Alright guys I'm at this step and I don't have power to the right side of the fuse located in the driver kick panel any suggestions ?????NISTECH wrote:The difference in operation between the 3 modes of opening is the time control unit recieves a signal on terminal 3 when turning the headlights from parking lights to headloghts[the point at which the motors are suppose to operate to up] In the other 2 choices it does not send a signal to that terminal. BUT that circuit also uses its own fuse. so you need to look at the fuse too. Note though that fuse supposedly also powers your marker and tail lights. Still check to make sure the 3rd fuse up on the right side of your fuse box in the drivers kick panel has power on both sides when the switch is turned on. It is a 15 amp fuse. If it does go to the time control unit and do the same test on terminal #3 with the switch turned to the on position. The timer is located in the drivers kick panel, and its black not the colors I mentioned before. When you pull the kick panel trim off you will see 2 controllers one white and one black. the one further in is black, that is the unit your after.
