lrb_2000 »
https://forums.nicoclub.com/lrb-2000-u28436.html
Sun Dec 07, 2008 9:53 pm
Hmm.. Probably around 2k for the engine..
$250 Supertech .5mm over 9:1 pistons + full seal rings (from a friend)
$400 K1 rods from AMS
$500 95' KA p&p head, valve job, rebuild with 91' cams (NICO member)
$500 Full felpro engine gasket kit, ARP main and head studs, all oem nissan timing chain components, felpro headgasket, main/rod bearings, etc.. (NICO member)
$380 for machine work (block hottanked, new freeze plugs, decked, bored over, hone, crank polished, clearances checked, balanced rotating assembly, and rods/pistons weight matched within .1g)
$70 oem oil pump$45 oem water pump
So overall probably a little over $2000 for the engine build after all was done.. That's not including the $450 ACT clutch.. and a bought a spare 92' kade for $300, I used that block with the '95 kade head.
The whole build was probably close to 7k, or more I would guess.. and my car still looks like ****, but it sure does hall ***.
Also,I'm just over 3,000 miles now. Engine still runs great. My emance tune hasn't been giving me any trouble. My car just takes forever to warm up. I don't have either fan on, and it takes almost 20 minutes of driving around for it to reach 180*... if I go down a hill for a minute or two it drops down to about 150* or less.. I guess the innercooler is doing it's job, but it sucks in the winter.
