Not at all. In fact, I never noticed any "regional retardation" in your posts, and just now realized you're in NY. Well-done, sir!OriginalWheelman wrote:
Is that directed at me?
I disagree with you! [insert personal attack] This clearly shows you are wrong [insert slanted link that says exactly what I need to prove my point while dismissing any that are counter or suggest any middle ground]Beancooker wrote:After reading many threads in this forum, I have come to one realization. No matter how hard one side argues their point, the other side will never agree.
This is no different than having a discussion about religion, and which religion is closest to God.
Discuss?
I should have been a little clearer. Lemme get out the Crayola.rn79870 wrote:
Seriously Beanor, allowing people to pick and choose which laws they like and therefore will obey is a little far fetched. You can't be serious about that.
You are a [insert political or idealogical slur] which means you are wrong because you think differently than me and I have clearly established I am right.
Exactly.C-Kwik wrote:
I wouldn't call it multi-faceted. They are tied together, but the underlying reason for the law to exist is BECAUSE of the environmental impact. His point as I interpret it is that there are those who will be critical of someone as a matter of law and not the intent of the law. The former being of no relevance without the latter. Its a kind of cart before the horse issue...
Without looking I assume Bob and Telco have posted in it.....Beancooker wrote:But this thread has been spun so far off course at this point, it's pretty much a wasted conversation.
Rough time? Not at all ... they simply dislike trolls as much as I do.telcoman wrote:Gregg and Bud are having a rough time dealing with the truth especially to those that make them aware of it.
I don;t consider myself part of a party. I'm a registered Republican, but only so I can vote in their primary. I'm Republican in an economic sense, but I tend to side with the dems on a lot of social things, or rather, what the dems preach. The reason I am so anti-democrat is because almost every democrat I've met is a self serving hypocrite that preaches the message of "tolerance and fairness" only so they can think that they are superior to those who "follow an antiquated religion". I'll tell you what, if you read the bible, whether you believe it as a religious text or not, it is a damned good set of rules to live by. I should know, I've read it cover to cover. Most "Christians" I know can't say that. Before I go off about Christians... The republican party is often labeled as stagnant and trying to keep the status quo. If you really look at it though, the republicans have most of what they want, and they are trying to keep it that way. Can you blame them? If it were the republicans trying to get things their way, the roles would be reversed and the dems would be the "stagnant" ones resisting change. I love how some people always assume change is for the better. Just because the Republicans want things to stay the same doesn't make them wrong.Marenta wrote:what events in your life made you choose the party or stance that you go with now?
You know, we probably have more in common than either one of us think.OriginalWheelman wrote:I'll tell you what, if you read the bible, whether you believe it as a religious text or not, it is a damned good set of rules to live by. I should know, I've read it cover to cover. Most "Christians" I know can't say that.
Probably. I don't have a problem with your beliefs, more the way you insist your position is absolute.HashiriyaS14 wrote:
You just keep thinking that, if it makes you feel better.telcoman wrote:Gregg and Bud are having a rough time dealing with the truth especially to those that make them aware of it.
Funny, I feel that most of the Republican politicians are self-serving hypocrites. Christian in their so-called beliefs, pretty much the opposite in their actions.OriginalWheelman wrote:The reason I am so anti-democrat is because almost every democrat I've met is a self serving hypocrite that preaches the message of "tolerance and fairness" only so they can think that they are superior to those who "follow an antiquated religion". I'll tell you what, if you read the bible, whether you believe it as a religious text or not, it is a damned good set of rules to live by.
Sure, let's throw a little insult in now and again.Beancooker wrote:I should have been a little clearer. Lemme get out the Crayola.
I could care less if anyone break the law, but that doesn't mean I don't applaud when they get caught. It also doesn't mean I don't try and make them aware of the consquences.Beancooker wrote:I used test pipes as an example.
Some people (like you) get just as ruffled about someone breaking the law, as say the environmental impact that using a test pipe could have.
That's false circular logic. You can't protect the environment by breaking laws designed to protect it.Beancooker wrote:Really, I don't give a damn about some law that says I have to be good to the trees. Personally I don't run test pipes, because it's not worth the 5hp gain to have a CEL.
I would feel worse about potentially hurting the environment, than some petty law that is suppose to protect it.
A civilized society requires that citizens follow a prescribed set of rules that are designed for the greater good of all. There are means available to change laws that someone disagree with, other than simply disobeying them. So yes, we all have an obligation to follow "unreasonable" laws at the expense of allowing each person to pick and choose what he feels are the "reasonable" ones.Beancooker wrote:The point I was trying to make was that there are people who are worried more about the law, only because it is a law. No matter how irrational it is.
If it were 20 HP we were talking about, I would have a set of test pipes.rn79870 wrote:That's false circular logic. You can't protect the environment by breaking laws designed to protect it.
You pretty much understand my effed up logic. Protect the environment all you want, as long as it doesn't interfere with my RWHP.Bob wrote:If I understand what you're saying, you believe it's reasonable to protect the environment, but not unreasonable to break any laws a person doesn't like that are designed to protect it.
Beancooker wrote:
Exactly.
When a child is kidnaped, raped and killed by a grown man, and the father of the child seeks vengence, and executes the person who destroyed his child's life, then there are the people who say that the father should be tried for murder.
Beaner, you got it all wrongBeancooker wrote:
That is the best diagram of the kind of Change we need I've ever seen. Good find Matt.audtatious wrote:
WHAT????????rn79870 wrote:When a child is kidnaped, raped and killed by a grown man, and the father of the child seeks vengence, and executes the person who destroyed his child's life, then there are the people who say that the father should be tried for murder.
Absolutely. He should be tried, and convicted of murder. If there is any justice he will receive some leniency in sentencing. The legal system has been very effective at putting murderers behind bars, even executing them. We don't need a nation of vigilantes running off half cocked in the name of justice. I agree with the emotion behind your thought, but not the practical application of it.
LOL, please give us an example of this because this seems pretty far fetched.AZhitman wrote:I've done a TON of reading in response to posts from Bob and Howie and ish that made me think, "Wait a minute - Let me read up on that."
That is exactly right!Beancooker wrote:That's the problem with our judicial system. We aren't hard enough on criminals. If people knew they would suffer a terrible death, instead of a few years of incarceration/rehabilitation, crime would drop.
Plus, in case the reaction will be "Oh, that is just another backward Middle Eastern country", look at the prison system in France for another example. Yeah, they do not have capital punishment, but prison there is not considered a place for people to be molly-coddled - like we do here! You get convicted, you go to jail and stay in there for your term (usually never leaving your cell for years) - without gyms, yard time, etc., etc. - even for relatively minor crimes. I'd almost rather take the capital punishment.Beancooker wrote:Why do you think countries like Saudi Arabia have such a low crime rate. Because the consequences of committing the crime are horrific.
Z
