timmy0257 wrote:
also, what kind of tire dressing is recommended? i use a cheaper Eagle One spray, but it gets all over my wheels and then the brake dust (although its not alot) gets on it and sticks. just something from an auto parts house is fine with me.
Oh, noes. Not the tire dressing question!
IIRC, Miz B got an earload of advice on that not long ago, so she can probably spare some. Everything from brake fluid to xylene.
Basically anything you spray onto the tire is going to end up on the wheels, whence it will pick up dirt. Whatever I use, I put an old sock over my hand and spray it on that, then rub on the tires. Keeps the initial application off the wheels, and unless you put it on really thick minimizes the "sling" effect.
I don't like shiny tires, so I tend to use "natural finish" Armorall mixed with Mothers Back to Black (about 5:1). I also ran across a fairly new Eagle One gel-type protectant that works well on tires and weathered trim, and is a sort of satin shine, not too gaudy.
