I've been schooled on this from listening to fellow y33 owners like Falk and others and have picked up some things from my own experience also. If you plan on lowering your car, I say go with the 19s if you don't want to worry about rubbing. I think you should be able to get away with 19x9 with and offset of 20 to get that flush look. Also, you might consider running a staggered look. As for tires it depends on if you're a fan of the stretched look. If so, I think Falkens would be your best bet as most use them. And I've seen some mild to wild selections, but that part is up to you. Find the style of wheels you want then worry about the tires.TrizzyDizzy wrote:Ok, so wheels are generally the first thing any Infiniti owner considers right after buying a car. Well i basically wanna know what my options are for buying a set of wheels. I generally sold on either 19s or possibly 20s. I would like the front and rear to be atleast 8" wide, but no more than 9.5" in the back. So what offset combinations can i run? Also, what would be an appropriate tire size to prevent any rubbing (i dont mind rolling the fenders).
Ive also noticed that clublexus has alot more of a variety of used wheels going through their marketplace, would i be able to use most of their sets if i decided to go with a used set?
Thanks for you time!
Exactly backasswards if you are interested in safety and performance.Solini wrote: Find the style of wheels you want then worry about the tires.
What sense would it make if he decides on tires that meet the load ratings and speed ratings for his car but decides on some cheap @$$ wheels that aren't strong enough to support his car??? Aren't you the one who's always asking about weight and strength of wheels?maxnix wrote:Exactly backasswards if you are interested in safety and performance.
Solini wrote:What sense would it make if he decides on tires that meet the load ratings and speed ratings for his car but decides on some cheap @$$ wheels that aren't strong enough to support his car??? Aren't you the one who's always asking about weight and strength of wheels?
Must read the whole post to comprehend it. Maybe invest in a little thought and reflection also.maxnix wrote:Determine the tire required first based on load and speed requirements with an eye to size, then determine which wheels will fit and are strong enough without incurring a substantial weight penalty.
I understand that you were talking about aftermarket wheels that were on a Lexus, but could fit your car. The problem with that is you are not going to find the right fitment and you will also lose a lot of lip.TrizzyDizzy wrote:As in flush... i mean with a slight bit of negative camber (basically what lowering springs would give me), i want the lip of the wheel to run down at an angle. Have the tire tucked underneath it (stretched).
I dont want stock lexus wheels, i was talkin about aftermarket wheels that were originally used (and sized) for lexus/toyota cars. But i figure id need atleast a 30mm spacer to mount on anything i see over at clublexus.com.
I think I'm on his ignore listFalkdesigns wrote:Yeah, sometimes Brian (Maxnix) posts things like this when he's really got nothing to add. I think everyone but him knew you weren't talking about stock Lexus wheels.
Yeah I wanted 9.5 and 10.5 but AME only makes up to a 10" width Sounds like your "EXE" tastes are exactly like mine; a super clean look while still being realistic.Falkdesigns wrote:Anyhow, I'd run 235 fronts on my 8' front rims if only someone made a 94 load rated 235/35-19 wheel. I like the way the 275 fits my rear 9.5" rim, but the front is a little too straight up for me. I'm not a fan of extreme stretch, but I do like a mild stretch. If I could, I'd have 19x9.5 front and 19x10.5 rears with 245 front and 275, to me that would be tit's.
IIRC, they'll be fine, may be a little sunken for some tastes.kg03 wrote:I have the opportunity to get a set of OEM 19's off of a G35 with a 19 x 8.0" in front and 19 x 8.5" in back and The tires are Bridgestone Potenza RE050A and measure 225/40/19 up front and 245/40/19 in back. Would these fit according to the standards and best practices mentioned above with respect to tire selection for a y33. I don't plan on lowering and I don't like the "camber" look. I don't want to have the fenders rolled either.
Any suggestions?
thanx in advance.
Kevin, the wheels he referencing are 8" & 8.5" with 30 & 33, or something very close to that.Falkdesigns wrote:If you can find the offsets for the wheels we can let you know easily. Stock Q (Y33) wheels are about +40, which is really sunken in. And you'll definitely need to replace at least two of the tires (load rating on 225 is way under the min. 94 needed), the 245's on the rears are what you'll need for the front, you'll need 255, 265 or 275 for the rear.
Not at all, so long it a nice quality hub-centric spacer like H&R.kg03 wrote:would the hub centric spacers affect the structural integrity of the suspension and hubs?
Exactly.cullenj76 wrote:Not at all, so long it a nice quality hub-centric spacer like H&R.
Our sponsor, http://www.tirerack.com, sells H&R spacers.
Well, it is an inert piece mechanically connected to neither the wheel nor the hub, so the bolts have more stress on them due to the increased leverage. And there is some added unsprung mass.cullenj76 wrote:Not at all, so long it a nice quality hub-centric spacer like H&R.
