1- pull out headlight button2- cut brown wire3- e tape both ends of wire4- enjoyGcustoms wrote: rather than mess around with wiring?
maybe so, but none are as simple. he's worried about wiring on sleepy eyes...he doesnt need to fool around with boxes with knobs. he needs to cut a brown wire.BrianHarte wrote:
Because there are COOLER ways to do it.
do you write for superstreet?BrianHarte wrote:
+street cred and JDM cred.
I have a Pivot controller in my garage. I need to install it soon. Found this is the best instruction.BrianHarte wrote:I wired in my PIVOT headlight controller.
I SUCK SO BAD at wiring..... and i managed to do this myself.
it might not be a lot, but when you can get the same effect for $0 its crazy. 50 bucks is more then a full tank of gas, more then admission to a local auto x, more then i spent to do all my wiring even. idk i can think of better ways to spend $50 but it is cool i supposeBrianHarte wrote:pocket change
So lets go back and forth for a month about it. Neither way is right or wrong. Just that one of you has put more thought into it then the other with the pivot switch. And you dont get the same effect, the pivot switch is obviously adjustable, where just cutting wires is a more permanent postion for the lights.White Comet wrote:it might not be a lot, but when you can get the same effect for $0 its crazy. 50 bucks is more then a full tank of gas, more then admission to a local auto x, more then i spent to do all my wiring even. idk i can think of better ways to spend $50 but it is cool i suppose
Actually, no, you can adjust lights by double clicking it. It's just more steps to go through.blacksrjdm wrote:
thats actually pretty sick.
yeah it is more steps, but i don't mind. i'm not saying the pivot box is bad. on the contrary, it seems pretty nice, but the price tag just kills it for me94_240sx wrote:
http://www.youtube.com/watch?v=PcaLnkI5UmE
Are those offroad lights stuck in ur bumper?Gcustoms wrote:After listening to people argue for the 2 days that i was away, i tried what seemed like the simplest yet most functional way of all of them, all i did was flipped the lights on, (lights come up) hit the toggle switch to make them stay up and turn the lights off (lights stay up) i then pulled the 5a fuse and put it in just far enough to work, but so i could yank it without trouble, i hit the toggle switch and at the right time i pulled the fuse, this was the result:
