elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sun May 15, 2005 8:53 am
Before you picture troll, i will post pictures tonight when I get back home.
As a few of you know this was the weekend that I set aside to do my brakes. IT was becoming unbearable how bad things were.... I didnt take a picture of it, but you could see where the pad was being eaten alive.... You could see and feel in the rear rotor where it was being scraped...
Anyway, heres my parts list.
4 Brembo blanks (brand new)Z32 30mm iron calipersOEM pads1 big and 1 small bottle of valvoline synpower brake fluidCaliper greaseBraided SS Z32 240 conversion linesSpeed bleeders
So i got up extra early yesterday to get started. Started with the rear, and everything went smoothly... The hard line fittings are on tight and after some trials, I went right to vicegrips to that, with a very brisk blow, and then they came right off... The rear conversion lines are the same as the Q45 lines except with a shorter banjo bolt... They use a banjo fitting but the seat of the bolt has the inverted flare...
An important step here is the bolts are just ever so slightly too long and mine leaked. That said, if you use 3 copper washers (one on the bolt head side, and 2 on the caliper side) the bolt wont bottom out and leak.... I broke oneof the banjo bolts and had to make a new one out of the Q ones....
Remember to orient so that the bleeder is on the TOP... I was reading about this last night and its something thats very easy to overlook, and can cause woes when trying to bleed your brakes... Theres no difference left ot right except where the bleeder is.!!!
That being said, theres really nothing special about the rear brakes, everything went right on and everything was as smooth as buttuh. Be sure to use plenty of grease, at autozone they have little packets for .99, and I still had some left over.. Grease everything, wherever the pad contacts something.......
Now on to the fronts. This is where a little bit of skill is required. Everything came off just fine. My pads were replaced at exactly the same time and the front pads still have a lot of life left (say over 50%)....
Heres where the modding has to come in. Some people suggested removing that heat sheild, but i didnt see an easy way to do that. I decided to just cut mine. Youll see where it sort of curves around and theres a little tab. I just cut that so it was flat and it worked perfect, with plenty of clearance on both sides....
The front lines have the goofy flared fittings, which really, IMHO, make more sense than those banjo fittings... I think that if the hole on the bolt isnt perfectly lined up with the banjo then it wont be optimal.... Whatever the case is, there isnt QUITE enough room. When the car is unladen, and you turn lock to lock the line bunches a little, however, not a problem when you have the car under weight.
To accomodate this and make sure things fit right, i put my jack under each control arm to simulate it being laden. From there you can align the fitting....
So the results.... THe car is definitely a little smoother overall (from the 5 miles ive driven it thus far), however, i dont think ive bled them right, the pedal is still very mushy.. Im going to have my mechanic rebleed them this week when the car goes in for an oil change.... Ive been putting off my oil change and this will give me some motivation to do that.... Thus, i wont really say what its like until its working right. From what Squeefoo was telling me, its VERY touchy....
Overall, this was definitely a good mod to do if you have 17in wheels or more (for clearance)... I did the math, and doing this upgrade will cost about as much (slightly less) as rehabbing your Q45 brakes, and after that, will be substantially cheaper as the brembo blanks are about 1/2 price of what OEM rotors are.... Im thinking that with the double thickness in the rear and 2mm extra in the front that has to make things last longer.... THese are the brakes that were meant for the car, and had it not been for wheel clearance issues, i think nissan would have used these to begin with!
