now. (Bolt removal may require a few taps with the hammer to your ratchet, to break them free)
9:Wrap the bungy cord around the springs on shocks, leave some slack, you'll use this to help hold the caliper for you while you work 10:Now remove caliper. If the caliper doesn't remove easily, tap it LIGHTLY with the hammer and then remove it. 11:Hook the bungy threw the bolt holes on calipers. 12: Open hood and loosen brake fluid lid. You will have some brake fluid over flow when you compress the pistons, this is normal. Remember to re-tighten lid before using brakes. 13:On the caliper, you'll see 2 pistons. Using the C-clamp, do one piston at a time. Place the stationary end of the C-clamp on the back of the caliper and the moving end on the end of the piston. Now compress the piston (tighten C-clamp) until it stops completely. The reason you do this is because the piston has self adjusted to compensate for the worn out pads, the new pads will be thicker and unless you re-compress the pistons, you'll never get the assembly back together. 14: Now wiggle the pads free and place them on the ground in a way which gives you a clue as to how and where they came off from. When you wiggle them free, just use common sense to not damage anything. You'll kinda tilt the outside pad and bring it out, the back pads seems to come almost straight out. remember the angles that get them out so you can reverse that to re-install the new pads. 15:Blow away any pieces of crud and excessive dust 16: Follow lube instruction if you're using it. ***DO NOT LUBE THE PAD ITSELF OR THE ROTOR!!! Brakes require friction to works--of course--and lube reduces friction.*** 17: Replace pads, the back pad has the clip/tit/nipple thing but you already know that because you remembered how they came out 18: Replace caliper. If caliper doesn't go on fairly easy, something is wrong, most likely the pistons need compressed further. Once caliper is in place, bolts should thread easily and be tightened tightly, but not stripped. 19: re tighten brake fluid lid 20: Without getting in the car, open the door, turn it on, press brake peddle with your hand to do a preliminary test before replacing wheels. Pump it a few times, once it has full pressure you may notice that the peddle doesn't go down as far = thicker pads require less travel. 21: Put the wheels back on, then using the star pattern -- hand tighten the lug nuts as tight as your hand will do. You will need to wiggle the wheel a little to get it snug as you go. Once the wheel can't wiggle anymore and the lugs are very hand tight. Slowly lower the car. Once it's on the ground finish tightening the lugs with your lug wrench. Leave center caps OFF. 22:Carefully/slowly drive and test brakes. If they fail you will calmly USE YOUR E-BRAKE peddle to stop -- just as you would if your brakes failed any other time. 23: re-check the lug nuts to make sure they're all tight and replace center cap
24:Put away all your tools in order and clean up any mess. (Make this a habit ) 25:Pat yourself on the back, this is when you have your beer. Consider a few things... Are the old pads you took off NISSAN brand? If so, this may indicate the previous owner preferred factory service and/or parts. GOOD Did you notice how the rotor shifted in place once you stared taking this apart? Well, only 2 more bolts -- located on the back side of brake assembly and it FALLS off in your hands. Not to hard to replace rotors now that you've been in there.
Modified by Listof7 at 9:24 PM 2/9/2008
Ceation Begins In Our Imagination...
driverdriver
Toronto, Canada
8-1-2003
Some nice informative write up guys. I'm very impressed. Keep em coming.naladude911, do you just have a simple write up regarding changing parking lights? Let me know and I'll fire you off an email.
crossbones668
1994 infiniti J30
Cary NC
2-11-2008
| « Re: J30 Do-It-Yourself Work - PCV valve Replacement | 1:23 PM 2/11/2008 |
The J30 has two PCV valves. One is located on each side of the intake manifold, located about halfway back, and screws directly into the plenum.This is a simple job that requires a little muscle. You will need a 19mm deep socket, a 4" extender, a socket wrench, a large blade flathead screwdriver, and two PCV valves. An optional tool is a 45-degree needle nose pliers for the hose clamps. Three basic problems are that the PCV valves tend to stick fast in the plenum and take some muscle to break loose; the flexible PCV house at the rear ends of the valves are short and hard to get on and off; and the PCV valve on the drivers side cannot be removed without freeing the adjacent wiring harness from the three clips that hold it in place. Important things to remember before finishing the job: 1) Reconnect the ground cable on the drivers side, 2) Reconnect the wiring harness clips on the drivers side. Loosen the hose clamp behind the valve and slide back. Inspect hose for dryrot. Use the side of the flathead blade to slide the hose off the valve. Unscrew the valve, trying to get the wrench action behind the trailing edge of the manifold. On the passenger side, mind that you don't bang the lines in that area. Replace the PCV valve. Reattach the hose and reseat the clamp. Proceed to the other side and repeat. Note that the thread body will not screw all the way into the plenum, and should not be forced. Note that nothing should ever be screwed into or unscrewed from a hot piece of metal.
