I must agree. My furnace only runs in the morning and evening. It will drop to high 50s on cold nights around these parts, I sleep like a rock.Dattebayo wrote:78 is warm as hell for me, lol. I'd probably kill your mom.
+1Dattebayo wrote:Maybe what you need is a fan running for the white noise.
themadscientist wrote:They already have zone climate control. It's called getting your own place and paying rent and utilities.
I am actually tempted to move out in a year once I've gotten settled in at my new job and have started full on college.themadscientist wrote:They already have zone climate control. It's called getting your own place and paying rent and utilities.
A little too pricey considering I'll be leaving this house in around two years.C-Kwik wrote:You could do something like this as well:
http://www.google.com/products/catalog? ... CHgQ8wIwAA
Its basically a single room A/C with an external condenser. Might work well for situations like yours and/or rooms that are terribly balanced. Its a bit pricey, but for situations where a home's temperatures way warmer in a particular room, it can be a simple solution. For a more short term solution, you can get one of those portable A/C units for like $400.
Bubba1 wrote:themadscientist wrote:They already have zone climate control. It's called getting your own place and paying rent and utilities.
Aww, you beat me to it.....
Dittoz7 wrote:My house stays at 80. I'm sure people break in while we're not here and grow ganja. Still have yet to catch them in the act.
Dude. Can I live in your house? That sounds like the greatest temperature ever.Jesda wrote:My thermostat is 66-68F all year. Summer power bills are about $310 though.
I make my roommate use his space heater if he has a problem with it.
Jesda wrote: Summer power bills are about $310 though.
The latter option is not out of reach for most people. And zone climate control is likely to require quite a bit of hardware to work correctly. Valves, sensors, wiring, the controller, etc. Not to mention installation of this hardware. And as far as I can tell, the set-up in the link is just programmed to help balance the output. You'ld probably want a system that can apply the A/C to specific rooms. The hardware would be mostly the same, but you'll likely need to find or write code specifically for this. Otherwise, your mom may turn it off regardless...King Ranzo wrote:A little too pricey considering I'll be leaving this house in around two years.
^Jesda wrote:It would probably kill me. My pits dump fluids like:
