Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Dec 23, 2006 7:45 pm
the missing hub bolts are odd on the back of your upright, but that's an easy replacement, grab your hub blts off your upright.
And the e brake issue is solved for me. I just cut out the spacers off my skyline hubs and viola, it works. The only issue I came across with doing this was that the pivot on the driver side rotated and wouldn't rotate back down and contacted the edge of my rotor drum. I had to get a cutting wheel out and chop out some metal off it to get some clearance. Thankfully it wasn't anything too bad.
And other than that, the brake job has been my most annoying job done on this car to date. Rounded flare nuts necessetated replacing hard lines. Both hubs were rust welded to the uprights. It took me an entire day just to get the hubs out so I could swap the backing plates. The rear e brake cables were corroded to the front e brake cable splicer bracket. And nothing I did would get them loose. They wouldn't even burn out, so I'm waiting for a new front e brake cable from midway.
All in all, a simple afternoon swap job has turned into a week long terror. It was every bit of 5 days to get everything done (although I had to admit a lot of that time was spent doing weird parts runs and one junk yard run), except the e brake cable, which won't be bad as soon as my parts get here. Oh, did I mention that both bolts that bolt the front e brake cable to the chassis snapped inside their holes? I think my car just wanted to stick to stock rear brakes ><
