Xentec HID Problem....HELP PLEASE!
SneakyFish
Car: 2008 Altima Coupe 3.5SE CVT
thanks stryker. its very much appreciated i know its somewhat of a hassel to take and put everything back on
Stryker617
Car: 2008 Nissan Altima Coupe 2.5S (Dark Slate)
Ok, here are the pics. The electrical tape is around those 2 prongs. They slide into the clip. Mine were a little loose, but stayed. Make sure you disconnect the battery, and test them before taping them up. And don't let them touch!
SneakyFish
thanks stryker for the pics. i think your kit is diff from mines cause some of my wire dont look similar. but either way thanks. it is very much appreciated.
SneakyFish
i tried installing the hids again yesterday and they WORK!!! they look great! thanks everyone for the help
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
BlackNWhite wrote:Those parts that both of you are having trouble with the fitment, I never had a problem with it.
The reason I never had a problem with those parts is because I did my install using an HID relay kit. I'm assuming you guys are connecting them to your car with no relay protection. With the HID relay, you don't use these parts that are a problem for you, you use the connectors that come with the relay kit and those connections fit like a glove.
I got it for about 20 bucks shipped on ebay. Just type, "hid relay kit" and look for a seller that has NY in his name. I think it's like NYdirect or something.
How hard is it to install the HID relay?? I installed the HID's myself for both the fogs and headlights so should I be able to install the relay as well?
BlackNWhite
Yes, you can do it yourself. It's simply a connection to the battery and then directly connects to the OEM harness on the driver's side. Then the relay is what you connect to your HIDs.
MattyJatz
Car: 2009 Altima Coupe 2.5s
Question,
Would anyone happen to know where I can purchase a Xentec ballast? When I originally got this kit I did not buy a relay harness. Needless to say, my driverside headlight went out. I bought a relay harness to see if this would fix the problem and it didn't. I think the ballast is bad because I plugged in the bulb into the other side and it worked fine and vise versa.
I cannot get ahold of the dude on ebay where I purchased the Kit so I guess I need to order another ballast?! Help would be much appreciated!
