Postby Orlandos13 » Fri Oct 31, 2008 12:02 pm
Hey, I'm not that familiar with rbs so can anyone please briefly explain to me which of these three engines would be best to swap on a 240sx s13 89?
Orlandos13
Car: 1989 Nissan 240sx KA24(e) s13
Re: (Orlandos13)
Postby mmm240 » Fri Oct 31, 2008 12:19 pm
You found the right forum, so It could be worse. But it's not what others think is better it's about what you figure out that you want on your own.
http://forums.nicoclub.com/zerosearch
"God damn that's a pretty f**king good milkshake... I don't know if it was worth five dollars, but it's pretty f**king good"
mmm240
Car: 05 CTS-V, 02 GSX-R 750, 94 Toyota Pickup, 91 GVR4, 91 Accord Wagon
Re: (Orlandos13)
Postby Coolwhip » Fri Oct 31, 2008 12:19 pm
figure you budget for such a swap as in how much you have to spend or willing to spend.
Figure the type of application you wish to use this car for (street, road, track, drift, drag, etc, etc, etc.)
research, research, research the engines you might potentially swap. much is uncovered in this step.
Make a grid, matrix, cost vs. benefit analysis, etc. etc. whatever fits your decision making process.
Determine what engine best fits your needs and budget.
Re-evaluate budget.
multiply by x2.
Then call me
PLEASE ENABLE YOUR PM's BEFORE PM'ing ME... I will not be able to respond if not
President of the RBBA - RB Baller Association
Treasurer of the NRRBA - Non-Running RB Association
http://rawbrokerage.com
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Re: (Coolwhip)
Postby Orlandos13 » Mon Nov 03, 2008 9:46 am
Thanks dude! I think I'll go rb26dett. Thanks again, that chart with info really helped me a lot and saved me time.
Orlandos13
Re: cost (rection47)
Postby rb20det-240z » Wed Nov 05, 2008 1:19 pm
rb20det - 1100 with ecu, trany, wire harness.maf sensor,
rb25det - 1800-2300
rb26dett - to much lol
rb20det-240z
Car: 1972 240z
Knowllage?
Postby rbNissan » Sat Nov 08, 2008 11:40 am
Im a bit of a noob when it comes to Nissans I was a honda guy for the last 10 years and have decided to move on to a more powerful car. I have a 95 nissan 240sx I am looking to swap a motor into the car and I am looking at putting a rb25det motor into my car Ive read this forum. But am still alittle unsure. how reliable would a rb25 motor swap be in the car.
rbNissan
Re: Knowllage? (rbNissan)
Postby Coolwhip » Sat Nov 08, 2008 8:41 pm
rbNissan wrote:But am still alittle unsure. how reliable would a rb25 motor swap be in the car.
as reliable as you make it. Get a beat up motor or just swap it in without going over it to do maintenance and it can either provide you with a good time of fun or a problem child thing after thing.
Spend some money and do things right as you swap it in, then these things are less likely to fail and cause you problems when using this motor daily.
Its just like anything else in life... Date a girl and not pay her any attention during the beginning of the relationship, she'll either dump you or will create problems for you and you'll be picking up the pieces as you go.
Or you can just start out by learning what she likes, get the bad luggage out of the way, etc. and you'll have a much better prepped relationship.
(now thats some quality advice, people pay for that, )
hope that helps
Coolwhip
Vendor
Re: Knowllage? (Coolwhip)
Postby kylekinnamon1989 » Wed Nov 12, 2008 3:08 pm
ive been looking all over this forum for track times!! but nobody has asked them or posted them.. i was wanting to do the rb25 swap on my 90 240sx se and i was wanting to know who has done that and if they have taken it to the tracks and what there 1/4 mile run was!! just straight rb25det swap in the s13 with no upgrades otherthan the stock turbo, maf ecu ect!!! anybody know the track times!!?
kylekinnamon1989
Car: 90' Nissan 240sx SE/ SR20DET
Re: Knowllage? (kylekinnamon1989)
Postby mmm240 » Wed Nov 12, 2008 3:13 pm
Check youtube and streetfire and whatnot
mmm240
Re: Knowllage? (mmm240)
Postby kylekinnamon1989 » Wed Nov 12, 2008 3:35 pm
mmm240 wrote:Check youtube and streetfire and whatnot
i have, i can only seem to find them doing burnouts and idling and **** like that, i wanna see actually track times and stuff you know!?
kylekinnamon1989
Postby mmm240 » Wed Nov 12, 2008 4:03 pm
mmm240
Re: Knowllage?
Postby rbNissan » Fri Nov 14, 2008 11:44 am
Alright then. According to the shop they have replaced the intake manifold with a Greddy Intake Manifold, Greddy Intercooler, Nismo Engine Mounts, Upgraded Fuel pump, Upgrade Water Pump. Now assuming everything else is still in good condition. what would the next step be I have heard that the main bearings are good to replace. Any other suggestions?
rbNissan
Postby Coolwhip » Fri Nov 14, 2008 12:15 pm
rbNissan wrote:what would the next step be I have heard that the main bearings are good to replace. Any other suggestions?
If you are going into the block to do bearings, you should opt to do the crank collar as well. Replace the rod bolts with some ARP hardware.
Coolwhip
Vendor
Re: RB25 in a BMW 325IS???
