maxnix wrote:If a turbine sensor is leaking, it is deemed failed.
Fair enough, I'll go ahead and replace it then.so then I need to build a todo list for the Q I'm buying next week (pending my bank that is)... its a 97 non touring and has 97Kmi and dealer inspection showed leaking turbine sensor, leaking valve cover gasket and a cracked strut mount.
Todo list with the new Q, in this order:replace turbine sensor.flush fluids: brake, ATF, PS, diff, oil.(is that all of them?)replace valve cover gaskets and spark plugs while in there.run a can of that BG44K stuff through there that you guys call magic sauce.lower with teins and KYB's, fix strut mount while here.Wheels & tiresPaint front bumper (has a bunch of scuff marks on it) and lower valences.Tint windowsStereo
