Slappy »
https://forums.nicoclub.com/slappy-u23761.html
Tue Apr 08, 2008 7:42 pm
First name / car used in event
Thomas , 1993 Nissan 240sx coupe
Event Name , Location & Date
ClubLoose Night Moves Englishtown NJ 3/26/08
How did you think you did?
My 1st two runs were a complete failure , but after some talking to be my good friends and Gerry telling me to get an instructor i did alot better.
Were you happy with your setup?
To early to tell , but i know my recent alignment settings makes my car very loose in the rear (oversteer)
What you plan to work on next event
Try and make sence of all those cones and get my line down
ClubLoose Night Moves Englishtown NJ 4/30/08
I went in thinking i was going to do better then last time but the course had so much gravel and clag built up online that i plowed each time entering the 1st right hand sweeper. They changed the layout some by making the 1st corner very wide and doing away with the "donut" around the light pole
Entering the 1st corner there was some understeer , then once i would go to correct , there would be crazy oversteer. That lot was like ice tonight. I dropped the tire pressure in the front tires and that seemed to help some. I did lower the rear of my car 0.5" and im not sure if that was causing the understeer issue.
Forget about balls out entry speed and just get some clean runs in.
ClubLoose Night Moves Englishtown NJ 7/30/08
I made it into B group!!!!
Yes , very. Falken RT615'S @ 55PSI Rock!!!!! (rear)
Less spins, and listen to all the advice like i did tonight. Listening to what Petty , Gerry and the other guy in the stands had to say helped me out ten fold. It was crazy that i was getting so many compliments from everyone , and i was happy that those cats i was getting along with all night made it into B group as well.
All Star Bash East Coast /Clubloose 8/16/08
My 1st runs are always bad because my memory is nonexistent , but once Petty showed me the way i killed it all day , except for the very last run of the day. I was pushing it to hard and spun twice.
Yes , very happy , except for the fact that i now need to upgrade my cooling system.
Earlier , faster entry
Clubloose Advanced Day , Englishtown NJ 10/24/08
I think i did pretty well considering how tricky the Kart track was tonight for people with NA KA's. The 1st corner was balls out so i was flat in 3rd gear. The layout was a wide right hand sweeper, into a hairpin style 180 , and a easy left hand sweeper , then a right then done. Either you went in fast and hard as **** , and miss the 180 cause you couldnt keep the rears spinning , or go late into the 1st corner and make it.
Always happy with my setup. The car performed awesome. I tried a new tire out tonight , the Falken Ziex Ze 502 (rears). What a killer tire for the price. Awesome grip and tons of freakin smoke. Once it got to be pretty late in the night , the tires started to finally feel slushy and lost grip, but after i took out 15psi , they came right back to life. One thing , i wouldnt mind just a tad more HP.
Well , i cant enter any faster then i was tonight on the Kart track unless they make the entrance longer or i get more hp.
Modified by Slappy at 4:19 PM 11/26/2008
