SFBayQ45 »
https://forums.nicoclub.com/sfbayq45-u9053.html
Mon Aug 30, 2004 11:38 am
Q45tech / Rex - Thank you both for your feedbacks.
So based on your comments, it appears that the tech didn't do the proper testing procedure. Therefore the results are not reliable enough to make an accurate conclusion? To follow-up on Rex's sentiment, does this technicality warrant a second look at no cost...after all, I did pay a pretty penny for this service...
If the thermostat needs to be replace, then I'll replace it. But on the contrary, could it be because my engine isn't warming up fast enough. I noticed on morning warm-ups that even if I let the car idle for 5-10 minutes, the temperature gauge doesn't move one milimeter from the Cold position. Is that normal? It only moves ever so slowly as I begin to drive and rests a few milimeters below 3 o'clock.
Rex - I don't understand the logic of the question below. Could you explains? "Or is that just asking for them to skimp on something elsewhere? (Assuming they get some service work from the diags test)"
The only other test I didn't take advantage of (or more accurately, didn't have the greens to put out) was the compression test. I really wanted to see how the engine has been holding up, but the $500+ in labor cost quickly made me decline the work. I needed confirmation that this engine is worth investing into, since the next major maintenance item is the chain guide replacement. Do you think it's the right decision to invest an additional $2000 now (Cali shop rate, unfortunately not T3 rate).
