What did you do to your Pathfinder / QX4 today?
overwest
Car: 2001 Nissan Pathfinder [Project Pathgrinder] RIP
1990 300ZX TT [PikachuZ] RIP
More stickers. The ones on the right side are ones that I designed.
skiski329
Car: Nissan Altima Coupe 3.5
Wouldn't recommend pulling in reverse. Great way to damage transmission as reverse is weakest gear.
oooo! I didn't know that. then how are we suppose to pull something out? i read in the manuel that's the only tow hook you can pull something out with. the rear ones are for tie down only.
zach7685
Car: 2002 Infiniti QX4
2001.5 Nissan Pathfinder SE
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
Got new seat belts for free under warranty and did brakes. PS i did use a second jack stand Image
overwest
Went ahead and layed on some yellow tint over my fogs
And then I chopped off this resonator/secondary muffler thing, replaced it with some 3.5" galvanized steel all the way back. Sounds a lot deeper now.
THatfield
Car: 2003 Infiniti QX4
Did an oil change with Mobil 1 5w30 full synthetic and a Mobil 1 filter. Also aired up my spare tire and rotated the ones on the ground.
Then I discovered wonderful body rust in multiple places.... :tisk: :cry:
Bluewulf73
Car: 1998 Pathfinder LE
Started working on my homebrew snorkel and installed my Jackson Autosport "missing link".
Sometime this week I gotta cut into the fender :ohno: to pull the Intake hose through and connect to the external part of the snorkel. :woot:
Slumpert
Car: 1997.4 Pathfinder
So yesterday I installed new shocks and struts. I bought the Gabriel Ready Struts and shocks. The struts were a bit pricey $149.00 each but they are complete unit with a new spring, bearing, top nuts. Total spent was bit over $400.
I bought replacement nuts from Nissan, but I misread the parts diagram and thought the shocks used the same nut top and bottom, the bottom one is different so i ended up re-using the old one.
I was not prepared for the amount of effort the swaybar connection ball joint took to release on the passanger side. 17mm nut that litterally would not budge to a 500ft torque wrench, tried neigbors snapon impact and cracked the husky 17mm socket I had. Bought a impact socket set and still the snapon impact could not break the nut free. Finally used a 2ft breaker bar and my 300 pounds to get it loose.. One of the other 21mm nuts on the lower strut was hard but the rest came off pretty easily.
It no longer springs like crazy on bumps so well worth it.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
Rolled over 200,000 Miles. Things to do suspension, Oil Change and bushings.
BoostMyQX4
Car: 96 Infiniti QX4
Bleed brake lines today, man it look like McDonald's sweet tea come out of the lines lol
And tomorrow i have to adjust rear brakes.
Bluewulf73
I have successfully completed the snorkel for my Pathfinder.
The hardest part was cutting. Had to use a Rotozip and around 11 cutting disks. I still have to get the edge-guard put on the edges of the opening but it is already on and working beautifully. Sorry, I have no photos of the work as I did it over a few days between work and kids. I have yet to install the edge trim (can't find it anywhere) hopefully that will be done in the next two days. Later on, when I have more $$, I will buy a proper snorkel head.
As you may or may not be able to tell, I already crossed a puddle. IT was deeper thank last time I went through it and the water came over the hood and splashed the windshield. I freaked out.
Stopped on the other side and to my surprise, (wasn't sure my job sealing the box was all that good) the interior of the airbox was bone dry! Woohoo
Total cost was $50.00
I have attached a couple of photos. Kudos and many thanks to RedDog of PCoA for his idea and templates!
Next, some OME, KYB, NX4 and 4X4 design goodness!
overwest
Picked up some parts I need to replace on there. Starter, Water pump, and spark plugs.
As well as an early birthday present ;P
Now...I have to save for these...
THatfield
Today I discovered if I hold the unlock button, my windows go down! :woot:
I love my truck!
Densetsu
Car: 2004 Nissan Pathfinder Chinook
Prev: 2003 Nissan Pathfinder Chilkoot
THatfield wrote:Today I discovered if I hold the unlock button, my windows go down! :woot:
I love my truck!
I've yet to understand why Nissan would put in this function, but leave out a way to CLOSE your windows with the remote.
overwest
http://youtu.be/UhRDRN7wUzw
Got my Flowmaster on today. But I had a little fun without any exhaust for a bit.
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
Nice exhaust overwest, i might be getting the pathfinders done soon, getting the cats cut out and straight piped, no resonator/muffler/ just glass packs and dual out.
On the other hand my X5 4.8is factory exhaust is a beast and im going to be doing the resonator delete and electronic cutouts before the mufflers that way i can lower the sound when i need to but otherwise, another guy has it done on his and you hear him well before you see him, sounds awfully mean.
Heres stock sound:
http://youtu.be/OoGwggl6yo4
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
Changed my in cabin air filters today.
3 years since the last change. They were pretty black, but not as nasty as some I've seen on here.
Checked the air box while I had them out, and it was still pretty clean in there. Whew.
Next on the list is getting my snow tires off. Hopefully next week. After that, a major cleaning, inside and out.
