Won't Shift out of Park
jka999
What a pain in the backside. Rogue just won't shift out of park. Here's what I do to bypass. Follow instructions for releasing shift lock. on 5-16 in manual. Then you can put car in neutral....THEN into reverse.
Car going in on the 5th for a transmission replacement.
:mad:
ImStricken06
Car: 2008 Nissan Rogue (sold)
2013 Hyundai Santa Fe
2016 Kia Sorento
jka999 wrote:What a pain in the backside. Rogue just won't shift out of park. Here's what I do to bypass. Follow instructions for releasing shift lock. on 5-16 in manual. Then you can put car in neutral....THEN into reverse.
:mad:
this is not a transmission problem. this is a shifter problem. two different parts. here is the simple and cheap fix i came up with:
diy-stuck-shifter-wont-come-out-of-park ... 54005.html
Return to “Rogue Forum”