infinitirydah
1996 Infiniti J30
St.Pete FL
2-25-2008
| « Re: J30 Do-It-Yourself Work (driverdriver) | 9:32 AM 2/25/2008 |
im trying to figure out how to replace the alternator V belt, but i cant figure out how to, any help or advice appreciated.
rclem7
1995 Infinity J30
Bloomingdale GA
2-22-2008
| « Re: J30 Do-It-Yourself Work (infinitirydah) | 11:39 AM 2/27/2008 |
Belt Replacement:I will try and explain as best I can since I just did this a week ago. You will have to start by removing the intake tubing, and the two radiator hoses. This will open up the top of the engine and allow you to work. There are three belts on the car, and of course the one you want to replace is the hardest to get to. You will need to loosen up and remove all the belts. The compressor belt has a tension pully on it. You will need to loosen the nut on the face of that pully, then loosen the bolt pointing down, and that will loosen the compressor belt. The power steering belt will be removed by loosening the pump itself. In similar fasion, there is a bolt on the lower side of the pump that will need to be loosened. There is a nut on the back side that locks the tension bolt that will need to be loosened, then loosen the tension bolt. You may have to loosen a bolt on the top side of the pump to get it to swivle. Next you will do the same to the alternator. Loosen the nut on the back side of the tension bolt, then loosen the bolt. I also had to loosen a mounting bolt above the alternator to get it to swivle as well. Once you have the alternator belt loose, you can remove the fan by removing the four bolts on the face. I just was able to get it out the top and out of the way. I don't know if there is an easier way or not, but be very carefull when doing so as not to damage some wires or the timing belt housing. You might even consider loosening the alternator belt first so that you can get the fan out of the way as one of the first steps. Replace the belts. Would be a good idea to inspect the other ones too since you will have them off. They're not that expensive. Reassemble in reverse order. Just be sure that the alternator belt is the last one you tighten since you will have to replace the fan. It took me about 2 hours to complete the job, but I went into it blindly since I just bought the car.
rclem7
1995 Infinity J30
Bloomingdale GA
2-22-2008
| « Re: J30 Do-It-Yourself Work (rclem7) | 7:09 PM 3/3/2008 |
I found this link in another post and found much of it useful. Just thought I would share. Lots of DIY stuff and diagrams.http://www.fuzzycats.com/j30.htm
atowersmusic
93 Infiniti j30 leather loaded
raleigh nc
3-5-2008
| « Re: (driverdriver) | 5:48 AM 3/5/2008 |
thanks for the work and help you are given us
atowersmusic
raleigh nc
3-5-2008
| « Re: J30 Do-It-Yourself Work - PCV valve Replacement (crossbones668) | 5:49 AM 3/5/2008 |
that answers a lot of my questions thanks glad i found this section
mad1sdaddy
1994 Infinity J30
Calcium ny
1-17-2008
| « Re: J30 Do-It-Yourself Work (driverdriver) | 3:05 PM 3/5/2008 |
looking for any tips on ease of extraction for the o2 sensor on a 94. why couldnt nissan have put it on the passenger side exhaust, there is so much more room on that side.
