RB20DET vs RB25DET vs RB26DETT FAQ
Kalypso
bigblak06 wrote:do rb25 and rb26 you the same motor mount kit
I believe this is a yes
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
sorry but there different. i know this from seeing it myself. my freind has rb25det swap(mckinney mounts) in his s13 coupe and his mounts are completely different to my RB26 mckinney mounts. now the tophat garbage mounts are suppose to have all 3 rb mounting points but the mounts are real poor qualitly from what ive seen.
Kalypso
not a problem, im glad he got the right answer....
any answer on my original post above?
stylepointzz
Car: 1990 hatch' 'oo' nose
kalypso i got a question for you, can you get on AIM for a sec?
Kalypso
my comp is in bad shape and is crashing often.
email me, and when its not acting up i'll hit you back.
stylepointzz
done
amakadius
Car: 1995 nissan 240sx rb25det S14.5 conversion
2fast4urass wrote:1. R34 engines are easy to find on ebay but cost around $8,000
2. can you put HICAS on a regular 240sx
3. how would i make a 240sx all wheel drive
you should be slapped for question number 3
bm3r
Car: 98 240sx
Anyone have dyno #'s with BPU upgrades on their RB25?
BPU upgrades would include:
Intake ManifoldFMICDPExhaust
kermit5327
Car: 95 240sx White 100% stock
im sure u guys are going to eat this up but did any rbs come with auto trannys
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
Yep
supersayianjim
Car: 89 240sx(s13)
Speaking from experience and doing my own rb20det swap by hand(my own) heres a break down for those unsure..
-1989 240sx(blown head gasket) no rust 89,000 miles(from ak) $800.00
-Rb 20det motor set(including harness,ecu,intercooler,fuel pump) $700.00(SHIPPED)
-harness work(carl h) $220.00(only thing i sent away)
-R32 crossmember$115.00 (j-hot)
-inteercooler,piping,fluids,spark plugs $3,000.00
doing this swap your self(if you have a garage do it) is not expensive.. easy to do and things fall into place.
i didnt get my diff installed yet(got a j-30) and didnt install my urethane kit. going to pull my oil pan and replace it.
the engine is very very clean. like a new one. runs like a champ(on stock psi) and is great on gas..
i don't have a tach(dont need it) and with a 5spd vss you can use it on the rb transmission and get mph readings.
if youre not good on wiring(like me) just pay to get the harness put together..
i have the send the ecu away(to carl h again) to eliminate the speed limiter(it stops at 120mph) and to adjust maps with my turbo upgrade...
geartech4
Car: 96 Nissan 240sx
krayton wrote:Ok here it is. Im thinking we make a faq comparing all the engines. Now we know the rb26 is top, and the rb20 is bottom. Lets just shoot some info out on all the engines to help other people decide on engines. Also lets leave price out of comparing engine to engine cause that always turns into the deciding factor anyways. Everyone shoot there feelings or good info on a specific engine. I can edit it in to make it easier. try not to get in arguments. if you disagree just say so. no need to make a fuss about it. Mod is gonna be strict on this one to make it clean. damn right i am. if this turns into a flame fest ill lock it and we will never discuss this topic again -Kamin
*this is just trying to make things a little easier for other people
General
Pros
-its an RB! from a skyline!-closest thing to a real skyline-I-6 potential-the awesome sound.
Cons
-Yes, it is more weight, around 150lbs more for a rb25 swap. the weight isnt important tho, its the weight shift. it really depends on engine/transmission and how you mount it (i.e. crossmember or aftermarket mounts), but realistically your looking at 2-3% overall weight shift. if you look at the numbers in a 3000lb car thats only a 60-90lb shift forward. just to put that in perspective, 12 gallons of gas weighs roughly 100lbs so there is more of a shift between a full and empty tank, than a RB swap. IT DOES NOT DESTROY THE WEIGHT BALANCE OF THE CAR
-Parts are still rare and expensive, but things are starting to come over-mounts or crossmember swap required
RB20
Pros
-cheap-skyline engine (?)-WD-racing was saw near 400hp with his-easy swap-free revving up to 8k is possible on stock valve train-excelent gas mileage off boost (it is a 2l after all)-can make good power with minimal mods.-sensors interchange with lots of usdm cars
Cons
-SR is easier with same potential (for your lower goal people). out of the box both will make near the same power, and upgrade easily to near the same numbers. -cheap turbo (ceramic wheel)-"weaker" transmission, nearly the same as KA/SR trans-akward intake manifold- its getting old 89-93 production years-high mileage engines need proper mantinence ie timing belts and water pumps- tiny injectors (270cc)-intake manifold flange is diffrent from rb25 (greddy manfold does not bolt on)-some rb20's can have the same problem as the early rb26 engines with the crank collar issue
RB25
Pros
-good potential (500+ on stock internals)-VVT-strong transmission (also include this when you price rb25s)
Cons
-expensive clips (when you get that strong transmission)-becoming rare and expensive parts-weak pistons ring lands-not full glory as rb26 -another lame turbo, but better than the RB20's-factory hp overrated (easily achieved with basic swap upgrades though)-side feed injectors (hard to find)-akward intake manifold-custom driveshaft required (unless you use RB20 transmission?)
RB26
Pros
-the GODZILLA of RBs-most potential of all-twin turbo stock-upwards of 300+ out the door-bullet proof
Cons
-$$$$$-$$$$$-r32 crank coller issue (kills motor)-need for rb25 transmission-hard to find r33 motors-impossible to find r34 motors-did we mention $$$$$?