Postby igorok » Mon Dec 01, 2008 10:04 am
Hey Guys, im planning to swap a RB25 into my 1992, 325is, what do u think about that???? thanks!!!
igorok
Car: bmw
Re: RB25 in a BMW 325IS??? (igorok)
Postby mmm240 » Mon Dec 01, 2008 10:31 am
Cool? Sticking with an I6 is cool, but I would swap an M motor in. Good luck and keep us updated!
mmm240
Re: RB20DET vs RB25DET vs RB26DETT FAQ (krayton)
Postby Nguyen91 » Mon Dec 01, 2008 11:55 am
so i've been doing a bit of research on the RB30 hybrids and i may have a new project in mind.. I'm gonna wait awhile though before doing anything... gotsta get edjukayded..
Nguyen91
Re: RB20DET vs RB25DET vs RB26DETT FAQ (gbaz77)
Postby 916builder » Tue Dec 02, 2008 7:14 am
A drive shaft out of a datsun 620 pu works too for those of you that want to use a single drive shaft. It can be cut to size for around 40 bucks anywhere. I have used this myself for a swap.
916builder
Car: To many to list!!!
Re: RB20DET vs RB25DET vs RB26DETT FAQ (mmm240)
Postby SullivanRacing06 » Tue Dec 02, 2008 9:23 am
mmm240 wrote:
16000lbs
haha, i think its was more like 24569lbs, what a bad question, here ya go who ever asked the weight diff question
if i have to be drug tested to keep my job, why is our government not drug testing everyone on welfare?
SullivanRacing06
Car: r32 gtst, 06 350z, 98 durango r/t, 94 f-350 with a 6bt, 91 ef, 91 da
Postby droppedyota94 » Wed Jan 14, 2009 1:19 pm
I just have a quick question. I know a guy with a shot rb20 block and i know where i can get a good rb25 block is it possible to use the 20 head on the 25 block? If so what needs to be done to make this work? I now the 20 head isn't as good as the 25 but the 25 block has no head with it and his 20 head is good.
Life is an endless drive that you take alone. Might as well enjoy the right, take the long way home.
droppedyota94
Car: 1990 240sx S13 with RB25DET
Postby 1992x240sxDriv3r » Sun Mar 29, 2009 3:04 am
I want to get a rb25 for my 240!!!!
1992x240sxDriv3r
Car: 1992 Nissan 240sx se
Re: RB20DET vs RB25DET vs RB26DETT FAQ (1992x240sxDriv3r)
Postby AlmightyWez » Wed Apr 01, 2009 8:16 am
Whats the deal w/ the 26's individual TB setup? Is it worth keeping or is it better to do a regular 25 style intake w/ single TB? I'm still a newb to the RB so I'm not sure which is better to have for a race setup.
76 280Z - Project "GodZilla"
AlmightyWez
Car: 76 280Z
Postby 2fast4urass » Mon Apr 06, 2009 5:04 pm
1. R34 engines are easy to find on ebay but cost around $8,000
2. can you put HICAS on a regular 240sx
3. how would i make a 240sx all wheel drive
2fast4urass
Postby IrenicShogun » Thu Apr 09, 2009 3:03 pm
The RB26 cons are not even constructable, come on man.
Hyper producing hydrogen fluid liquids, keep your distance.
IrenicShogun
Car: 95 240SX Hatchback
Re: (Wannab)
Postby wakabless » Thu Apr 16, 2009 7:02 am
where is a safe place to by the rb25det
and if anyone knows where can I find one in TX I'll be great
wakabless
Car: nissan 240sx s13
Re: (wakabless)
Postby Vkoslak » Thu Apr 16, 2009 11:08 am
There is a shop in Richardson that sells rb25det. A friend of mine bought a H22A there and has had no problems with it. I've bought some r33 brakes and rear subframe from there. They jacked me around a little on shipping. But if I go there in person everything is fine. "jdmenginescorp" on ebay. They have a rb25det for sale right now for $2k. I suggest going in person and picking out the rb25det you want.
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Re: (Vkoslak)
Postby wakabless » Fri Apr 17, 2009 3:35 am
thanks man
wakabless
Postby bigblak06 » Mon Apr 20, 2009 8:15 pm
do rb25 and rb26 you the same motor mount kit
bigblak06
Car: 1989 240sx
Re: (GTR Shop)
Postby Midnight Ryderz » Mon Jun 22, 2009 9:27 pm
NOT all rb25det's have cermic turbos ONLY the s2 had them. I personally know this because i have an actual r33 skyline gts25t S1 and am running at full boost 17psi STOCK turbo if it was cermic it woudl have blown apart at 1 bar
Midnight Ryderz
Car: 93 Nissan Skyline R33 GTS 25t
Postby rbchick » Tue Jun 23, 2009 12:05 pm
Rb20s are great and fun. Even though they arnt one of the more money saving swaps they are definatly worth it and sound better stock then any other 240s ive heard when they get on it
rbchick
Car: RB powered s13.....KA s14
Postby Kalypso » Thu Jun 25, 2009 11:58 pm
what are the three weaknesses of the rb26 for reliability.
I believe they are:
1 - too much oil in the head, extra drain needed.
2 - crank collar.
3 - ...
fill in the third and elaborate please.
Kalypso
PreviousNext
Return to RB20DET / RB25DET / RB26DETT Forum