Gerardjg
Deltona Fl
1-24-2006
| « Re: J30 Do-It-Yourself Work (mad1sdaddy) | 1:55 PM 3/11/2008 |
| Quote, originally posted by mad1sdaddy » | | looking for any tips on ease of extraction for the o2 sensor on a 94. why couldnt nissan have put it on the passenger side exhaust, there is so much more room on that side. |
There is one on the passenger side Soak the threads with PB Blaster for a couple of hours + invest 10 bucks on a O2 sensor socket, I did them a while back so I do not recall the exact procedure. SEARCH it is posted here somewhere.
infinitirydah
1996 Infiniti J30
St.Pete FL
2-25-2008
| « Re: J30 Do-It-Yourself Work (rclem7) | 11:13 PM 3/11/2008 |
thanks a lot for all the info, replacing that belt is a b***h, but it should be a lot easier now that i have somewhat of an idea of what im doing.
elche1
j30
north babylon ny
9-10-2007
| « Help with 1995 j-30 | 12:35 PM 3/20/2008 |
I have 2 questons:1) Does anyone know how to disconnect the alarm system or bypass the system? 2) My J-30 1995 cranks but dosn't start. The Sparks are good, and fuel pressure is good also. Where can I go from here. I think it might have something to due with the alarm . I get no siren or horn on the security system.
crossbones668
1994 infiniti J30
Cary NC
2-11-2008
| « Re: Help with 1995 j-30 (elche1) | 7:08 AM 4/8/2008 |
Try replacing the fuses, and check the coils, water in the distibutor, etc.
j30t_Dan
2009 Nissan Sentra SE-R
Edmonton AB
4-15-2008
thanks so much guys
2009 Nissan Sentra SE-R CVT 1993 j30t R.I.P
gr8scott72
1994 Infiniti J30t
Brandon MS
2-16-2006
| « Re: Help with 1995 j-30 (crossbones668) | 10:54 AM 4/19/2008 |
| Quote, originally posted by crossbones668 » | | Try replacing the fuses, and check the coils, water in the distibutor, etc. |
water in the what?
Scott2000 Ford Excursion XLT 4x4 V10 4.30:1 gears - 162k miles - Hawk SuperDuty front/rear pads, Powerslot slotted rotors up front, Optima Red Top Battery 2000 Dodge Durango SLT 2wd 5.9L V8 - 111k miles, rebuilt tranny w/ shift kit, 4.56:1 gears, added leaf springs, Bilstien HD shocks, Hawk SuperDuty front pads, Optima Red Top Battery 1994 Infiniti J30t - 212k miles - sold
coachdave
j30 1995
oviedo fl
5-20-2008
| « Re: Help with 1995 j-30 (elche1) | 9:07 AM 5/20/2008 |
| Quote, originally posted by elche1 » | | I have 2 questons: 1) Does anyone know how to disconnect the alarm system or bypass the system? 2) My J-30 1995 cranks but dosn't start. The Sparks are good, and fuel pressure is good also. Where can I go from here. I think it might have something to due with the alarm . I get no siren or horn on the security system. |
I have this same prob.
Here is what happened. Car would not start, tried jumping it, nothing. All electric works (as a matter of fact the radio worked for the first time in forever). Someone told me it might be Neutral Safety Switch. So i put car in Neutral and it turned right over. After this every once in a while it would not start, i would put it in neutral, wiggle it a little and it would start. One time nothing i did would get it to start, so i left it overnight where it was and went back next day and thought i would try it and in neutral it turned right over. Got it home, but now it wil not start at all. Again all electric works no prob, just wont start. At this point i am assuming it is this Neutral Safety Switch. Is this something i can DIY? Where can i get info on doing this work? I see that some people are saying check fuses. Should i do that?? Any help would be appreciated. Thanks, Coach
roastduck88
1994 J30
SF CA
5-30-2008
| « Re: Help with 1995 j-30 (coachdave) | 8:53 AM 5/30/2008 |
There's a orage wire underneath the Driver side dash that is attached to the Theft warning module (I beleive it's a silver box underneath the dash). Ground that orange wire and you will see your security light shut off instead of flashing. If the light continues to flash then you either didnt' ground it properly or you have the wrong wire.
craze K
94 infiniti J30
Mechanicsville PA
7-19-2008
| « Nice descriptions | 2:52 PM 7/22/2008 |
This site is great. I bought my parts from everythinginfiniti.com that I needed for my fix. Now all I have to do is give all this great info to my friend so he can replace the parts. Thank you to everyone.
