What did you do to your Pathfinder / QX4 today?
mthatch
Car: 2001.5 Nissan Pathfinder SE
I spent a solid week detailing my car inside and out.
First, using rubbing compound, I removed all of the build up on the car.
Afterwards, I finished the process with polishing compound and multiple layers of wax.
I then cleaned the carpets, seats, and restored the pile where it was bad.
Removed the cracked and ripped console cover, and reupholstered. ( This is without sewing. Once I have access to a sewing machine, I can used the old pieces to create a template and make a fitted one.)
New rotors, brake pads, inner and outer wheel bearings and races, and wheel seal.
After installing a cold air intake and realising how much I love driving through puddles, I decided to modify my air cleaner box to accommodate my cone filter. The air dam underneath the box has been opened up to allow cool air from behind the fog lamp inserts.
I also replaced the burned out lights inside the recirc and AC switches, rebuilt my ac pully's bent tensioner bracket assembly, new belt, cleaned the rear brake drums and shoes, and replaced the cabin air filters.
zach7685
Car: 2002 Infiniti QX4
2003-Subaru Baja
1989 Nissan Maxima
2003 GMC Savanna
2002 Mini Cooper S
1968 Mercedes 230-Sold
2005 VW beetle Convertible
2001.1 Nissan Pathfinder LE
Today I replaced a leaking, low pressure A/C hose. Its a fairly easy job. I used a hose from a QX4 and it didnt quite fit so I had to get a longer screw. The screw I got from Lowes ended up being too long so I had to use washers to shorten it. Saved $400
Car: 2001 Nissan Pathfinder LE
Bought the 2001 LE a year ago for jus a daily mobile work vehicle...absolutely love it. Year later i decided to put some money into it...all in one shot:)
-Starter
-Coolant flush
-Changed frt brake pads/rotors/calipers w/brake flush
-Front outer tie rods
-Rear trailing arm/upper control arms/sway bar links(fixed death sway)
-4 wheel alignment/adjusted the bearings
-OEM roof hatch deflector
-AVS Hood defector
-Traded for newer R50 oem 17"
-245/70/17 General Grabbers
sonnyc
Car: '99 Pathfinder SE
I replaced the fuel filter. This was the second time I replaced it and guess what, the first time I installed it the wrong way. Been driving with this for 7 years LOL... :blush:
I got some SES light came up recently (P0153 and P0325) but I reset it and see if they came back :) The truck was and is driving very smooth except some hesitation around 65-70mph.
Jake2.4
Car: 2002 PF LE
Replaced the transmission, many curse words were said.
But she runs good once again.
