WTF THERMOSTAT!?!?
JKL1031
i didnnt actually. im thinking about putting a dissolvable pill in that hoe to keep it open at first, and run the rad cap off a bit.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
OM3GA wrote: Strange, i have never seen that work before. I know how it is supposed to work but it still just does not. Glad to hear you two had luck with that though. :bigthumb:
Yeah, I'm not sure where all the trouble comes from. I've used the bleeder screw with brand new motors completely empty of coolant and never once had problems with bubbles in the system or overheating. :gotme
JKL1031
hell ive tried it all
JKL1031
can anyone tell me quickly which side of the thermostat has the temp sensing element. the side into the block, or facing the radiator?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I dont know, but I know it shows a pic of it in the FSM link in sig.
JKL1031
in the mean time could i clamp my lower hose to restrict the flow for more heat. im not really driving to much at the moment.
JKL1031
I got it back from a professional and now it slightly begeins to overheat. the the tstat seems to open up and i felt the bottom hose get hot once. and now its back cool.
Does the sttat only open when its hot or is it supposed to stay open or slightly open at all times?
JKL1031
So if my head compression comes back ok, cand I only have a problem with the TSTAT in, and uve bled and tried all hell, would drilling the jiggle valve hole open, or running a Swirl pot eliminate the air problem?
JKL1031
^bump.
PEZi
run it t-statless and see if the problem still exists? :gotme
JKL1031
it doesnt
DamonDread
Car: 1987 Toyota Supra Turbo
boil water, throw t-stat in, see wich end pops open.
JKL1031
Oh im wayy past all of that BTW. Ive ruled out everything, and im up to the head. hadnt got it pressure checked yet. Im just looking at after the check, if its good, then what.
GTR PrYdE
Car: 1993 Nissan 240SX, 2003 Evolution VIII
Im using an autozone tstat because I couldn't get the nissan tstat to work.
Even with the autozone, had to jack up the car til it got too hot, cool down, add coolant, repeat.
Drive the car down the block til it got hot, park it and do the same thing. Over and over til I got all the air out.
It doesnt help that my autometer water temp is in place of the bleeder screw, and the stock temp sensor is unplugged(it's not accurate at all)
GTR PrYdE
Im strongly considering drilling tiny holes in the nissan thermostat to fix this issue.
Next time though, when I replace it with a mishimoto.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
mishimoto ehhh china made junk
JKL1031
yea i tried drilling holes in it today, and it seems to be tough metal or i had the wrong bit.
So if its an air problem, holes would work it out? It runs fine without the tstat. im guessing it would take longer to warm up. how many holes and at what size? I have another mechanic that is going to bleed it for me again tomorrow. Last time another guy bled it, i drove 2 hours before the car got hot. it climbed, then went down. 30 mins. later it got hot hot.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Sounds like you need to rent a cooling pressure tester and check for leaks
GTR PrYdE
JKL1031 wrote:yea i tried drilling holes in it today, and it seems to be tough metal or i had the wrong bit.
Air is the problem. After it starts to get hot, park and and fill it back up each time it cools.
It should take a little water each time.
Make whatever size holes you can and try the top 1/3 of the thermo?
It's a royal pain but I can assure you it's all the air to blame.
GTR PrYdE
I forgot to add,
the autozone thermo I have has a weaker spring than the Nissan one so I was able to jam 2 aspirins in and get most of the air out, but it still took forever to get the rest lol.
JKL1031
Pressure test has been done as well. Ive bought this car in october, parked it in december for winter, hadnt drove it since.
Next time I'll bleed twice then. Try holes maybe next.
JKL1031
I didnt a chance to work with it, but im going to go ahead and over a swirl pot/ surge tank.
JKL1031
just an update, its warm again, so i pick te car up from shop that was looking for me a new engine. I remove the Tstat, drove the car 130 miles in 74F weather, at operating temp the hold time, and hoses are holding pressure, however both did feel a bit warm. Is there a chance that i still have an internal leak?
