dustyk »
https://forums.nicoclub.com/dustyk-u13031.html
Fri Aug 31, 2007 3:21 pm
Not Another Fram filter argument....
I always buy whatever filter is the cheapest I can find. I actually have had 1 oil filter fail on my in my lifetime and it was one of those super expensive Mobil 1 filters. Ive read seen the posts online about how the filters dont filter as well and I really could care less. Im not sure if everyone knows but Fram is a subsidiary of honeywell, the same honeywell that Garret turbos is part of.
In anycase whether it be Fram, Wix, OEM Nissan, OEM Honda, OEM Mazda, STP, Bosch, Napa, Mobil 1, K&N whatever, the chances that your engine will fail because of the oil filter is slim to none. Id say your chances of an engine failing due to lack of maintenance is waaaay higher than having an oil filter failing and causing your motor to die.