Modified by craze K at 12:35 PM 7/23/2008
driverdriver
Toronto, Canada
8-1-2003
Removing J30 shift knob:Directions courtesy of Deathdealer Alright, I have searched about everywhere to find out how to remove the stock shift knob on the automatic transmission so I could put a custom one on without breaking something. Now, I'm going to share my knowledge if there are any others like myself. It's obviously very simple, but if you're a bit cautios like me then you probably don't want to attempt it without knowing for sure what to do. I have found alot of opinions from people about how to remove it, but noone that had experience doing it. Step 1: We'll have to remove the unlock button that you have to push down to shift out of neutral and park. To do this, stick a flathead screwdriver, or something of that nature, between the button and the shifter on the side facing the back of the car. Do not try to remove the inner, plastic trim around the button. Push down ion the tool and pry the button up. You shouldn't have to apply much pressure to do this, so if you're really trying to force it then you're probably doing something wrong and should stop and have a beer. Step 2: Once the button pops up and off, you'll see 3 screws. These aren't very important because they only hold down the plastic trim down. Step 3: Pull off the rod cap and spring - but make sure to keep them as you will probably need them for your custom knob. Step 4: You'll see a large bolt down in the middle of the knob. This is a bit awkward to get to, but I was able to unscrew it with needle-nose pliers. Unscrew it, pull off the knob, and there you have it! Piece of cake. I hope this helps!
Victor
1994 Infiniti J30T
Fullerton CA
4-6-2008
| « Re: J30 Do-It-Yourself Work (rclem7) Drive belt replacement procedure | 5:35 PM 8/2/2008 |
One of my drive belts is making a squealing noise when I first start driving that is getting worse. Just feeling how much slack is in the belts I think it is probably the alternator belt, since it seems to have the most play in it. I am trying to decide if I should pay someone to replace the three belts (I got a quote of $111.00 parts and labor for Gates belts), or is it something I can do myself. Or maybe I should just try tightening them, but it seems like almost as much work to tighten them as replace them. I just took a quick look but I have some questions about this procedure rclm7 was kind enough to post. 1. Is it really necessary to remove the radiator hoses? 2. Why is it necessary to loosen the alternator belt before removing the fan? Looks like it would be easier to work if the fan was removed first, but I don't know if the fan and pulley are one unit. 3. Can all the work be done from the top or is it necessary to put the car on a lift or jack stands to get to anything from underneath? 4. I can't even see any of the adjustment bolts shown in the FSM, so guess all the disassembly would be needed to just tighten the belts even if not replacing. 5. Is there any preferred brand of replacement belts, like Goodyear Gatorbacks, or would Auto Zone house brand be OK?
heynow775
1995 infiniti j30
temple ok
8-4-2008
i had to pull my1995 j30 with a dollie about 100 miles, it a auto trans. when i went to take it of the dollie it would go into reverse, when i got it offit only gose in drive, you can put it into nutral and its still in drive.you can put it into park and it wont rev. but it feels like its still in drive. what do you think
gr8scott72
1994 Infiniti J30t
Brandon MS
2-16-2006
| « Re: (heynow775) | 7:33 AM 8/5/2008 |
| Quote, originally posted by heynow775 » | | i had to pull my1995 j30 with a dollie about 100 miles, it a auto trans. when i went to take it of the dollie it would go into reverse, when i got it offit only gose in drive, you can put it into nutral and its still in drive.you can put it into park and it wont rev. but it feels like its still in drive. what do you think |
I think you should have put the drive wheels on the dollie.
graydragon
j30
louisville ky
2-7-2008
| « Re: J30 Do-It-Yourself Work (Gerardjg) | 5:58 PM 8/10/2008 |
did you notice an increase in your gas milage with your O2 sensors changed out? are there only 2? thanks.
gr8scott72
1994 Infiniti J30t
Brandon MS
2-16-2006
| « Re: J30 Do-It-Yourself Work (graydragon) | 9:04 PM 8/10/2008 |
| Quote, originally posted by graydragon » | | did you notice an increase in your gas milage with your O2 sensors changed out? are there only 2? thanks. |
OBD1 has only 2 O2 sensors (93, 94, 95). OBD2 has 4 (96, 97).
| First 1 2 > Last |
