S14-NEO wrote:id really be curious to see your A/F numbers when you at that high of boost..in my experience, using the SOHC MAFS are for only the last resort and emergency use only like jsut to get it runnign etc. the reason its not recommended to be used when boost pressure has been turned up is due to the fact of the inability for the SOHC MAF to be able to keep up with air flow requirements
at 14 PSI and WOT on the dyno I was at around 12/1 afr. I have put more than 60,000 miles on this engine alone and it has survived countless autoXs drag runs and 2 years worth of my hamb fisted day to day abuse, if it was an issue Im sure I would know about it.
