Use a 5mm allen socket instead of allen wrench! Make sure if you use wire ties you position them out the way of new parts! Old style guides are different in size from the new Tension side guides and if you leave no slack in chains it will be hard to maneuver Tension Side Guides around chains! I don't like the red RTV so I would use something else like Permatec Gray! If you haven't replaced water pump you should plus gives more space to work around Lower cover! Drain all Anti-Freeze even from block freeze plugs to keep matting surfaces from contamination! I also checked timing with timing light before and after finishing work to make sure they are the same! Be careful not to pinch cylinder head gasket when installing front cover back on engine! Check position of front crank seal before removing and re-install exactly the same way! Make sure you have a feeler gauge to set oil pump chain to upper guide chain clearance! I use a two foot 5/16" piece of hose to fish out any broken guide pieces from oil pan!PopPop wrote: Are you removing your valve covers also or just front cover?
Man, this is awesome info you just don't get from the FSM! I'm about to embark on the same journey and I can tell ya, I'll be studing this and other threads closely! Thanks again for all the info.PopPop wrote: Use a 5mm allen socket instead of allen wrench! Make sure if you use wire ties you position them out the way of new parts! Old style guides are different in size from the new Tension side guides and if you leave no slack in chains it will be hard to maneuver Tension Side Guides around chains! I don't like the red RTV so I would use something else like Permatec Gray! If you haven't replaced water pump you should plus gives more space to work around Lower cover! Drain all Anti-Freeze even from block freeze plugs to keep matting surfaces from contamination! I also checked timing with timing light before and after finishing work to make sure they are the same! Be careful not to pinch cylinder head gasket when installing front cover back on engine! Check position of front crank seal before removing and re-install exactly the same way! Make sure you have a feeler gauge to set oil pump chain to upper guide chain clearance! I use a two foot 5/16" piece of hose to fish out any broken guide pieces from oil pan!
Ahhhhh, the magic that is Gulati (and Stinson)It's a wonderful thing.... people fixing their own cars.....But some lucky people get a gem dropped right into their laps!!!!(A sand coloured, pie panned, gem!)Jesda wrote:Just a few short years ago, DIYers didn't dare replace their own guides. Now people on NICO are saving their Qs by themselves.
Glad I could help!ozzie! wrote:
The most helpful piece of info was tapping the front edge of the oil pan down to make room for the cover to go back on......
REMEMBER THIS!!!!
Although I have never done this job, I never thought it looked to hard. I don't see why more guys arent doing the job themselves.Jesda wrote:Just a few short years ago, DIYers didn't dare replace their own guides. Now people on NICO are saving their Qs by themselves.
its definitely not for the feint of heart, you gotta have some experience working on cars before you attempt this...Q_SHIP wrote:Although I have never done this job, I never thought it looked to hard. I don't see why more guys arent doing the job themselves.
Well maybe thats why then. I work on my own stuff unless I don't have the time.elwesso wrote:
Might make an interesting article as addenda to the existing one (hint) A check list of do's and don't's. Easy to research too....elwesso wrote:just to expand on what you were thinking, it is a fairly straightforeward job, but theres a lot that cna go wrong in the process
1.) Then why did you change them? Get my drift?ozzie! wrote:1.) Has been running ok for god knows how long on broken guides....So the pieces in the sump aren't a huge concern,
2.) I will be dropping the oil pan for the next oil change, due in 3 weeks....Till then, I intend on taking it easy with my driving, as before when the guides were being shipped...
3.) The place i found the large broken piece suggests that the other pieces could have been caught the same way, and ground down to granules by the chains... In which case, the may have made it to the oil filter in a grit form...
4.) I guess I will know for sure in about 3 weeks!
