GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Sat Sep 13, 2008 4:51 pm
A few more possibilities and choices:
1) read all of the stuff below
2) remove the plugs and do a compression check
3) squirt some oil in each cylinder, re-check compression, if the readings were low to begin with, install the plugs and try starting the engine
4) disconnect (one at a time and except maybe the two for the O2 sensors) every connector that you can find under the hood, lube the contacts with dielectric grease, reconnect them and try to start the engine each time.
5) disconnect (one at a time again), clean-up and reconnect every engine compartment ground wire and cable that you can find (fuel rail to the engine, engine to the body, etc).
5) rings are not sealing or valves are not opening and closing, meaning you need to circulate some engine oil, or there is a bad electrical connection? Take your pick.
6) search the forums/internet....more
--------------------------------------------------------------------------------------- « Re: Q45 Engine won't start: any thoughts? (maxnix) 3:41 PM 11/28/2005
OK, here's what happened. I did have an early Christmas!
An infinity dealer mechanic told me it was a long shot, but there was a chance that the "hydraulic lifters" had bled down. He said that he had seen it once in his 17 years as an Infinity mechanic.
He suggested that the lifters were holding the valves open, thus no compression. And I tell you that the engine was spinning fast a freely when it wouldn't start. The crankshaft was turning, the camshaft was turning, but the lifters weren't moving the valves. The engine must have compression, fire, and gas to start.
His suggestion was to hold the gas pedal down, simulating the choke effect, and just crank the engine until the engine starts. And that it might take three to eight minutes to start.
So, the engine had been pronounced dead by timing chain suicide by five mechanics and had been down for five weeks. I was sick because I had just put 1800$ into new AC and alternator.
So I ran over to the shop late in the evening and turned it over two minutes before the battery ran down. At the last second I detected an firing event.We charged the new battery up next morning, and cranked on it for three minutes.By the Grace of God it started! Ran like nothing ever happened, like it did before, which is smooth as silk! The mechanic was duh..duh..duh all over himself.
Ok, so the lifters bled down. I still don't know what that really means, but it's the best Christmas gift of the year!
bravetex---------------------------------------------------------------------------------------
DrewQ45
Well, I think your tech. got the right fix, but for the wrong reason! It's very, very, common for these engines to flood during cold weather if they aren't allowed to warm up properly after a cold start and then shut down. A typical scenario is someone starts the car to move it to a different space, then tuns the car off in less than a minute.What's happening is the ECU is set up to send a very heavy hit of fuel to the cylinders while trying to start in cold weather. Esentially it's a choke - but instead of removing air, it adds fuel - same effect on the fuel mixture, but different route. But - if the car is turned off soon after start-up, all of that extra fuel is left sitting in the cylinders. Then it washes the oil off of the cylinder rings.... so compression is lost. "Flooring" the pedal during cranking is the ECU's signal that the driver thinks the engine is flooded so it shuts off injectors...
Heath
Modified by GerryO at 8:07 PM 9/13/2008
