RobertsnewQ »
https://forums.nicoclub.com/robertsnewq-u29366.html
Thu May 04, 2006 10:12 am
I think I posted this before, but all of the following cars use the same type of Sumitomo fixed caliper and the same pad profile:
R32 GT-R calipers use a 296mm X 32mm rotor
R32 GTs-t and late Z32 use the 280mm X 30mm rotor (late Z32s have iron calipers)
R32 T and R33 GTS4 and early Z32 use 280mm X 26mm
And just for confusion,
R33 GTs-t and R34 GT use a 297mm X 30mmR34 GTT use a 310mm X 30mm
And for comparison, Q45 uses 280mm X 28mm w/ Nissan truck pads
350Z and R33/34 Brembos are 324mm X30mm
The R32 GT-R brakes are the largest you can squeeze under 16" wheels.
Oh, and JDM Subaru WRXs (and USDM from MY 06 on) use the same calipers and pads but I don't know the rotor diameter. So do some Mazda RX-7s from the late 80s. Most Toyota 4WD trucks use a larger iron version of the same caliper.
It would be funny to put the "SUBARU" calipers on your Q.
Modified by RobertsnewQ at 1:30 PM 5/4/2006
