Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Mar 05, 2004 1:51 pm
Realistically, the O2 can only change things 20% [if they are dead] as there is a preprogrammed injector opening time [per rpm and TPS].............the MAF is almost unlimited.
Why you use the Consult at 60 mph flat no acceleration and record all the parameters. Then review the numbers and understand the effects of temperature and barometric pressure for that particular run. Something beyond the average technican.
IF 1.8 millisecs is normal and you read 2.0 millisecs YOU are sending 25% more fuel to the cylinders.
Because the ramp up time is 1.1 miliisecs [1.8 minus 1.1= 0.7.......2.0 minus 1.1= 0.9..........0.9/0.7= 1.2857 = 28.6% more fuel].
AT WOT [high rpm] [11.0 minus 1.1= 9.9 10.8-1.1= 9.7..........onlya 2% variation]
See 0.2 millisecs makes a much much much bigger differece at low duty opening cycles because the opening ramp up time is so significant.
THE FSM shows very broad readings at 2,000 rpm [1.4-1.9 volts for MAF] and [1.7-2.4 millisecs for injector open time] THIS is a 100% variation of fuel. Not possible from atmospheric changes
Yet from 120F to 30F the real variance is only 8%, now altitude could be 15%.
They should have provided a narrower range and a look up table for temp and altitude to help the technican.
You can't assume good means "right on" or anywhere near perfect.
The normal variations on injectors may be 5% so a single dirty one may force that bank to be 5,10,15, even 20% richer to net an average of 14.7 AF at the appropriate O2 sensor.
The Consult shows you left and right bank injector opening time and Average block learn correction from 100% [preprogrammed level].
When one Q gets 22 and another 24 and another 20 mpg at cruise [assuming exactly the same conditions and same brand of fuel in the same city]........you always start with fresh O2 assumming they are over 3 years or 50k, then a rail flush, then an induction clean and flush, a MAF clean, a basic timing check, an isle and running vacuum check, a cat back pressure checks [while you are changing the O2 [using this port to measure backpressure at idle, 2000 rpm and WOT]............lots of these things are never done!
