numbnuts240 wrote:you can use discarded condoms to make balloon animals at kids' parties.
I dont think thats very sanitary... ^^scotty-2-forty wrote:numbnuts240 wrote:you can use discarded condoms to make balloon animals at kids' parties.![]()
Thanx for the new sig numbnuts.numbnuts240 wrote:you can use discarded condoms to make balloon animals at kids' parties.
You may have warped your head from overheating now since you ran it for so long while overheating. DOHC KAs don't like to be overheated for very long. That wasn't very smart...xxmarcusrxx wrote:WTF this is ridiculous, Its been running for like 30 mins and the temp is staying right under the *H a little water is barely trickling from the blurp hole (when thermo is all the way open it streams out), no air bubbles, and it never gets hotter or colder just stuck there.
^^^^^OutToWinPAHC wrote:did you install the thermostat correctly? With the vent hole on top?
Beat me to it.OutToWinPAHC wrote:did you install the thermostat correctly? With the vent hole on top?
OM3GA wrote:get one of theses and youll never have a coolant bleeding problem again
JKL1031 wrote:A little birdie told me that the 10mm bolt by the intake manifold above the water outlet can be used to bleed the coolant.
+1 Thats the way I've always done it and never had any problems at alls13sickboi wrote:or open the 10mm bolt and add coolant till it starts comming out of the hole. cheap, eazy, done.
Strange, i have never seen that work before. I know how it is supposed to work but it still just does not. Glad to hear you two had luck with that though.or open the 10mm bolt and add coolant till it starts comming out of the hole. cheap, eazy, done.
