So we can confirm that the intake is clean and I have no vacuum leaks not a big one at least because at idle I get 20" Hg (~650 RPMs).
Injectors are a couple of years old but I have no history of a BG power flush, just BG44K and Redline S1 along with ISO Heet.
I never did a compression test but the engine was rebuilt at 30K miles at a Infiniti dealer (Not back in Japan).
I never did a oil pressure test but on of the HLA's on the left bank possibly #7 cylinder is clogged and makes a noise. I have tried BG Quick clean thats put into the engine oil and run for 15 minutes a couple of times but thats has yet to fix it. I am worried about using Marvel Mystery Oil because I haven't heard many good things about it.
The spark plugs were changed last year with OEM NGK standard 5 heat range, Gap may or may not have been checked to make sure its correct. There is a leak on coil packs 1 and 2 but I need to make the time to reseal them, I have 8 used spare coil packs and one used harness for the right side. All the spares OHM to at least 7 OHM's and the spare harness has continuity to all connections.
Timing according the ECU seen through the Consult is set to 15* Before Top Dead Center.
Enough about my car here is how to set up the power balance test so you get good results:
Start up OBD Scan tech (Nissan)-> Go to the Power Balance button on the bottom left of the screen-> Go to the Options tab->
Make sure the values on your screen match those below then press the "Save" button
(8 Cylinder)
(Under RPM Adjustment turn the dial all the way to the right till you see 200) (This is to hold the AAC wide open (100%))
(Cylinder off and cylinder stabilization should be bot 9 seconds). (From the default 2 and 3 seconds).
(You can check the "Power Balance" box but I am unsure if it makes any difference.
When all of the above is set then select "Save" then every time you open the program those setting will be used unless changed.
http://picasaweb.google.com/lh/photo/FP ... directlink
http://picasaweb.google.com/lh/photo/_c ... directlink
When the above is set correctly go to the main default screen by selecting the "Test Results" tab-> The select the "Start/Stop tab on the top right-> Press Start.
Let the test run then go to the "Summary" tab to see the result in detail.
The only thing I can't confirm is if the Injector pulse width changes to make up for the cylinder thats shut off.
I will do some tests tomorrow and see if it does or not.
Here are three back to back runs with the CD changer paused, Hood open, TCS off and doors closed:
Power Balance Test Summary On 8/10/2010 7:38:43 PM
Coolant Temperature: 185 Deg {F}
Idle Air: 100 %
Cylinder # 1
Cylinder On Stablized For 9 Seconds
Average RPM When Cylinder Stablized... 1554 Rpm
Cylinder Off Sampled For 9 Seconds
Average RPM When Cylinder Is Off... 1462 Rpm
Average RPM Drop Result... 92 Rpm
Highest RPM Drop... 854 Rpm
Amount Of Data Sampled When Cylinder Off... 569
Cylinder # 2
Average RPM When Cylinder Stablized... 1546 Rpm
Average RPM When Cylinder Is Off... 1472 Rpm
Average RPM Drop Result... 74 Rpm
Highest RPM Drop... 846 Rpm
Amount Of Data Sampled When Cylinder Off... 567
Cylinder # 3
Average RPM When Cylinder Stablized... 1549 Rpm
Average RPM When Cylinder Is Off... 1475 Rpm
Highest RPM Drop... 849 Rpm
Amount Of Data Sampled When Cylinder Off... 572
Cylinder # 4
Average RPM When Cylinder Stablized... 1550 Rpm
