No adjustment needed, you just hafta use the j30 calipers brackets with the j30 calipers, as the j30 calipers wont mount on the s13 caliper brackets. Also the j30 pads are bigger so they wont fit into the slots on the s13 bracket.Ajax wrote:So how did you adjust to fit the new calipers on? Did I miss something here?
Nah no misunderstanding lol. Some of the calipers may be interchangable with other brackets, like the s13/s14, or the j30/q45. But using the j30 and q45 calipers on the s13 brackets just won't work. For example the j30/q45 pads are bigger and since they sit on the brackets they wont work on the s13 brackets which are fitted for the smaller s13 pads. And for the z32/r32 calipers I don't know for sure if you need their brackets or not, since their pads are fitted/seated on the inside of the calipers with pins that slide through the pads themselves.SeVa-S13 wrote:I think he misunderstood or something. I'm pretty sure S13/S14/J30/Q45/Z32/R32 and evern some Maximas have interchangeable calipers, as in they'll all bolt up to eachother's mounting brackets.
Thanks for the complement. I pick up these goodies along with abunch of stuff for my CA and s14 manual seatbelt for 27 bucks. Granted it was half off weekend but still I was stoked. But if your heading to pick and pull this weekend is half off again! may 20-21 dont miss out.mrgreeneyes wrote:awesome write up and ballsy drilling. you may wanna remove some of those " " marks. kinda threw me off when reading it. otherwise awesome stuff man... approx pick and pull price on that setup?
Thanks, I definately notice a good difference with the stopping power and responsiveness. I couldn't give you precise distances but yesterday this lady decided to pull out right in front of me. I just barely missed hitting her, if I still had the stock s13 front brakes I know for sure I would have rear ended her.lofapoo wrote:Excellent write-up!
How do the new brakes feel?
Any difference in stopping power/distance? I'm sure there is, but how significant, that is the question
That's a very interesting point. I never thought about it that way. The brake rotor is not at all lug-centric like the wheels(technically hub centric, but also use centering via tapered lug seats), and is centered by the hub.cdlong wrote:driling the rotors like that is fine. the center hole centers the rotor so there is no way of causing vibration with crooked drilling. if the holes are off, the rotor won't fit on. if that's the case, just make them bigger. the lugnut holes are just a place for the lugs to go.
even if you screw the holes up royaly, the original hole and wheel clamping force will be enough to keep the rotor from rotating on the hub.
yep. like a lot of stuff on nissans, the same across the board.naed240sx wrote:Edit: This is of course assuming that the Z hub bore is 63mm like the s chassis bore. Is this correct?
ZOOOOMMBBIIIEE BUMP!swpS13 wrote:sorry for bringing up a dead thread. i already have 5 lugs on my s14 so would everything just bolt right up Caliper, rotors? and my own brake lines? Thanks guys
easier than you thinkswpS13 wrote:sorry for bringing up a dead thread. i already have 5 lugs on my s14 so would everything just bolt right up Caliper, rotors? and my own brake lines? Thanks guys
Indeed. Take the whole rear knuckles and use the ebrake and everything.Chris28 wrote:Rear 5 lug hubs will bolt on
