SeVa-S13
240SX Moderator
RMS13
Chicago IL
1-23-2003
Lookin' good, but the turbine being that close = melted BMC. Heatshield o'clock.
WTF makes you think all caps is a good idea? DIAF.
lrb_2000
'91 SE s13 Hatch, '95 SE s14
ID
5-3-2005
yeah.. the other turbo was acually closer.. it had a larger 5 bolt pattern, which is guess is strange, i was hoping they'd be the same..
TheOne
93 240sx FB
Arlington TX
8-9-2004
so wait, you are swapping a GT35 for a T3 super 60?, isn't that 1 smaller? i guess you want faster spool?
93' 240sx fastback - 10.240 @ the local 8th mile."Horsepower sells cars, torque wins races" - Carroll Shelby "Horsepower is the force that determines how fast you hit the wall. Torque is the force that determines how far you take the wall with you after you hit it." - Unknown "Real cars don't make power at the front wheels....they lift them."
lrb_2000
ID
5-3-2005
noooooo... in my first post I said "the GT35 in place of the T3 Super 60" I guess the pictures could mislead you.
daconkiftador
Classified$ P0st Wh*re
'92 SE Coupe
Clarkston WA
1-14-2006
word^ son.
| Quote, originally posted by 95s-14 » | | I told my dad to quit being a PITA and take a vid of me doin a burnout in the driveway |
Florida240sx
93 Hatch 5spd 93 vert 89 hatch
DeLand FL
7-1-2004
What up with the t3 super 60? I'm interested
http://www.itsfunnyhoney.com/v..._time S14 for sale http://forums.nicoclub.com/zerothread?id=294220
 Megan Racing Parts supplier.Among many more companies Act, hks, b&m, sparco,msd,etc. hotrod6000000@yahoo.com KA-T why settle for anything less?
lrb_2000
ID
5-3-2005
I'm not sure. I want to get rid of it, but i'm not sure how much to ask. It should only have about 8k miles on it.
lrb_2000
ID
5-3-2005
| « Re: (lrb_2000) | 2:51 PM 3/23/2007 |
Well, I got my car running yesterday with the new turbo. It's a HUGE change.. full boost isn't until somewhere between 3500-4000 instead of like 2800 with the super 60. But it hits hard. I'm running 12psi... it feels a lot faster than with the other turbo, as was expected. I'm going to get some video tomorrow probably. I need to still move the p/s reservoir, and make my new hot pipe. As well as get my ecu tuned, so I can use my 810cc injectors and up the boost. But for now, it's running 12psi pretty good with 400cc injectors. Here's some more pictures. New filter
 a little dirty
 p/s reservoir is pretty close to the compressor
 Interior view
daconkiftador
'92 SE Coupe
Clarkston WA
1-14-2006
fuhqin bad ***!
jared36
89 240sx
Swansea/Belleville Illinois
12-20-2006
| « Re: KA-T GT35 Build.. cont.. (lrb_2000) | 9:08 PM 3/23/2007 |
Cant wait to see some new videos...your car is badass
lrb_2000
ID
5-3-2005
Thanks! I'll get some video today.So, one thing I noticed, which is probably normal.. I go out and tune during the day, and get perfect 12-12.5 afr at 12psi.. then I go out at night, when it's about 20 degrees cooler, and they hit like 13.5 afr.. is there any way around this with the SAFC II or do I just need to tune when it's cold out.. I'm getting my ecu tuned soon, but for the time being.. I drive during the day and night a lot.
nissanfanatic
1992 Nissan 240sx SE
Gainesville Fl
11-1-2004
You are probably maxxing the 370s if you are at stock fuel pressure..Try opening them up some, but I doubt you are going to get much more fuel out of them.. It shouldn't really lean out at night as the MAFS should read the additional air coming in and add fuel as necessary..
-Cory Street racing fatalities: 0.21% of total fatalities in motor vehicle crashes. FTC1992 Nissan 240sx KA24DE-Turbo: The "Showcar" Stock internals 532whp/486ft.lbs-30psi 12.6@122.3mph-22psi http://ka-t.org/cory_b.php
lrb_2000
ID
5-3-2005
I'm using 400cc injectors acually.. but i'm sure they're close to being maxed... My high throttle map is like:3400 +20 3800 +25 4200 +30 4600 +35 5200 +35 5800 +30 6200 +20 That got me pretty good afr's during 70 degree weather in the day time at 12psi. Then last night I went out, same tune, and it was bouncing from 13-14.5 afr @ 13psi.. so I turned it down to 10psi and it held pretty good around 11.5-12 ... so I don't know.. I don't know what I should do to tune. I have 810cc injectors just laying here, everything is ready to go. I'd like to up the boost to 15psi and acually get a decent tune instead of this safc. Tuned ecu seems the easiest route. I'd like to go with MS II but I don't think that would be a good idea for me. This is my first car that i've worked on. I've done all the work. I've never driven a turbo'd car, or a fast car for that matter. So this is quite the accomplishment for me so far. I just don't want to blow my **** up. haha.. if I do, I have a built motor waiting to go in.. as soon as I get my rods. So basically, what would anyone recommend I do for tuning? With a tuned ecu I wouldn't have to get it retuned with my new engine, because the only difference would be compression.
