pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sun May 09, 2004 7:28 am
Well, if you are getting spark and fuel, but the car isn't starting, that means your injectors are clogged and this is a common problem on these engines when they sit for a while without starting them.
Get yourself a bottleof quick start and spray some in the throttle body, and try to start it, if it start for a sec or two, your injectors are clogged them. if so, then keep spraying bit by bit and keep starting it and eventually it will run.
PULSAR GTR