Summer can't come soon enough.
overwest
I'll probably be slowing down on posting in this thread because I feel like I've spammed it out the poopoo hole but I managed to change my spark plugs today. Not before snapping one of my coil packs in half. :( Surprisingly, it still works. I'll see for how long though. That one on the end is from the drivers side, very back. Spark plug #3 I believe. Any idea as to why it's drenched? Me and my pops figured that it was overflow from a bad oil change.
Buzzman
Couple of things to check/think about: The oil and sludge on that plug looks like it's been there for a while.
Definitely doesn't look fresh. Check the valve cover and see if there's a leak above the plug.
The other concern is the top of the plug, the contact nipple. It is black/corroded. The other plug contacts are nice and clean in comparison.
Might want to check that particular plug (the new one you put in) about a month from now and see what it looks like.
skiski329
@ Overwest. Could it be oil that dripped in there and was trapped when filling up after an oil change? I figure that any excess oil touching metal would have been burnt off, but since the top is surrounded by plastic maybe it wasn't burnt off.
overwest
Buzzman wrote:Couple of things to check/think about: The oil and sludge on that plug looks like it's been there for a while.
Most definitely. That's what I figured may be the issue. When I go to pull apart the engine again to do the water pump, I'll get a better look around most likely. And that'll be on my list to do next month for sure.
skiski329 wrote:@ Overwest. Could it be oil that dripped in there and was trapped when filling up after an oil change? I figure that any excess oil touching metal would have been burnt off, but since the top is surrounded by plastic maybe it wasn't burnt off.
That was the assumption as well. My pops and I figured this was somehow close to an overflow for the engine oil so it just ended up draining into the spark plug well.
Pathfinder3.5
Car: 2002 Nissan Pathfinder LE Gold
God, I miss my truck :(
BoostMyQX4
Today im working on patching some of the rust spots on the wheel wells in the back, paint started to bubble up in some spots, oh man nissan really messed up by using cheap metal for these trucks.
Anyhow im gonna Bond-Do the heck out of it LOL.
Quick Question: What color can i paint the SUV that will be closest to Sahara Beige Metallic/Tuscan Beige Metallic with out the Metallic.
zach7685
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
I love my truck!
It could be a Safety Feature
Buzzman
I love my truck!
Umm, you know you can open AND close the windows by using just your key in the drivers door lock right???
You don't even have to get in the truck that way.
yngw13
Car: 2001 Nissan Pathfinder SE
hooked up battery to a charger/Maintainer...took 5 hours or so for it to be fully charged
I did this this weekend...
I dont use the pathy much and worried that the battery is gonna have an untimely death...(2 weeks in a row)
Also my sis was passing by and I offered the car if she needed to go anywhere...she ended up not using it...
Its just a Everstart Walmart battery....and its an OK battery...it doesnt do so well in maintaining a 12.4-12.6 voltage....it hovers in 12.1...but it was good in winter and started the car fine....eventually if I start putting in my subs Ill probably go buy a Diehard platinum...and do a Big Three upgrade
nico911411
Just installed K&N Filter. Now I'm trying to figure out how to custom a shield!
Anyone knows what the "hose" circled in RED is? it was connected to OEM Airbox. Fuel vent???
I can feel the QX4 sucking in lots of air now!
Bluewulf73
First off, lemme say that I did not do most of this today, this happened over the past week... got my snorkel head and installed (too big for my application)
Installed Bash Plate:
OME Lift + NX4 strut spacers and 1" rear spring perch spacers:
Before:
After:
Went wheelin':
[youtube]http://www.youtube.com/watch?v=IkjYfC7MpNE[/youtube]
Washed him today:
Oh, yah...started installing roof rack lights... :woot:
BoostMyQX4
Took off front fenders, MAN WHAT A PAIN!!!!
Will be replacing driverside fender and fixing passenger side.
Bluewulf73
nico911411 wrote:Just installed K&N Filter. Now I'm trying to figure out how to custom a shield!
Hey nico911411,
Looks nice! I've seen filter shields made out of clean paint cans. The ones I've seen have been for snorkels but I'm sure it would work nonetheless.
Adapter from inlet hose to bottom of paint can, screwed and siliconed/glued in to make it air-tight, hole in paint can to match the hole from adapter.
Adapter for filter screwed and glued to top of paint can. Filter tightened to adapter and top of paint can can then be clamped shut on to paint can. Can also be opened to clean/remove filter.
Lastly, a small hole and glue the little nib onto which that hose with the red circle attaches to. It is a vacuum/vent line that attaches to the top RH side of the plastic box. It draws clean air from the top of the airbox. Paint can can be...umm...painted to match the colour of the car and then attached to the car via large clamps to prevent it from vibrating loose. Just a thought... :gotme
Bluewulf73
BoostMyQX4 wrote:Took off front fenders, MAN WHAT A PAIN!!!!
Pain is right! I was going to take mine off, to fix a dent and cut the hole for the snorkel hose.. :facepalm: ended up scratching that idea and cutting the hole and painting it with the fender on.