nissanfanatic
Gainesville Fl
11-1-2004
Yea I saw 400cc and 370 stuck in my mind when I was typing because 370's are close to 400s and I was guestimating that you are maxxing them.. Buy an ECU tune... It might not be 1337 hax like MS or any of the other DIY methods, but at least your car won't blow up.. Esp for the first setup, you need a good experience or you'll get out of Nissans..
hannibal
1990 Integra
Atlanta GA
9-11-2002
| « Re: (lrb_2000) | 1:47 PM 3/24/2007 |
I think Cory might be right about the injectors maxing out. They simply cant provide enough fuel to match the cool dense air at night.
the thread killa
lrb_2000
ID
5-3-2005
True. What ecu are you running, Enthalpy? I want to go that route, but i'd like to acually talk to someone before I place my order... to make sure i'm not waiting around forever.. how to I get ahold of Scott ? Or should I just order it and send my ecu and everything will be fine? I worry about stuff like that because i've had to wait so long on rods twice now, even though they said they were in stock.
Jookmasta
Miami, FL
4-18-2003
your car must pull like a freight train now when the boost hits. and i HIGHLY suggest that you get a heat shield for the turbo or get a piece of metal to block off the heat from the plastic reservoir. post up dyno figures when ur done as im curious to what ur making.............
It is cheaper to hook up your car than to have a girlfriend.........................  Brown Squad Member #19 ~ What can Brown do for YOU?
lrb_2000
ID
5-3-2005
Oh yeah.. I have a heat shield.. I just don't like to put it in the pictures, considering it's just a bent up licence plate :DBoost hits really hard.. it's weird at first, because you floor it, and it just kinda goes like stock then about 4k rpms it hits 12psi and you have to shift pretty much immediately, it's fun... As soon as I get my ecu, and put my new injectors in, in about 2 weeks i'm getting on the dyno and going to push about 15-18psi.. I hope my stock motor doesn't blow.. it's never been touched beyond the valve cover.
NateDogg
8-24-2002
I'd keep the boost at 10psi until you get the 810cc's in. Remember the closer to stoich (14.7:1 AFR), the hotter the burn and the hotter the piston gets. I think we all know what happens when a KA leans out and burns a piston (or four). Thats why I like to keep my AFR in the 11's on stock pistons, especially on pulls that last longer than 5 seconds.Also, since you arent doing anything for timing...ahem...you're asking for trouble !!! Proper ignition timing (retard) is more important for preventing detonation than having a rock solid AFR... Sounds like a pretty insane top end setup though. Good for highway pulls!
lrb_2000
ID
5-3-2005
I have my base timing at 16*BTDC to be safe.. so out of boost it feels a little slower, but i'd rather not blow it up... but i'm going to agree with you on the 10psi. I'm going to keep it there. Hopefully i'll order the ecu tune on monday. I need to do body work anyways.btw, check the link in my sig for a short video from last night... me doing a burnout and some little donuts, it was pretty wet out though.. :\ and a video of my friends STI doing some too..
Modified by lrb_2000 at 3:03 AM 3/25/2007
daconkiftador
'92 SE Coupe
Clarkston WA
1-14-2006
sweet vids!
lrb_2000
ID
5-3-2005
Here's some progress on the body work is anyone cares... I've never done body work before.. so it's taking me forever.. sorry I don't have a bunch of before pictures.. my wheels look like they have positive camber going on.. lol.
yes the front will be lowered... yes i have sideskirts.
lrb_2000
ID
5-3-2005
wild_maxx and I went out today and got a quick video. I'm only running 8psi since I don't want to blow the motor up...yet... This video is pretty much identical to the video I made with the super 60... and the car is probably just as fast, or faster at 8psi as it was at 12psi on the other turbo... here's the link, check my sig for the other videos. http://www.youtube.com/watch?v=8iTBgDaRNFQ
wild_maxx
89 240sx money pit
pullman WA
6-28-2004
| « Re: (lrb_2000) | 4:58 PM 4/7/2007 |
ahh good times... I told ya that my hands were shaking while I was filming.
http://www.putfile.com/sk8142"**** all these gun-toting Hip gangster wannabes" - Maynard J. Keenan
Edub1
Forum Sage
89 240sx KA-T
Detroit MI
11-10-2005
You guys should check out the GM stand alone thread. I know people make good power on Enthalpy tunes but I don't think there is anyone tuning ECCS that matches what these GM guys are doing.
