Yep Shatch's right with the ringgears etc. From memory the TT manual is about 5-6mm larger. Diffs for NA are R200 4.1 (R33 GTR ratio, most other skyline r32's are 4.36 or 4.37), TT is R230 at 3.69.I consider the R200 as just awesome. Very strong and mix'n'match for different models. Still a lttle heavy, but naturally strength brings weight and they're not too heavy for most cars me thinks.From memory R230 is 52kg's, r200 is 36kg's. BTW rips in rotorua have a 9 sec car running the gts4 diff (R200) and is approx 800hp. Last I read the factory diff was loving it. Its got an RB30xx.(Dont really follow their cars, but if someone from NZ is reading they may put up a link etc)T45 wrote:From what I gather, the only differences are between the NA and TT rear ends.
TT is 3.xx something and the NA is 4.10 something.
Can we start a new thread regarding rear ends? I mean, this is good info too... but it's not what I had originally wanted the thread to be about.ultrapulse wrote:Yep Shatch's right with the ringgears etc. From memory the TT manual is about 5-6mm larger. Diffs for NA are R200 4.1 (R33 GTR ratio, most other skyline r32's are 4.36 or 4.37), TT is R230 at 3.69.I consider the R200 as just awesome. Very strong and mix'n'match for different models. Still a lttle heavy, but naturally strength brings weight and they're not too heavy for most cars me thinks.From memory R230 is 52kg's, r200 is 36kg's. BTW rips in rotorua have a 9 sec car running the gts4 diff (R200) and is approx 800hp. Last I read the factory diff was loving it. Its got an RB30xx.(Dont really follow their cars, but if someone from NZ is reading they may put up a link etc)
T45 wrote:Sorry for the detour, as a typical male my first thought went to "rear ends".
I don't think I saw that thread... I'll take a look for it and try to get all the info in one place. There's a lot of interest in this engine and a lot of speculation. The data needs to be more organized.T45 wrote:As for the ring gear and VH starter meshing, I think tmorgan had an issue with the Z/truck flywheel being too far away from the VH starter. Maybe he can chime in with his experience. I'm sure you've read it but if you haven't, he had to switch to a Z32 5speed case and use the Z starter.
Thanks!mtcookson wrote:Fixed the title for you, should offer less confusion.
I'm using a VH ring gear on my 300zx N/A flywheel right now.SuperHatch wrote:Flexplate/flywheel ring gear guys... flexplate/flywheel.
I should have been more clear! Cheers!
I'll get exact tooth counts if you want them. But with this info there should be a way to use a Z NA Trans with an NA clutch/flywheel and the stock VH starter if you're having clearance issues around the Z starter.
That's where I was going with this anyway...
That's what it sounds like to me... on both counts.tmorgan4 wrote:What transmission are you using with this? From the sound of your post a 350Z 6-speed?
Are you using a Q45 starter?
Yes, but I also have a GTR AWD transmission for my side project.tmorgan4 wrote:What transmission are you using with this? From the sound of your post a 350Z 6-speed?
Yes, for both set ups.tmorgan4 wrote:Are you using a Q45 starter?
There is also an aftermarket 4.11:1 ratio gearset from Richmond gears available for the R230. I believe it's $800.perana wrote:i just thought every one should know that you get a 4:11 ratio r230 in a z32.its only in the nismo edition z32.mine was a 1999 model i think those were the only nismo zeds,not sure could'nt find out much a bout it very raer.cheers
Raxephon wrote:I'm using a VH ring gear on my 300zx N/A flywheel right now.SuperHatch wrote:Flexplate/flywheel ring gear guys... flexplate/flywheel.
Cut the welds on your VH flexplate ring gear off, do the same to your n/a flywheel ring gear.
Remove both, discarding the original n/a ring gear.
Slap VH ring gear & 300zx n/a flywheel in an oven @ 350 for 5 hours and then slap the ring gear from the VH onto the n/a flywheel. (Use pliers or you'll burn the sh*# out of yourself)
Tack weld it in place and send it to a machine shop to be re-balanced and surfaced.
Starter engagement issues solved. (For me at least)
The Z33 6 speed input shaft is the same size as the 300zx n/a transmission input shaft.