RB30det hybrid
Using the higher displacement 3 L block from the RB30 engine mated to the RB25 or RB26 head can yield a very powerful engine. Here's a thread with details. zerothread?id=188136
For Specs on engines and good info also check:- http://www.meggala.com/nissanrb3css.htm
Very nice bro, you broke that down very well. I have a S14 rb25 with upgraded turbo and aem ems and some other stuff, and i love it. I made 447hp and 400 ft lbs at 23 psi. I would love to have more power but it is a monster and sounds awesome.
S13_RB25
Car: A 240 but no RB yet!
Ok what I was wondering, looking off of the rb30 hybird, was that can a rb26 head fit a rb25 block?? If so what are the pros and the cons?
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
S13_RB25 wrote:Ok what I was wondering, looking off of the rb30 hybird, was that can a rb26 head fit a rb25 block?? If so what are the pros and the cons?
Biggest con... price of a RB26 will be cheaper to purchase than trying to mate a RB26 to a RB25. The end results would not justify the cost associated with the head swap. Best route to go on the RB25 block is with a R34 NEO RB25 Head.
S13_RB25
. Well does the neo head flow in more air then the rb25 head it self or the valve train is better on the neo compared to the rb25.
S13_RB25
S13_RB25 wrote:. Well does the neo head flow in more air then the rb25 head it self or the valve train is better on the neo compared to the rb25.
Ohh I forgot lol the RB25 neo has VVT. But just to make sure does that give the rb low to mid range torque right??
S14Zilvia
Car: '90 300ZXTT, '92 S13 coupe, '06 Ram 3500 Mega, '93 del Sol Si
So no new information on engine weights?
One would think that an importer could throw their motor sets on a scale and document the results.
EJ8 944
When I got my RB26, completely stock, everything included minus trans and flywheel, UPS clocked it at 830 lbs with two wood pallets. If that helps any.
Abaker13
Car: 93 HB S13 KA24DET
*sold* 96 Zenki w/ RB20DET
this is an old thread but ive got myself a frankenstein rb engine with the RB20DET engine RB25DET turbo and RB26DETT cams and injectors................:)
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
OEM Cam gears, specifically rb20det and rb26dett, are there any differences?
I had an rb20det, now I have an rb26dett, rb26dett cam with rusty adjustables, can I use my oem rb20det cam gears without issue?
Orthank
Car: 1998 R34 Nissan Skyline GT-T
RB25DET series 1
Ceramic POS Turbo like the RB20
Side feed injectors like SR20
RB25DET series 2
Plastic compressor wheel turbo
Different CAM angles and sensor
RB25DET NEO
NEO head with ome GT-R head internals (solid lifters)
different combustion chamber size
IN EX CAMs are different sizes 236°in, 232°ex
IN EX NVCS (r33 is only IN)
Traction control
Improved coil packs
Largest stock RB turbo
MT ECU is expensive and rare as hell due to different wiring loom compared to all other RB engines
Top feed injectors same as Z33 Z34 (370cc)
Highest power (STOCK) of all RB single turbo engines
Practically every head component is unique to this engine therefore sourcing parts can be a b****
outlaw7
Car: 78 zed
you know ive been doing a lot of reading on these engines and ive heard a few different issues with each engine from different threads but i dont think(i could be wrong though) anyone's compiled them into one place, i think it would be a good idea if someone knowledgeable posted all the good reliability mods and things that should be replaced or upgraded before looking for big power for each engine
i know from different places ive heard about rb25 ring landing issues and other engines ive heard something about oil starvation from the pump, but is their anything else major that should be taken into account when building these engines?
sorry if this has been covered already, still trying trying to get my bearings on this site
Miguelone
Car: R33 Skyline 4 door
Orthank wrote:RB25DET series 1
RB25DET series 2
RB25DET NEO
Traction control
Improved coil packs
It doesn't have VCT on the exhaust, only intake like R33 RB25's, it does have more aggresive stock cams though.
kiwiDET
Car: S14 30DET 26DETT HYBRID 985RWHP @35 PSI
Fuk i feel sory for you guys, in new zealand we have more then enough rb parts lol. We get the rb 20 25 26 30, every silvia and skyline regardles of it being gtr or just gtst. Plus we get the nisan cefiro a31 and c33laurel. We have a website cald www.trademe.co.nz have a look there for parts guys.
lazyman18
This might sound like a dumb question trying to see what ppl think I should do I'm having a toss up what motor I should buy the rb20det or rb25det I'm goin to leave it stock for now and its goin to my first Nissan motor and I'm putting it in a 1976 Amc gremlin thanks for the help
Trini94
Car: sentra specV 04
when u say the rb20 transmission is weak do u mean the internals (clutch flywheel and pressure plate) or is it something else?
TheRoadShark
Car: '93 S13 Coupe
RB25DET S2 @ 10psi
Silvia conversion
Trini94 wrote:when u say the rb20 transmission is weak do u mean the internals (clutch flywheel and pressure plate) or is it something else?
Internals as in the shafts and gears and forks and synchros and stuff. The RB20 transmission is a KA transmission is an SR transmission, just different bellhousings - IIRC. The RB25 trans (same as Z32 n/a) is massive by comparison and can withstand alot more power. So it's weak by comparison, and weak for high power purposes.
32GTR
Car: RB26dett 32gtr original
hey guys does anyone know what the torque tension is for a rb26dett for the cams brackets??
Dontletmefall
Car: Hcr32
Random question. Would the standard fpr's off a rb25 bolt straight onto an rb20? Without needing an injector ungrade or tune?
