The aspect of the wheel's fitment that you need to be most concerned about isn't the offset, but its disk. That will determine whether a wheel will clear the width of a large caliper or not. For example, you can take two wheels of the exact same width and offset, but different disks, and the lower disk wheel will not clear the calipers. Unfortunately, when buying lower-quality wheels, you are not given much choice in terms of disk sizing, so you're either lucky and get a wheel that happens to have a high enough disk to clear the brakes, or you will have to use spacers to push the wheel out from the calipers. With higher-quality, name-brand wheels you will usually be able to order wheels in different disks in addition to widths and offsets. This image shows the difference between Work's A and O disks in their Euroline DH model. The O disk is the lower of the two (note how the mounting pad is thinner, moving the spokes closer to the hub, which in turn decreases caliper width clearance).http://www.onetongarage.com/misc/work_disks.jpgPoorManQ45 wrote:Wes: What's the minimum offset that you have to have to clear those Z calipers?
The reason I asked is because it appears that the Z's caliper extends farther out towards the wheel spokes. I was wondering if there were any clearance issues with the spokes. I understand that the wheel itself has to be large enough in diameter.one ton garage wrote:The aspect of the wheel's fitment that you need to be most concerned about isn't the offset, but its disk. That will determine whether a wheel will clear the width of a large caliper or not. [/url]
Hmmm... I think you misunderstood my post, as I was referring specifically about what you need to look for in a wheel to have it clear the 4 pot calipers, and it's not a wheel's offset, as the offset alone has no bearing on whether a wheel will clear the brakes or not (i.e. you can have a wheel with -50mm offset that sticks way out, but if it's got a low disk, the spokes will still intefere with the calipers). Diameter is acutally not an issue with the 4 pots, as you can easily fit them under a lot of 15" diameter wheels, so anything 16" and above is usually a non-issue.PoorManQ45 wrote:The reason I asked is because it appears that the Z's caliper extends farther out towards the wheel spokes. I was wondering if there were any clearance issues with the spokes. I understand that the wheel itself has to be large enough in diameter.
Also, drive a Z32 with new pads and rotors and a well-bled brake system, then drive a 240SX or Q45 with same-size calipers with the same make rotors and pads and fluid, also well-bled, and you will notice a difference also (again, especially if you are critical about slight discrepencies in feel). You never HAVE to replace your master cyl to gain an improvement in braking over the sliding calipers, especially since chances are, when you swap the brakes you're also swapping in newer rotors and pads and lines and fluid, so of course you're already going to augment your braking over your existing setup... but you can not discount the fact that ultimately upgrading your master cyl will also net you the best setup in terms of feel.Nismo_Freak wrote:I'm going to stab the next person that talks about master cylinders.
GO out and DRIVE a car with the Z32 brakes, then come back and talk about it... seriously!
Wes, get some aftermarket pads. You will notice a good difference.
Fact: OEM Q45 pads are crap. I drove a Q45 that had about 400 lbs. ripped out of it compared to stock and it felt like I was driving a bus compared to my 240.
Whew! I knew it.elwesso wrote:... TONS of air came out! So im glad i got that taken care of...!
I've been wondering what pads to put on too, for a little more bite.You might try some heat sink grease/compound from the rotor hats to the rims. To pull the heat to the rims.elwesso wrote:... OEM pads are fade city... by the end it had about lost everything...
Another WHEW ! Thought I was losing all credibility.elwesso wrote:I'd recommend this to anyone, great upgrade for the money!
I think i need to rebleed again because the brakes are about where they were.. They were good for a while, then i violated them big time, and theyre not as good anymore.. Im wondering if i glazed the pads... The guy said the fronts were OEM pads but im not sure about that... They could have been POS pads, as they didnt have the "burger" or sumitomo on the back of the pads like the rears did.....squeefoo wrote:Whew! I knew it.
SEE !
Next: brake pedal and pushrod adjustment.
Assuming you meant "floor"PoorManQ45 wrote:If that's the case wouldn't the pedal sink to the flow?
