I figured i'd get you guys up to date with my build, if anyone is interested.. I know people like pictures.
So here's my last thread, and specs on my current build.
zerothread?id=207038
So now i'm putting the 810cc injectors in place of the 400cc, the GT35 in place of the T3 Super 60, and a tuned enthalpy ecu. I'm going to run somewhere around 12-15psi on my stock engine until my built motor is complete, or the stock one blows up. The built motor will consist of: Turbo 240 Sportsman RodsSuper Tech 9:1 comp pistonsBlock is decked, hot tanked, bored over and honedBalanced rotating assembly (flywheel, crank, crank pulley)Metal head gasketARP Rod bolts, ARP main and head studsRebuilt head, ported and polished, 3 angle valve job with '91 camsNew OEM timing kit, oil pump, water pump etc.. basically replacing everything
I have to replace the 5 bolt downpipe flange for the turbo, make a new hot pipe since i'm coming out and around the p/s reservoir instead of straight down like before, also making the hot pipe 2.5" instead of 2" for the bigger turbo. But for now here's a few pictures of what it looks like at the moment. Take a look at the link i posted at the beginning of the thread to see what has to be changed.
GT35 vs T3 super 60
IAP Manifold +GT35 Clearance, pretty good.. I have ABS and such
pic of the car (getting painted white in a few weeks)
Modified by lrb_2000 at 10:25 AM 3/25/2007
