goeatpaiste »
https://forums.nicoclub.com/goeatpaiste-u55898.html
Sat Jan 26, 2008 8:23 pm
well i think 100psi is pretty much the minimum for a gasoline engine to fire. on the other hand, drive yourself over to a motorsports shop and pick up some ring land cleaner/antisieze. you put a little in your spark plug hole and run the engine over. if a ring is stuck, it will most likely unstuck itself
stevo
