neurovish »
https://forums.nicoclub.com/neurovish-u377.html
Wed Sep 18, 2002 12:54 am
A drift is nothing but maintained oversteer....too much oversteer and you spin, too little oversteer and...well, I guess you'd be understeering or not steering then. The essence of the drift is the midpoint of the extremes...so any car that can spin can drift, you just need to figure out the way to get it on the path to spinning yet keep it from doing so, and there are ff cars that tend to oversteer....anybody played with a ser specv? By Torry's account, it is prone to oversteer....and I hear tales of his car doing the drifting thing prior to being captured by red & blues. I've never tried drifting an ff car, so I can't really say how it's done....although logically it would be similar to rwd initially, only difference is you can't power over into a drift and can't control it as well once it's in the slide. Feint, trail braking, an ebrake can be done with any car though.
My technique/theory?I dunno...still developing.There aren't really any good places around here to practice, just parking lots and wide median u-turns....they'll help you learn how to brake traction and control a slide a bit, but as far as learning goes it's pretty ghetto. For the U I use pretty aggressive feint and power over...I found a good way to practice one night in the rain, run up to the braking zone doing about 50, put the car in neutral and try to throw the back out (don't forget to brake btw). You'll end up doing a lot of understeering, but it's good practice to get a feel for how much you can load up your front tires. This is just to practice getting the rear tires loose, this way you don't have the 'power over' crutch which is so easy to use in wet conditions. BTW...you want to end up doing about 20 - 30 depending on how wide your median is...and I mean big medians, not these wimpy 2 foot sections of cement you see in the middle of roads everwhere, you definately want room for error if you don't plan on walking home.For parking lot drifts, it's pretty much the same thing in the wet, feint and power over but you don't really need to kill as much speed as for the U. In the dry I use a bit of feint and a clutch kick.
If I could have my way, then I'd use nothing but feint and trail braking...give my poor clutch and driveline a rest from the clutch kicks, maybe they'll last a bit longer. I haven't really experimented much with the e-brake, only for the occasional 3 point turn circumvention.
