r34 gtr »
https://forums.nicoclub.com/r34-gtr-u3863.html
Fri Apr 04, 2008 5:47 am
Its dead easy to remove the intake manifold! Its your lucky day!
You will need:Beer10, 12, and 14mm sockets (6pt, non-deep wall)3" 6" 12" extensionssocket wrenchPhillips screwdriverpliers
Drain coolant, unhook upper rad. hose from the thermostat housing.
Remove idle valves and crap, or just unplug them.
Remove dumb intake manifold braces. Leave removed when done, as they don't do a thing but get in the way and they weigh a total of about 30lbs. This may involve unhooking wires from the alternator and knock sensor, as they may have been routed through the middle of one of those dumb brackets.
Unbolt the fuel rail from the upper manifold. (10mm I think)
Remove harness ground wires from intake manifold, and pretty much just try to unhook that whole section of engine harness, and pull it out of the way. Everything from the CAS to the TPS to the coil packs. Just get it out of there to make it easy.
Get yer 14mm socket and big extensions
Remove upper manifold 1st (the bolts are actually easy to get to!) Get in there from the side. Youll have to look between the runners to see the bolts.
Once this upper manifold is clear (you'll probably have to pull the fuel lines off to get the FPR out of there) You can remove the fuel rail and injectors.
Remove lower manifold.
While you are in there, you might as well ditch the butterflies and port match the biach.
Thats about it. Just do everything in reverse to get it back together. RTV silicone the gaskets to ensure there will be no leaks.
