I'm thinking the same thing. How does a bad flywheel cause the revving problem you are having?yodawill2000 wrote:The engine Bucking and not going past 3 K rpm.
Bucking and rpm limited symptoms sound MAF, TPS, KS, ECM or transmission related to me. The flywheel is just a heavy round hunk of metal with teeth around the outside for the purposes of engaging the starter to crank the engine and to smooth the feel of the engine a bit. Were not talking manual transmission related clutch engaging surfaces either and I doubt that a loose flywheel would cause even vaguely similar problems.yodawill2000 wrote:The engine Bucking and not going past 3 K rpm.
No not the bucking, it won't start. The fly wheel and the starter solenoid are bad. What is TPS and KS?GerryO wrote:
So much to look forward to, and remember it's all about inputs and outputs, and very simple once you've found the solution.
I'd pull the starter to check the teeth on it, along with those on the flywheel, if you haven't already done so.yodawill2000 wrote:Throttle position sensor and Knock sensor.
By Bad do you mean the flywheel is missing teeth ?
yes it is (black interior) and the mats are plain old black. Thanks guys but I really don't want to waist anymore time or money with this car. I lost my job because of this car! So now its time to move on. Thanks everyoneGerryO wrote:
Is your (j30wizz) interior black and if it is, what does your rear mat look like?
Ok then, CYA!!!j30wizz wrote:Thanks guys but I really don't want to waist anymore time or money with this car. I lost my job because of this car! So now its time to move on. Thanks everyone