Average RPM When Cylinder Is Off... 1476 Rpm
Highest RPM Drop... 850 Rpm
Amount Of Data Sampled When Cylinder Off... 549
Cylinder # 5
Average RPM When Cylinder Stablized... 1553 Rpm
Average RPM When Cylinder Is Off... 1482 Rpm
Average RPM Drop Result... 71 Rpm
Highest RPM Drop... 828 Rpm
Cylinder # 6
Average RPM When Cylinder Stablized... 1560 Rpm
Average RPM When Cylinder Is Off... 1489 Rpm
Highest RPM Drop... 822 Rpm
Amount Of Data Sampled When Cylinder Off... 570
Cylinder # 7
Average RPM When Cylinder Stablized... 1564 Rpm
Average RPM When Cylinder Is Off... 1473 Rpm
Average RPM Drop Result... 91 Rpm
Highest RPM Drop... 839 Rpm
Cylinder # 8
Average RPM When Cylinder Stablized... 1559 Rpm
Average RPM When Cylinder Is Off... 1484 Rpm
Average RPM Drop Result... 75 Rpm
Highest RPM Drop... 821 Rpm
Power Balance Test Summary On 8/10/2010 7:42:01 PM
Idle Air: 10 %
Cylinder # 1
Average RPM When Cylinder Stablized... 1472 Rpm
Average RPM When Cylinder Is Off... 1471 Rpm
Average RPM Drop Result... 1 Rpm
Highest RPM Drop... 734 Rpm
Amount Of Data Sampled When Cylinder Off... 561
Cylinder # 2
Average RPM When Cylinder Is Off... 1479 Rpm
Highest RPM Drop... 825 Rpm
Cylinder # 3
Average RPM When Cylinder Stablized... 1562 Rpm
Average RPM Drop Result... 83 Rpm
Highest RPM Drop... 862 Rpm
Cylinder # 4
Average RPM When Cylinder Stablized... 1558 Rpm
Average RPM When Cylinder Is Off... 1480 Rpm
Average RPM Drop Result... 78 Rpm
Highest RPM Drop... 858 Rpm
Amount Of Data Sampled When Cylinder Off... 565
Cylinder # 5
Highest RPM Drop... 829 Rpm
Cylinder # 6
Average RPM When Cylinder Stablized... 1548 Rpm
Average RPM When Cylinder Is Off... 1466 Rpm
Average RPM Drop Result... 82 Rpm
Highest RPM Drop... 823 Rpm
Amount Of Data Sampled When Cylinder Off... 571
Cylinder # 7
Average RPM When Cylinder Is Off... 1456 Rpm
Average RPM Drop Result... 97 Rpm
Amount Of Data Sampled When Cylinder Off... 502
Cylinder # 8
Average RPM When Cylinder Stablized... 1538 Rpm
Average RPM When Cylinder Is Off... 1460 Rpm
Highest RPM Drop... 813 Rpm
Amount Of Data Sampled When Cylinder Off... 496
Power Balance Test Summary On 8/10/2010 7:45:18 PM
Idle Air: 10 %
Cylinder # 1
Average RPM When Cylinder Stablized... 1477 Rpm
Average RPM Drop Result... 21 Rpm
Highest RPM Drop... 752 Rpm
Amount Of Data Sampled When Cylinder Off... 558
Cylinder # 2
Average RPM When Cylinder Stablized... 1540 Rpm
Average RPM When Cylinder Is Off... 1474 Rpm
Average RPM Drop Result... 66 Rpm
Highest RPM Drop... 815 Rpm
Amount Of Data Sampled When Cylinder Off... 541
Cylinder # 3
Average RPM When Cylinder Stablized... 1537 Rpm
Average RPM Drop Result... 65 Rpm
Highest RPM Drop... 837 Rpm
Amount Of Data Sampled When Cylinder Off... 564
Cylinder # 4
Average RPM When Cylinder Is Off... 1467 Rpm
Average RPM Drop Result... 81 Rpm
Amount Of Data Sampled When Cylinder Off... 484
Cylinder # 5
Average RPM When Cylinder Is Off... 1485 Rpm
Amount Of Data Sampled When Cylinder Off... 566
Cylinder # 6
Average RPM When Cylinder Stablized... 1561 Rpm
Average RPM Drop Result... 77 Rpm
Highest RPM Drop... 836 Rpm
Cylinder # 7
Average RPM When Cylinder Stablized... 1555 Rpm
Average RPM Drop Result... 76 Rpm
Highest RPM Drop... 830 Rpm
Amount Of Data Sampled When Cylinder Off... 563
Cylinder # 8
Average RPM When Cylinder Stablized... 1557 Rpm
Average RPM Drop Result... 73 Rpm
Highest RPM Drop... 832 Rpm