American soldiers don't sign up to die for their country, they sign up to make the other poor son of a ***** die for his. Hoorah!
lrb_2000
ID
5-3-2005
| « Re: (Edub1) | 11:03 PM 4/8/2007 |
If I go with a stand alone, i'll probably go for megasquirt... here's my new hotpipe setup.. ditched the 2" steel crap for 2.5" aluminum and different route..
wild_maxx
89 240sx money pit
pullman WA
6-28-2004
| « Re: (lrb_2000) | 8:22 AM 4/9/2007 |
looks good. Have you driven it yet? Does it spool a bit sooner since the turbo outlet is no longer at a 90* angle right out of the compressor?
eazye2000
Booze Hound
of FAIL...
Hanscom AFB MA
6-27-2005
| « Re: (wild_maxx) | 12:56 PM 4/9/2007 |
You should move your Power Steering reservoir. I moved mine back in the corner by the brake master. Pic of mine is in my sig, but I'm gonna upload a better pic here if I can find it.
lrb_2000
ID
5-3-2005
ahh nice.. I probably will move it when the engine comes out. for now i just shortened the lines like 4" so it wouldn't be sitting against the compressor..no, i haven't driven it yet. I have to get the piece that connects to the intercooler welded.
lrb_2000
ID
5-3-2005
| « Re: (lrb_2000) | 4:26 PM 4/24/2007 |
Update time.. kind of. I finally got my Turbo240 rods in, which means my engine should be back from the machine shop next week. So i got started on tearing into my car again. We pulled tranny, drive shaft, and also dropped the rear subframe so I can get rid of this damn HICAS crap first. Then Shawn (wild_maxx) and I pulled the engine, tore it apart today so he could use the head/block for his KA-T build, didn't take us long at all. so here's a few pics. more to come as I clean things up and such. engine bay is super dirty and greasy.
 HICAS bull****
 No HICAS bull****
 pile of old stock parts, exhaust, random stuff..
PS. I lied about running 12psi. My gauge said 12psi, but I put a friends in and i'm acually running 8psi. My gauge was way off. So 8psi was basically maxing the 400cc injectors with the new turbo.
Modified by lrb_2000 at 5:13 PM 4/24/2007
daconkiftador
'92 SE Coupe
Clarkston WA
1-14-2006
Good luck cleaning that engine bay, gotta give the GT35 the respect it deserves, lol!
nelson8708
1989 Nissan 240sx Fastback
Sideways
12-14-2004
| « Re: (daconkiftador) | 2:37 AM 4/25/2007 |
Sparkler bombs are a good time. Your sparkler video was funny...."is it a big one?"
 KA24E-T boosted for two years now.
lrb_2000
ID
5-3-2005
haha.. yeah, they're pretty sweet..So I didn't get too much done today, I acually didn't really plan on doing anything, until I looked at the engine bay again and saw how ****ing dirty it is.. so I started cleaning it.. I got the fuse boxes and crap moved out of the way, and other random stuff.. and started going at it.. here's after about a half hour of cleaning it.. it's gross..
 hopefully tomorrow will be a much more productive day. I need to finish removing all the hicas stuff from the rear, and install my eliminator bar, and vlsd..
lrb_2000
ID
5-3-2005
| « Re: (lrb_2000) | 3:07 PM 4/26/2007 |
I finished cleaning the engine bay, and put back the fuse boxes and harnesses. It's pretty much ready for the engine to go in. before I started today..
 after cleaning
 after mounting fuse boxes and wires
 and the daily driver
Logan76
nOOb with PDS
2005 Saturn junk
Kittanning PA
3-30-2006
Dude, I love it, Love it to death, nice work so far.
no boost, no care.
wild_maxx
89 240sx money pit
pullman WA
6-28-2004
| « Re: (Logan76) | 4:15 PM 4/26/2007 |
^^^ dang he really loves it! The bay looks good man... any word on when the engine will be done?
Logan76
nOOb with PDS
2005 Saturn junk
Kittanning PA
3-30-2006
I like KA-T's for some reason...
wild_maxx
89 240sx money pit
pullman WA
6-28-2004
| « Re: (Logan76) | 4:31 PM 4/26/2007 |
your in the correct section then!
lrb_2000
ID
5-3-2005
no word yet. I'm hoping to get it back towards the end of next week and start assembly. here's a pic of the hicas eliminator bar i just got done installing.. the tie rods were a ***** to get out of the rear steering rack.
| First 1 2 3 > Last |
