WORST JDM EXPERIENCE EVER!!!!!!!!!!!!!!!!!!!!!!
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
something is wrong with that whole setup take that bish back and demand a proper rb25DET!
Ballzout420
Car: 93 Coupe
yah i know just talked to jdm again for probly the 5th time now since friday they have lost my invoice and will not go any farther without the invoice and now he wants a letter from an ASE certified mechanic stating everythng that is wrong and what i have these guys are ridiculous....... tell me there not giving me the run around the guys def beat me on purpose and are trying to get away with it
StricNyne
Ok
so we need
but it sounds like you reached a
but u must
if you want us to help you
Kalypso
OP you fail
you bought a shytty jdm motor,
and now your getting mad at people because you made an a** out of yourself, and watched a guy seal a valve cover in front of you.
pics or gtfo
Ballzout420
Car: 93 Coupe
i would of put up pics yest if i could i will as soon as i can
krayton
ok...so have you looked at the stamp on the block yet?
for sure this is a rb25?
Ballzout420
Car: 93 Coupe
yes it stamped rb25 but the intake mani gasket and bolt pattern look exactly like the head is from a rb20 i dont understand it i wish i could of had pics a week ago ill make sure io get them up tonite
Ballzout420
Car: 93 Coupe
i know i screwed up big time it is my fault i should of waiting on buying the motor im just driving at the fact that a company like this should not screw a customer espiacally the way they did and also the way they have treated me i will not stop until this gets corrected trust me the screwed the wrong guy
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
StricNyne wrote:is it a 25de ? and they bolted up a exh manifold to it ? i think the de uses rb20 trans as well, and the 25de has smaller ports as well
I think Carlos might have called it.
Block stamped with RB25.Intake Gasket matches RB20.Everything else looks to be a RB25DET
Seems that you may have a RB25DE with the turbo components slapped on it.
RB25DE and RB20DET ports are the same (and the actual mounting part of the manifold). You can also tell if you have a RB25DET transmission or a RB25DE transmission as they look similar but the DET's shifter plate is slanted.
Minor differences you may start to find that scream incorrect motor. Or possibaly a cluster mess of engine parts from various RB motors.
Either way, good luck with everything and please accept those requesting pictures as they're only out to help.
