pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sun May 09, 2004 7:28 am
the Tps won't cause the car not to start, it will cause it to ideal a bit rough, try using the quick start fluid before you remove your injectors, and the injectors aren't that hard to remove, no you don't have to remove the plenum, just take a look on the fuel rail, there are couple 12mm bolts, you remove them, and pull the rail upwards and then pull the injectors out.
good luck,
PULSAR GTR
